BJ8 intake manifold measurements
Lin
I am restoring a 60 BT7 and considering switching to BJ8 carbs. A lister gave me 2 used carbs to be restored and what he thinks is a BJ8 intake manifold. The ports on the carbs measure 2." The ports on the manifold measure 1 3/4." Do I have another BT7 manifold for the HD6 1 3/4" carbs instead of a BJ8? If one opens up the manifold ports to 2" is that all that is required to accommodate the HD8 carbs? Is the internal chamber in a BJ8 manifold the same as a BT7 manifold-just port opening size difference? Thanks.
Lin Rose
1960 BT7 in restoration
1959 Bugeye
Yes Lin, you can open up the port size but it just may be a BJ7 intake manifold and thats ok too.--Fwiw---Keoke
Ok, I did a little research and now my curiosity is piqued! Graham Robson in "The Big Healeys" says, "Although an identical 'looking' inlet manifold was retained, it was modified in several respects to take account of the fact that twin 30-degree semi-downdraught 2" HD8 carburettors were fitted."
In Bill Emerson's book, Bill states, "the carburettors were matched to an internally redesigned intake manifold..."
So, does anyone know what these modificatins were outside of the ports being opened to 2"?
Lin
1959 Bugeye
Lin, Thats all I know that they did to them.?? Maybe Norman Knock has some inside info---Keoke
Scotsman BJ8 Intake Manifold Differences Austin Healey 4
Patrick67BJ8 BJ8 Intake manifold Booster & Vacuum Hookup threads sizes. Austin Healey 2
J Bj8 intake manifold to heat shield to carb gaskets Austin Healey 4
H BJ8 blew out intake manifold plug Austin Healey 10
Patrick67BJ8 BJ8 - Intake Manifold, carb, gaskets sequence - Info needed Austin Healey 2
Patrick67BJ8 Copper Drain Lines for BJ8 Carb/Intake Manifold Austin Healey 30
L Fresh air and Blower intake hose replacement on BJ8 Austin Healey 12
F BJ8 Exhaust Hanger Pictures Wanted Austin Healey 9
Patrick67BJ8 Custom BJ8 Dash Switch Panel Austin Healey 7
1 BJ8 History Trace Austin Healey 7
D BJ8 Top Installation Detail Austin Healey 3
AUSMHLY BJ8 Trans Cover Carpet Austin Healey 7
AUSMHLY BJ8 Carpet and Snaps Austin Healey 2
Overdrive45 BJ8 Interior Trim Austin Healey 8
nitro BJ8 Production Year Austin Healey 6
B BJ8 Seat Sliders Austin Healey 4
B For Sale 1967 Metallic Golden Beige MKIII BJ8 Numbers Matching - The Real Deal Austin Healey Classifieds 0
BoyRacer For Sale BJ8 disk wheel hubs, spindles & calipers Austin Healey Classifieds 0
S SOLD!! For Sale 1964 AH 3000 MkIII BJ8 Phase 1 Austin Healey Classifieds 2
AUSMHLY BJ8 Cylinder Head Installation Austin Healey 6
LAW75 BJ8 Brake Lines Austin Healey 2
BoyRacer For Sale BJ8 spindles & disc wheel hubs Austin Healey Classifieds 0
G Wanted BJ8 Tonneau Cover Austin Healey Classifieds 0
Cutrog1 For Sale Healey 3000 BJ8.... a restoration saga Austin Healey Classifieds 0
Scotsman Wiring Diagram for 1966 BJ8 Austin Healey 3
A For Sale 1966 3000 Healey Blue BJ8 Austin Healey Classifieds 3
B BJ8 Hood Bow and Seal Austin Healey 5
Mickey Richaud Wanted Wanted: BJ8 Seat Track Sets (Both Sides) Austin Healey Classifieds 5
AUSMHLY Laygear End Float BN1-BJ8 Austin Healey 2
C For Sale BJ8 original dash Austin Healey Classifieds 3
LarryK BJ8 Parts or Project Car For Sale in St. Louis Austin Healey 3
B BJ8 Centre Console Chrome Strips Austin Healey 5
B Wanted Chrome strips centre console BJ8 Austin Healey Classifieds 0
AUSMHLY BJ8 Cylinder Head Re-Torque Austin Healey 26
AUSMHLY BJ8 Transmission Gasket Austin Healey 0
