Can I bolt up 3Synco Trans to 18V motor?
bluemg
I have a 3 sync overdrive transmission, that I would like to test out. I was going to put it in a 65 MGB but sold it. Now I'm thinking about putting it in my 1600 MGA or selling it, but would like to make sure it is operating properly. I have a junk 1973 MGB with the 18V motor that Im using to test transmissions, ( cross member is cut out)
The input (first motion ) shaft appears to have the same splines and size but the older 3 sync shaft is about 1/2 inch longer overall, I'm afraid this will bottom out in the crank? The 3 sync trans is 5/8 of an inch shorter overall then the OD 4 sync
that came out of the 73 B.
There is also a difference on the bell housing starter bolts.
CAN A OLDER STYLE 3 SYNC OD TRANSMISSION BOLT UP TO A 18 v MOTOR?
I 'm not trying to test the units on the road, but have the car jacked up spinning the tires. So question #2 is could this present a problem testing out the Sync's downshifting? I wouldn't think so being the driveshaft is still turning when I downshift.
Thanks for your input.....
There a few difference between a MGB 3 and 4 syncro tranny set up, basicly, the rear engine plate, flywheels and starters are different, and have to be also change when making the conversion, now putting one in MGA is another story altogether, Bob White can tell you more about that than me, but what I sted covers the difference between the MGB tranny set ups.
tony barnhill
Great Pumpkin - R.I.P
Also, Hap, isn't the bearing inside the flywheel different?
bob67bgt
2 Types of 3 syncro MGB transmissions. Ones for a 3 main engine with the small input shaft and the ones for the 65-67 cars with the 5 main engine and larger input shaft. All you will be able to do with your test is to tell if it engages. Hap is correct about the back plate,flywheel and starter change to bolt it up for that test. You may be able to do the same test with a good drill attached to the input shaft and a battery to power it up and a speedometer and cable to see if the speed changes on engagement since you will probably not be able to tell if its going in at that speed. You still will not have alot of info on the trans. Good luck with it. Bob
tony barnhill
Another thing is to get one of each bushings from Moss - they're inexpensive - for the input shaft & test to see which fits....larger one goes in 18V.
B
bluemg
Thank you for your response and the help. Taking Tony's advise I got into the Moss book the MGA's used a 10 spline input shaft until the 1622 motors came out.
If I understand correctly. Since this D type OD, transmission is a 23 spline input shaft it doesn't look like a simple bolt up to the 1600 motor job.
#1 So the natural question is will the 10 spline input shaft from my present MGA transmission, adapt into the 3 sync D type OD MGB transmission ?
#2 I already have a 3.9 rear end in the A, Im now wondering would this be worth the extra trouble?
I guess this may be the last advice Tony ever gave here, and it was spot-on !
Thank you my friend for all the help you gave us all, Godspeed Tony.
Jkirchner Rocker Pedestal Banjo Bolt Thread Size Austin Healey 10
K TR2/3/3A Cylinder Head Bolt question.... Triumph 3
S TR2/3/3A old 4 bolt axle set up Triumph 12
D TR2/3/3A cylinder head oil plug bolt size Triumph 6
S TR2/3/3A old 4 bolt axle differential. Triumph 11
KVH General Tech Dog Bolt Torque—Crankshaft Triumph 11
JPSmit A fairly specific looking bolt Spridgets 10
F 59 bugeye spring bushing bolt Spridgets 8
A For Sale Rover V8 heads, 10 bolt Other British Classifieds 0
TR3MT TR2/3/3A Whitworth Threads (as on the bolt) Triumph 6
S TR2/3/3A Tightening the crank pulley dog bolt on a tr3 Triumph 7
K TR2/3/3A Brake caliper brake pad retaining plate bolt hole? Triumph 16
R difficult bolt access Spridgets 8
steveg TR6 Question - which bolt for heater return pipe bracket Triumph 3
B TR4/4A Starter dog bolt Triumph 15
S TR2/3/3A Generator Pulley Bolt Removal Triumph 12
J Steering Box Adjusting Bolt Lock Nut Austin Healey 11
K TR2/3/3A Steering box install again...the collar with the pinch bolt? Triumph 9
AngliaGT '74 Midget - Heater Box Bolt Size? Spridgets 8
P Rear Seat Pan Bolt Hole Locations on a BJ7 Austin Healey 1
R TR2/3/3A Extension Crank Bolt Attachment Triumph 12
Alfred E. Neuman TR4/4A TR4 fan extension and crank bolt length Triumph 9
D TR6 Rusted Trunnion Pivot Bolt Triumph 18
W Wanted Bolt on luggage rack Triumph Classifieds 4
KVH TR4/4A Lower Control Arm Front Pivot Bolt Triumph 9
maxwedge5281 front hubs for bolt on wheels Austin Healey 7
K TR4/4A TR4A clutch pressure plate to flywheel bolt "torque value"? Triumph 2
Popeye TR4/4A Found this odd long bolt in my fuel tank... Does anyone know what it is? Triumph 17
D Oil Filter Bolt Seal Austin Healey 2
C Tough Bolt on front of Crankshaft Spridgets 16
Scotsman TR4/4A Spinners for bolt on minilite wheels Triumph 0
G TR4/4A ARP Bolt Torque Specs Triumph 10
B TR2/3/3A Rear Spring front attachment bolt Triumph 23
Csarneson Connecting Rod Bolt Question Austin Healey 3
maxwedge5281 Wanted want to buy! one bolt on 3000 wheel! Austin Healey Classifieds 2
tomshobby Spitfire head size of damper pulley bolt on 78 Spit? Triumph 2
D BJ 8 Float Bowl securing bolt loose Austin Healey 6
tr3guy TR2/3/3A TR3 Fan Bolt Torque Triumph 3
Jim_Gruber Removing back Radius Arm Bolt Spridgets 12
D TR4/4A Does a bolt legend exist? Triumph 3
M Rear spring plate bolt Spridgets 1
Popeye TR4/4A Rear leaf spring bolt torque Triumph 11
GeorgeC BN1 bolt size Austin Healey 0
D TR4/4A Tr4 Vented gas tank banjo bolt Triumph 7
S Torque setting for U-Bolt nuts Austin Healey 12
F Tightening the idler pulley bolt on a 1098 Spridgets 2
C TR4/4A How to get the $&@%# filler bolt out of the side of the trans to top her off?!? Triumph 7
Got_All_4 TR2/3/3A The bolt on the back of the tr3 head Triumph 4
T TR2/3/3A coil mounting bolt oil leak Triumph 2
K TR6 Thread repair for trans cover bolt Triumph 14
