Bugeye Side Curtain Mystery
mxp01
Gentlemen:
I continue the resto on my 1960 BE. This week I began working on sprucing up the side curtains. I removed the rubber gaskets and attaching brackets, polished the metal and refurbed the plastic.
I have to order new rubber gaskets from VB or Moss, but just to see how the brackets would hold in place, I put the windows on the door. That's when I spotted what could be a problem:
- The driver's side frame goes right up against the windshield post when the door is closed. That means that once the rubber gaskets are on the frame is going to be a really tight squeeze in this area. Meanwhile, the passenger door window frame seems to allow enough of a gap that will be filled quite comfortably by the new gaskets.
I measured both window frames and found they are identical. They both are attached by the thumbscrews, which are in their proper spots on the doors. Their mounting brackets are in the same spots and I found that the back ends of the windows reach to the very back of the doors so the roof should fit securely.
The doors shut correctly and the windshield seems to be positioned correctly, so where is the geometry wrong on the car?
Mike Pennell
texas_bugeye
Could the frame be out of square? well I know its not square but maybe it was drop on an edge or something throwing of the angle of the frame. That would push the leading edge more upright making it closer to the windsheild. You could stack them on each other and see the differance it that is the case.
jlaird
I should think, only think now.
That I would try differing combinations of the part that hooks the frame to the door. They are bendable and may not be all the same. In any case maybe several can be bent to make it fit correctly.
George Zeck
Mike -
It got bent over the years. I just had the same issue and consulted a restored BE and said it jsut needed a slight bend to put into proper allignemnt.
Tx-
Geo
jlaird
Ahh yes, compare the two sides to see if one is bent somehow.
I Bugeye side curtain bracket help Spridgets 2
G Side curtain windows for Bugeye Spridgets 1
R Wanted Bugeye front side lights (clear lens) Spridgets Classified 3
R bugeye side lights. Spridgets 0
R Bugeye side curtains Spridgets 4
Hot Wings Bugeye side curtains Spridgets 6
I Help on installing side curtains and rag top on Bugeye please Spridgets 4
ShawnC_at_Moss Question for you Bugeye guys regarding trunk side panels Spridgets 20
L Bugeye Side Curtains Spridgets 6
H Bugeye Sprite Side Curtains redo Spridgets 8
Gray_Cat Bugeye On the Side Spridgets 3
R Bugeye ignition switch Spridgets 2
T Music Video with a Bugeye, plus a hill climb video Spridgets 1
D For Sale 1958 A-H Bugeye Sprite Austin Healey Classifieds 3
Todd78d Bugeye carpet Spridgets 7
L For Sale original Bugeye SU H1-1 1/8 Carbs Spridgets Classified 0
Todd78d Bugeye choke linkage Spridgets 5
J Installing Adapter Hubs for Wire Wheels on a Bugeye Austin Healey 5
R Wanted Bugeye ignition switch Spridgets Classified 2
drooartz Replacing Bugeye windshield rubber Spridgets 6
CARSINC 1965 Sprite Bugeye Spridgets 5
drooartz The great Gordon Murray has a Bugeye! Spridgets 0
W Bugeye Tudor Wash Bottle Decal Spridgets 0
R Bugeye drum brakes Spridgets 7
SNClocks Bugeye Alignment Spridgets 4
S For Sale Bugeye wheels, steel with round holes set of 5 available Spridgets Classified 0
D Wanted Bugeye bonnet (hood) fiberglass or steel Austin Healey Classifieds 0
M Wanted Need 59 Bugeye Dashboard. LHD. Spridgets Classified 1
drooartz Restoring Penny the Bugeye Spridgets 22
B Wanted Bugeye front bonnet fender mirror like this Spridgets Classified 5
SNClocks Bugeye axle limit straps Spridgets 5
R Wanted BUGEYE SHIFT LEVER Spridgets Classified 6
R Bugeye Starter Switch Spridgets 7
Lin Bugeye Axle Hub & Bearings Austin Healey 1
G For Sale 1960 BugEye..Very Good..$20,500 Austin Healey Classifieds 0
Lou E Finally a Bugeye of my very own Spridgets 41
5 Sold My 1960 Bugeye Spridgets 10
SNClocks Goings on with our new Bugeye Spridgets 1
F 59 bugeye spring bushing bolt Spridgets 8
Rut 3 point belts in a Bugeye? Spridgets 9
JPSmit gluing a panel on to a bugeye Restoration & Tools 2
I Bugeye oil leak help Spridgets 4
I Bugeye lack of power Spridgets 1
I Bugeye charging issues Spridgets 8
I Bugeye smoking Spridgets 9
I Bugeye valve rebuild suggestions Spridgets 8
