UPDATE: 03 AUG '15
I believe problem is solved.
Another TR enthusiast found :
1) front carb needle adjust was out of its threads - therefore not adjusting and stuck full-rich.
2) front carb gasket for new air filters was covering the "float vent" opening.
Also, he plugged the "temperature compensator" vent hole. ("not necessary in our climate" and could cause unwanted mixture changes)
Then set both needles to 1.5 turns cw from stop.
Then drove about 5 miles --stopped to check plugs and adjust needle 1/4 turn according to plug color and then repeated the stop/check plugs/adjust needle procedure, until all plugs had equal brownish/beige color AND the "stumbling miss" was minimized or gone!.
He suggests replacing needles and jets with new because they have "wear" issues over time.........
I trailered it back home so I still need to do more road testing to be sure -- but that day it was clearly "FIXED" . Thanks to ALL on this forum for their thoughts and advice - it was appreciated!!
tv44engr
1970 TR 6 Overdrive.
Stock motor, stock Z-S 175 carbs & stock manifolds.
It has: Pertronix, custom exhaust, foam air filters & light flywheel.
This car ran perfect for about a year, then when I took it off the trailer at my first ever car show after about a 300 mile trip, it came down with the symptoms below and has not improved!
After driving 5 to 15 minutes it begins running very rough as if flooding & then won't idle & dies at stop
signs ....... resulting in front 3 spark plugs fouled solid sooty black & dry .... rear 3 plugs appear only
slightly black .
So far we have replaced: fuel, in line fuel filter, front carb float, spark plugs (NGK BP5ES, Champ N12YC & Autolite 65), plug wires, coil wire, coil, distributor, distributor cap, rotor & air filters.
Swapped Pertronix with points/condenser -- currently back to Pertonix.
Both carbs were rebuilt and fuel pump replaced about 10 months prior.
Checked for vacuum leaks, checked for spurious spark under bonnet at night.
Compression checked a few weeks prior: approx 160 with one about 140.
Timing has been set & rechecked.
Valve clearances were set a few weeks prior to the problem.
The front carb: has been disassembled, cleaned & inspected 3 more times; the last time we installed a Grose jet; checked & rechecked float level, adjusted idles & synched carbs several times.
Where to look now?????
Tom
tv44engr@att.net
tv44engr
slightly black .
Tom
tv44engr@att.net
