Bugeye single piece top frame same as two-piece?
Jimflorida
Does anyone know if the single-piece Bugeye convertible top frame is interchangeable with the similar-looking two-piece Sprite Mark II top frame? I need one for my Bugeye and the later 2-piece frame seems easier to come by. Jim
Absolutely will work, one of our group driving to Midget 50 this year in his Bugeye used my 2 piece from my MK1 Midget.
It was nice because his one piece bow made it hard to get his top on because it was tight. The two piece has the compression points with the springs so it can help with a tight top.
Yep.I have both styles. I use the two piece for the above reasons. It works great.
That's good to know. Thanks for your help. Jim
R Bugeye ignition switch Spridgets 2
T Music Video with a Bugeye, plus a hill climb video Spridgets 1
D For Sale 1958 A-H Bugeye Sprite Austin Healey Classifieds 3
Todd78d Bugeye carpet Spridgets 7
L For Sale original Bugeye SU H1-1 1/8 Carbs Spridgets Classified 0
Todd78d Bugeye choke linkage Spridgets 5
J Installing Adapter Hubs for Wire Wheels on a Bugeye Austin Healey 5
R Wanted Bugeye ignition switch Spridgets Classified 2
CARSINC 1965 Sprite Bugeye Spridgets 5
drooartz The great Gordon Murray has a Bugeye! Spridgets 0
W Bugeye Tudor Wash Bottle Decal Spridgets 0
R Bugeye drum brakes Spridgets 7
SNClocks Bugeye Alignment Spridgets 4
S For Sale Bugeye wheels, steel with round holes set of 5 available Spridgets Classified 0
J Finally getting (re) started on the Bugeye Spridgets 27
drooartz Restoring Penny the Bugeye Spridgets 22
drooartz Bugeye jack points to remove rear axle Spridgets 18
B Wanted Bugeye front bonnet fender mirror like this Spridgets Classified 5
SNClocks Bugeye axle limit straps Spridgets 5
R Wanted BUGEYE SHIFT LEVER Spridgets Classified 6
R Bugeye Starter Switch Spridgets 7
Lin Bugeye Axle Hub & Bearings Austin Healey 1
G For Sale 1960 BugEye..Very Good..$20,500 Austin Healey Classifieds 0
Lou E Finally a Bugeye of my very own Spridgets 41
5 Sold My 1960 Bugeye Spridgets 10
SNClocks Goings on with our new Bugeye Spridgets 1
F 59 bugeye spring bushing bolt Spridgets 8
Rut 3 point belts in a Bugeye? Spridgets 9
JPSmit gluing a panel on to a bugeye Restoration & Tools 2
I Bugeye oil leak help Spridgets 4
I Bugeye lack of power Spridgets 1
I Bugeye charging issues Spridgets 8
I Bugeye smoking Spridgets 9
I Bugeye valve rebuild suggestions Spridgets 8
jfarris Immaculate 1958 Bugeye Spotted 4
drooartz Leno's Bugeye Spridgets 12
R BUGEYE SOFT TOP FIT Spridgets 2
R Bugeye splined wheels Spridgets 0
T Wanted Bugeye Sprite RHD tonneau cover. Austin Healey Classifieds 0
Jim_Gruber Bugeye Seat Pans needed Spridgets 1
B Fluctuating Fuel Gauge 1960 Bugeye Spridgets 4
Basil For you Bugeye/ Frogeye fans Spridgets 5
B Bugeye Electrical Diagram with additions Spridgets 6
R 59 Bugeye rib cage tranny hard shift into reverse Spridgets 0
R Bugeye reverse gear Spridgets 6
