BOBBYR
Hi Guys,
I hope everyone is well.The other night, I replaced the points and plugs and thought it a good idea to check the timing. I think this could be the beginning of a drinking problem. Timing this motor is not an easy job. As I see it, the manual spec for idle timing is 10 deg.BTDC at 600 rpm's. Getting this motor to run at 600 rpm's is next to impossible. Also, the pointer on the timing gear case only indicates top dead center. Any help in timing this beast would be appreciated. Meanwhile, I'm going out to the garage to read the manual and have a cold brew.
Bobby R
Bobby R
