Bugeye dash light problems
ichthos
Going through my yearly maintainence before I start driving again. My dash lights are suddenly not working. All my running and headlights work. The turn signals work, but all the instruments and an auxiliary cig lighter do not light up. I only have two fuses I can see in the engine bay. Any suggestions on what to check? Any help is greatly appreciated.
Kevin
Did you use a continuity meter on the fuses? Sometimes they burn out under the cap; looking at them you may not see it.
Take a look at the dash light switch first. Maybe it just got switched off. If not try switching it back and forth a few times. If that doesn’t work jump it out. Those light are not fused.
Kevin, you really need to get a wiring diagram for your car.
Gilderman said to check the fuses, but the dash lights are unfused as delivered from the factory.
The dash lights should be red/white wires, and are powered by the round ignition/lighting switch in the center of the dash.
I would check to see if the switch under the dash....to the left of the steering column has been turned off. BEs do not use variable knob to vary the brightness of the dash bulbs, just the switch. If that does not work, check the red/white wires under the dash for a bad connection.
Good luck, Scott in CA
I agree that the dash light switch could be suspect. It's not a great switch. Jumper across it to be sure.
Sure sounds like that is the culprit instrument lights and for some reason the cigar lighter on my drawing all are powered thru the littl edge of the dash switch. All wires thru the switch are red with white tracer.
You may not know you even have a dash light switch. Under the Center of the dash, bottom side, little slide switch. One side on, one side off. And you always wondered what that switch did.
I completely for got about the switch. I don't even see the point of it. In any case, I did jump it and the lights worked, so it was the switch after all. Luckily I had an old spare. Thanks everyone.
Well, there you go! It's really not a good quality switch, but good that you have a spare. :encouragement:
Be careful when replacing it. My DPO managed to make the wires touch the dash and let the smoke out!
Kurt
longbridgehealey Bugeye dash Spridgets 6
I Bugeye dash pot oil level Spridgets 3
TulsaFred Bugeye radio in-dash Spridgets 10
Editor_Reid WTB Bugeye Dash Knob Set Spridgets 13
D Bugeye dash vinyl Spridgets 19
L Bugeye dash indicator assembly pieces ? Spridgets 0
F Wire insulation damage under the dash - Bugeye Spridgets 5
TulsaFred Source for Bugeye dash/switch bezel nuts Spridgets 9
TulsaFred Bugeye dash grab handle Spridgets 6
TulsaFred bugeye windscreen washer pump dash fitting Spridgets 10
60Bugeye Bugeye Dash Help Spridgets 23
I Bugeye - need help with last 3 dash wires Spridgets 7
M Building Bugeye dash Spridgets 28
toysrrus "WANTED": "ORIG. BUGEYE SERVICE MANUAL" & `59 DASH Spridgets 7
W Will a Bugeye dash fit Spridgets 12
John Moore Bugeye Seat Bottoms / RHD Dash Spridgets 1
Shealey Anyone have a dash grab handle for a Bugeye? Spridgets 17
Shealey Need a photo of a unmolested dash. 58/59 bugeye. Spridgets 25
msoylemez original bugeye dash items Spridgets 27
F Bugeye dash color Spridgets 5
B Bugeye Dash Covering? Spridgets 4
G Install Bugeye dash in my 67 Midget Spridgets 0
R Bugeye ignition switch Spridgets 2
T Music Video with a Bugeye, plus a hill climb video Spridgets 1
D For Sale 1958 A-H Bugeye Sprite Austin Healey Classifieds 3
Todd78d Bugeye carpet Spridgets 7
L For Sale original Bugeye SU H1-1 1/8 Carbs Spridgets Classified 0
Todd78d Bugeye choke linkage Spridgets 5
J Installing Adapter Hubs for Wire Wheels on a Bugeye Austin Healey 5
R Wanted Bugeye ignition switch Spridgets Classified 2
CARSINC 1965 Sprite Bugeye Spridgets 5
drooartz The great Gordon Murray has a Bugeye! Spridgets 0
W Bugeye Tudor Wash Bottle Decal Spridgets 0
R Bugeye drum brakes Spridgets 7
SNClocks Bugeye Alignment Spridgets 4
S For Sale Bugeye wheels, steel with round holes set of 5 available Spridgets Classified 0
J Finally getting (re) started on the Bugeye Spridgets 27
drooartz Restoring Penny the Bugeye Spridgets 22
drooartz Bugeye jack points to remove rear axle Spridgets 18
B Wanted Bugeye front bonnet fender mirror like this Spridgets Classified 5
SNClocks Bugeye axle limit straps Spridgets 5
R Wanted BUGEYE SHIFT LEVER Spridgets Classified 6
R Bugeye Starter Switch Spridgets 7
Lin Bugeye Axle Hub & Bearings Austin Healey 1
G For Sale 1960 BugEye..Very Good..$20,500 Austin Healey Classifieds 0
