Bugeye Release Bearing Question
TexasSprite
I've attached my BE 948 to a rebuilt ribcase gearbox and have a question about proper clearance of the release bearing from the pressure plate. With the push rod fully depressed into the slave cylinder, there is about 1/8" clearance. It also looks like when fully extended the rod should have enough travel to release the pressure plate. However, the slave cylinder has a spring inside which puts pressure against the pushrod, so that at rest, the release bearing is putting pressure against the pressure plate. My question is that once bled, will the fluid in the line prevent the spring loaded pushrod from moving forward. It seems like the spring ought to keep the cylinder closed instead of trying to open it.
Thanks for help with such a basic question. This part of my BE was totally non functional, so I don't have an example of how it should actually look.
My workshop manual shows the spring in the place you say - pushing the piston forwards, which as you say does seem the wrong way round!
Looking at the diagram, I suspect the purpose of the spring is too keep the piston pushed against the rubber. Without the spring it could be possible for the fluid to push the seal along the bore and the piston to get left behind.
I vaguely recall there are some 'rules' about using a rib 'box with a 948 engine - eg which release arm and clutch you should use, but I can't remember what the rules are, sorry! It way be that you need to use the smoothcase release arm for instance, but don't take that as gospel!
I can recall that with my car (that had ribcase and 948 and also arrived dis-assembled) the pushrod was too short and I had to make a longer one to get it to disengage, but as that was 15 years ago I can't remember the details.
It seems sensible that at rest the release bearing isn't touching the clutch, but the spring seems like that can't happen.
Does that help? No I don't think so either, buit no-one else has replied, so at least you know that the rest of us can see your post!
John
Longer pushrod.
Jack is correct, though I have encountered a home fix (which I would NOT recomend!) of bending the fork to obtain the right clearance! /bcforum/images/%%GRAEMLIN_URL%%/eek.gif
R Bugeye ignition switch Spridgets 2
T Music Video with a Bugeye, plus a hill climb video Spridgets 1
D For Sale 1958 A-H Bugeye Sprite Austin Healey Classifieds 3
Todd78d Bugeye carpet Spridgets 7
L For Sale original Bugeye SU H1-1 1/8 Carbs Spridgets Classified 0
Todd78d Bugeye choke linkage Spridgets 5
J Installing Adapter Hubs for Wire Wheels on a Bugeye Austin Healey 5
R Wanted Bugeye ignition switch Spridgets Classified 2
drooartz Replacing Bugeye windshield rubber Spridgets 6
CARSINC 1965 Sprite Bugeye Spridgets 5
drooartz The great Gordon Murray has a Bugeye! Spridgets 0
W Bugeye Tudor Wash Bottle Decal Spridgets 0
R Bugeye drum brakes Spridgets 7
SNClocks Bugeye Alignment Spridgets 4
S For Sale Bugeye wheels, steel with round holes set of 5 available Spridgets Classified 0
D Wanted Bugeye bonnet (hood) fiberglass or steel Austin Healey Classifieds 0
M Wanted Need 59 Bugeye Dashboard. LHD. Spridgets Classified 1
drooartz Restoring Penny the Bugeye Spridgets 22
B Wanted Bugeye front bonnet fender mirror like this Spridgets Classified 5
SNClocks Bugeye axle limit straps Spridgets 5
R Wanted BUGEYE SHIFT LEVER Spridgets Classified 6
R Bugeye Starter Switch Spridgets 7
Lin Bugeye Axle Hub & Bearings Austin Healey 1
G For Sale 1960 BugEye..Very Good..$20,500 Austin Healey Classifieds 0
Lou E Finally a Bugeye of my very own Spridgets 41
5 Sold My 1960 Bugeye Spridgets 10
SNClocks Goings on with our new Bugeye Spridgets 1
F 59 bugeye spring bushing bolt Spridgets 8
Rut 3 point belts in a Bugeye? Spridgets 9
JPSmit gluing a panel on to a bugeye Restoration & Tools 2
I Bugeye oil leak help Spridgets 4
I Bugeye lack of power Spridgets 1
I Bugeye charging issues Spridgets 8
I Bugeye smoking Spridgets 9
I Bugeye valve rebuild suggestions Spridgets 8
jfarris Immaculate 1958 Bugeye Spotted 4
drooartz Leno's Bugeye Spridgets 12
R BUGEYE SOFT TOP FIT Spridgets 2
R Bugeye splined wheels Spridgets 0
T Wanted Bugeye Sprite RHD tonneau cover. Austin Healey Classifieds 0
Jim_Gruber Bugeye Seat Pans needed Spridgets 1
B Fluctuating Fuel Gauge 1960 Bugeye Spridgets 4
Basil For you Bugeye/ Frogeye fans Spridgets 5
B Bugeye Electrical Diagram with additions Spridgets 6
R 59 Bugeye rib cage tranny hard shift into reverse Spridgets 0
R Bugeye reverse gear Spridgets 6
