Rut
My car currently has dual Tilton 3/4" brake and clutch master cylinders and they sit on top of the pedal box with the rods at an angle. I would like to build or modify a pedal box so the MCs will sit at the same angle as the originals, but the 2 together are 3.75" wide or about 1.25" wider that the inside of the original pedal box. At the existing angle I feel like I have less available travel of the push rods. Is this a fairly easy project and is it worthwhile? I have less movement in the brakes and clutch than I would like.
Thanks, Rut
Thanks, Rut
