Hi Guest! If you enjoy and benefit from your participation at British Car Forum, please consider supporting our efforts with a subscription. There are some perks with a member upgrade!
Do one or more valves in the fully open position extend into any area through which the piston may travel? Trying to see if a stuck valve will cause the engine to blow up on a first startup.
