Bugeye Floor Replacement
Blueghost
Ready to start Bugeye floor replacement. It is up on a rotisserie. Will do all pannels one at a time, including lateral cross members just below knees. In order to minimumize distortion I will install braces in both door areas.
Question: is there a prefered method for bracing? Some kind of "X" is probably strongest, but more difficult to fabricate. Looks like 1 1/2" angle iron welded between flat plates on each end, and then bolted to top door hinge mount and door latch striker stud mount, would be a lot easier to make and install than an "X" brace. This would only produce a "box" shaped brace. However, if something more substantial than what I described is necessary I'll do whatever it takes. Don't need over kill, but don't want to screw up due to a few extra hours work.
Thoughts from guys who have done this job??? Thanks.
I don't think you could go wrong in following Peter Ploof's lead and copying how he supported his car during it's rebuild. https://www.cardomain.com/ride/2203663 There are lot of photos, but it's perhaps the most complete sheet metal rebuild of a Bugeye that's ever been attempted.
I think maybe the young lady on Wreck Rescue started with less! At least Peter's car was "intact" and running.... :smile:
apbos Bugeye floor replacement Spridgets 34
B Two questions about Bugeye floor panel weld drilling Spridgets 15
M Bugeye engine removal with floor jack Spridgets 14
Rut Bugeye Floor Pans Spridgets 6
T Drew - got the floor back in the Bugeye Spridgets 25
T Anyone need Bugeye floor patch? Spridgets 2
R Bugeye ignition switch Spridgets 2
T Music Video with a Bugeye, plus a hill climb video Spridgets 1
D For Sale 1958 A-H Bugeye Sprite Austin Healey Classifieds 3
Todd78d Bugeye carpet Spridgets 7
L For Sale original Bugeye SU H1-1 1/8 Carbs Spridgets Classified 0
Todd78d Bugeye choke linkage Spridgets 5
J Installing Adapter Hubs for Wire Wheels on a Bugeye Austin Healey 5
R Wanted Bugeye ignition switch Spridgets Classified 2
drooartz Replacing Bugeye windshield rubber Spridgets 6
CARSINC 1965 Sprite Bugeye Spridgets 5
drooartz The great Gordon Murray has a Bugeye! Spridgets 0
W Bugeye Tudor Wash Bottle Decal Spridgets 0
R Bugeye drum brakes Spridgets 7
SNClocks Bugeye Alignment Spridgets 4
S For Sale Bugeye wheels, steel with round holes set of 5 available Spridgets Classified 0
D Wanted Bugeye bonnet (hood) fiberglass or steel Austin Healey Classifieds 0
M Wanted Need 59 Bugeye Dashboard. LHD. Spridgets Classified 1
drooartz Restoring Penny the Bugeye Spridgets 22
B Wanted Bugeye front bonnet fender mirror like this Spridgets Classified 5
SNClocks Bugeye axle limit straps Spridgets 5
R Wanted BUGEYE SHIFT LEVER Spridgets Classified 6
R Bugeye Starter Switch Spridgets 7
Lin Bugeye Axle Hub & Bearings Austin Healey 1
G For Sale 1960 BugEye..Very Good..$20,500 Austin Healey Classifieds 0
Lou E Finally a Bugeye of my very own Spridgets 41
5 Sold My 1960 Bugeye Spridgets 10
SNClocks Goings on with our new Bugeye Spridgets 1
F 59 bugeye spring bushing bolt Spridgets 8
Rut 3 point belts in a Bugeye? Spridgets 9
JPSmit gluing a panel on to a bugeye Restoration & Tools 2
I Bugeye oil leak help Spridgets 4
I Bugeye lack of power Spridgets 1
I Bugeye charging issues Spridgets 8
I Bugeye smoking Spridgets 9
I Bugeye valve rebuild suggestions Spridgets 8
jfarris Immaculate 1958 Bugeye Spotted 4
drooartz Leno's Bugeye Spridgets 12
R BUGEYE SOFT TOP FIT Spridgets 2
R Bugeye splined wheels Spridgets 0
T Wanted Bugeye Sprite RHD tonneau cover. Austin Healey Classifieds 0
