Bj8 gearbox problems
James A
Hi All!
During the last few trips, it is becoming harder and harder to get the car in gear both whilst driving and stationary.
I have not checked the gearbox oil however what is likely to be the problem here?
James
All gears (first, of course, is always a bear--no synchro)? If so, it's possible your clutch isn't disengaging. If it's an individual gear, then it's likely the synchro for that gear. Check the fluid level first.
Start by bleeding the clutch thoroughly. You'll have to do it from underneath--still difficult--or remove the transmission cover.
Does it seem you have to push the pedal further down than you used to? If so, that's a sign you need to bleed the clutch hydraulics..
Might be a good time to put on one of those aftermarket bleeders so you won't have to work so hard the next time.
YEP:
However, some simplicity can be gained by cutting the head off the top retainer bolt for the clutch cylinder and then reinstalling it as a guide pin .
Now the cylinder can be dropped down easily to perform the bleeding action.
One of the best mods I ever did; got one from the late, great Doug Reid ('Mr. Finespanner'). Bled my clutch once in a restaurant parking lot waiting for the restaurant to open.
Everyone is saying bleed bleed bleed and it is something to check ,however if this is a problem that has developed over time and theres no leaking hydraulic fluid from the clutch slave cylinder then the chances of bleeding helping are slim .
The rod that fits into the slave cylinder has a cotter pin in it . The pin and the hole it fits in wear over time so the clutch slave cylinder although it maybe working may simply not be pushing the rod far enough to disengage the clutch because the hole and cotter pin are worn out . Jack the car up get underneath and check the pin/rod etc for excessive wear .
Also check the play on the MC push rod and see if the round hole us not a large slot.
Sounds like a typical clutch wearing out issue. You should check all the things stated above but if all that checks then plan on a new clutch disc, pressure plate and throwout bearing.
S Embarrassed to ask: Transmission/Gearbox filler location on BJ8 Austin Healey 14
ttrotter Gearbox numbers location? 67 BJ8 Austin Healey 2
D BJ8 Steering gearbox Seal Austin Healey 9
S bj8 gearbox cover Austin Healey 4
S BJ8 gearboxBJ8 Gearbox Austin Healey 1
S austin healey bj8 gearbox Austin Healey 3
E BJ8 gearbox Austin Healey 1
F BJ8 Exhaust Hanger Pictures Wanted Austin Healey 9
Patrick67BJ8 Custom BJ8 Dash Switch Panel Austin Healey 7
1 BJ8 History Trace Austin Healey 7
D BJ8 Top Installation Detail Austin Healey 3
S Wanted WTB: 3.5 ratio diff/pumkin for '67 BJ8 Healey 3000 Austin Healey Classifieds 0
AUSMHLY BJ8 Trans Cover Carpet Austin Healey 7
AUSMHLY BJ8 Carpet and Snaps Austin Healey 2
Overdrive45 BJ8 Interior Trim Austin Healey 8
nitro BJ8 Production Year Austin Healey 6
B BJ8 Seat Sliders Austin Healey 4
BoyRacer For Sale BJ8 disk wheel hubs, spindles & calipers Austin Healey Classifieds 0
S SOLD!! For Sale 1964 AH 3000 MkIII BJ8 Phase 1 Austin Healey Classifieds 2
Patrick67BJ8 BJ8 Factory Hardtop Rear Window Austin Healey 6
AUSMHLY BJ8 Clutch Pressure Plate, Old vs New Austin Healey 4
AUSMHLY BJ8 Clutch Fork Bush Replacement Austin Healey 5
AUSMHLY BJ8 Cylinder Head Installation Austin Healey 6
LAW75 BJ8 Brake Lines Austin Healey 2
AUSMHLY BJ8 Clutch Pressure Plate Brand Preferences Austin Healey 3
BoyRacer For Sale BJ8 spindles & disc wheel hubs Austin Healey Classifieds 0
G Wanted BJ8 Tonneau Cover Austin Healey Classifieds 0
Cutrog1 For Sale Healey 3000 BJ8.... a restoration saga Austin Healey Classifieds 0
AUSMHLY BJ8 Overdrive Oil Passages Austin Healey 2
Scotsman Wiring Diagram for 1966 BJ8 Austin Healey 3
A For Sale 1966 3000 Healey Blue BJ8 Austin Healey Classifieds 3
B BJ8 Hood Bow and Seal Austin Healey 5
Mickey Richaud Wanted Wanted: BJ8 Seat Track Sets (Both Sides) Austin Healey Classifieds 5
Scotsman BJ8 Intake Manifold Differences Austin Healey 4
AUSMHLY Laygear End Float BN1-BJ8 Austin Healey 2
C For Sale BJ8 original dash Austin Healey Classifieds 3
LarryK BJ8 Parts or Project Car For Sale in St. Louis Austin Healey 3
Patrick67BJ8 BJ8 Intake manifold Booster & Vacuum Hookup threads sizes. Austin Healey 2
B BJ8 Centre Console Chrome Strips Austin Healey 5
B Wanted Chrome strips centre console BJ8 Austin Healey Classifieds 0
