BJ8 Cylinder Head Gasket
Joe Schlosser
The copper "paint" is super sticky, and keeps the gasket from moving during assembly. It keeps the cylinder sealing ring aligned. In addition, it aids the seals for the water and oil passages.
I stand corrected (my laptop's on a standup desk). Ordinary copper paint could be lubricating; see: various anti-seize products.
Keoke
Some of these copper anti-seize products, one of which is Copaslip, are listed as hazardous products in California.
Hazardous maybe, but AFAIK you can still buy it in or get shipped to CA. I can't remember the last time I bought something that didn't have a Prop65 warning on it; when every stinkin' thing has a warning on it people tend to ignore them.
Dandare
At the time the manuals were written the copper/asbestos head gaskets (that I have seen) appeared to be coated with a varnish-like substance... apparently some kind of sealer? Do the current manufacture gaskets have any discernable coating on them?
Danny
The Payen head gasket I gave to my builder was probably 20 or mores year old. I don't recall any varnish-type coating, but it might have had some sort of anti-corrosion treatment; pure copper, of course, tends to corrode greenish in the elements (copper oxide, I presume). I'd opened the saran like wrap on the gasket set years earlier to steal a gasket, so mine had at least some exposure, but no green.
Dandare
Bob, the ones I am referring to were mostly new old stock C series VRS sets acquired in the early eighties and packaged as BMC, Leyland and even Nuffield. I still have a few of 'em!
Danny
Those probably had asbestos, the later ones--including Payen--probably used whatever the replacement substance was (which likely didn't work as well). The auto manufacturers could have outsourced their gaskets.
Dandare
The gaskets felt sticky, whether that was age (of the gasket) or not I don't know. I felt inclined to wash one off once but was told it was meant for sealing hence the manuals saying to not use any sealer.
Are there any composite gaskets available for the six cylinder? I thought there used to be but can't see any on the AH Spares site for example.
Danny
R
robolab
I installed the head with a new quality head gasket from AH Spares. I then found that the new standard head bolts and nuts were of poor quality. With 2 bolts the thread gave up and overwinded before I applied the necessary torque. Will now order the improved heavy-duty bolts and nuts and put the head back on.
Now my question to the specialists. Should i use a new quality gasket, or is the head gasket that is included in the Payen gasket kit good enough? I haven't used them yet.
Thanks
Keoke
HI :
I have used Payen gaskets in the past with no problems.
However:
If you did not torque the existing gasket U might get by with just using new bolts ??
Joe Schlosser
Payen gaskets are very good. Used them on many applications.
If you can get ARP bolts or Nuts they are IMHO the best out there
AUSMHLY
At the time the manuals were written the copper/asbestos head gaskets (that I have seen) appeared to be coated with a varnish-like substance... apparently some kind of sealer? Do the current manufacture gaskets have any discernable coating on them? Danny
The BJ8 head gasket I received from AHSpares, part ENG602P, stamped AD890, seems to have a varnish-like substance.
AHSpares Description:
Gasket - cylinder head - High Quality UK made
These high quality head gaskets are made in the UK to exact original specifications from original tooling exclusively for A.H. Spares Ltd.
The materials used are of a very high specification so these gaskets are far superior to any aftermarket gasket currently available.
The gasket seems to be 3 layers. Top copper, middle? bottom some sort of steel? Something clear has been sprayed over the entire gasket. It's not sticky. It appears to have a very slight orange peel texture and what appears to be dust in that coating.
I've read that in preparation of installing a head gasket, both surfaces, engine and cylinder head should be absolutely flat, clean, no residue. Should I be concerned with the surface of the gasket I received? It appears to have dust in the clear coating. (see photos).
I've also noticed that there are places on the edges of the gasket that are separated. Is that normal?
AUSMHLY
High Austin Healey friends,
The manual says that the head gasket is to be installed dry, i.e. without sealants such as Hylomar.
With my Triumph TR3a, however, it was stated that the head gasket should be installed with Hylomar or something similar.
What is better now? Are there any experiences? My triumph has been tight for 10 years.
Thanks Gerd
I'm getting ready to install my head gasket. See my prior post.
Thoughts on install dry or with a sealant?
Hylomar, there are different versions.
Copper spray for head gaskets, different companies offer them.
Wellseal is used for the 100.
I will be using new ARP studs, washers and nuts, torqued to 75 fl/lbs in the order specified in the manual.
dougie
AUSMHLY
Thank you Dougie, HP. I used that on the exhaust gasket. Do you use anything on the exhaust gasket?
Prior post and included photos. Should I be concerned with the new head gasket I received?
1. Why does it have that clear coating on all sides?
2. What is the clear coating made of?
3. Is that dust in the coating and should I be concerned?
AUSMHLY BJ8 Cylinder Head Installation Austin Healey 6
AUSMHLY BJ8 Cylinder Head Re-Torque Austin Healey 26
S Procedure for cylinder head removal and re-installation - BJ8 Austin Healey 11
D BJ8 brake master cylinder question Austin Healey 6
AUSMHLY BJ8 Rear Wheel Cylinder leaking Austin Healey 30
RickPA BJ8 rear wheel cylinder install Austin Healey 1
R BJ8 with Servo, Is the 7/8 Master Cylinder recommended ?? Austin Healey 7
L Initial Adjustment of Pushrod on BJ8 Brake Master Cylinder Austin Healey 5
letemglow Brake master cylinder BJ8 Austin Healey 0
Y BJ8 Clutch Master Cylinder Bleeding Procedure? Austin Healey 7
6 Wheel Cylinder Fluid leak on BJ8 Austin Healey 7
J For Sale FREE! 2 fiberglass aftermarket hardtops, supposedly big Healey but NOT BJ8 (close though) Austin Healey Classifieds 0
F BJ8 Exhaust Hanger Pictures Wanted Austin Healey 9
Patrick67BJ8 Custom BJ8 Dash Switch Panel Austin Healey 7
1 BJ8 History Trace Austin Healey 7
D BJ8 Top Installation Detail Austin Healey 3
S Wanted WTB: 3.5 ratio diff/pumkin for '67 BJ8 Healey 3000 Austin Healey Classifieds 0
AUSMHLY BJ8 Trans Cover Carpet Austin Healey 7
AUSMHLY BJ8 Carpet and Snaps Austin Healey 2
Overdrive45 BJ8 Interior Trim Austin Healey 8
nitro BJ8 Production Year Austin Healey 6
B BJ8 Seat Sliders Austin Healey 4
BoyRacer For Sale BJ8 disk wheel hubs, spindles & calipers Austin Healey Classifieds 0
S SOLD!! For Sale 1964 AH 3000 MkIII BJ8 Phase 1 Austin Healey Classifieds 2
Patrick67BJ8 BJ8 Factory Hardtop Rear Window Austin Healey 6
AUSMHLY BJ8 Clutch Pressure Plate, Old vs New Austin Healey 4
AUSMHLY BJ8 Clutch Fork Bush Replacement Austin Healey 5
LAW75 BJ8 Brake Lines Austin Healey 2
AUSMHLY BJ8 Clutch Pressure Plate Brand Preferences Austin Healey 3
BoyRacer For Sale BJ8 spindles & disc wheel hubs Austin Healey Classifieds 0
G Wanted BJ8 Tonneau Cover Austin Healey Classifieds 0
Cutrog1 For Sale Healey 3000 BJ8.... a restoration saga Austin Healey Classifieds 0
AUSMHLY BJ8 Overdrive Oil Passages Austin Healey 2
Scotsman Wiring Diagram for 1966 BJ8 Austin Healey 3
A For Sale 1966 3000 Healey Blue BJ8 Austin Healey Classifieds 3
B BJ8 Hood Bow and Seal Austin Healey 5
Mickey Richaud Wanted Wanted: BJ8 Seat Track Sets (Both Sides) Austin Healey Classifieds 5
Scotsman BJ8 Intake Manifold Differences Austin Healey 4
AUSMHLY Laygear End Float BN1-BJ8 Austin Healey 2
C For Sale BJ8 original dash Austin Healey Classifieds 3
