ARP big end bolts.
DavidApp
I have installed the ARP bolts on my engine and torqued them to the figures enclosed in the package. I did check the bolt length before I tightened then the stretch after torqueing.
I notice there does not seem to be any form of security. IE locking tabs, lock washers or nylock nuts. Am I missing something?
David
Sarastro
There's quite a bit of technology in designing threaded joints that stay put. I have no doubt that ARP understands all that stuff. If you do some research on the subject, I think you'll find that lock tabs are a bad idea, helical spring lock washers have minimal value, at best, and nylocs are good but probably can't take the temperature inside the engine.
It sounds to me like you've done everything right and according to the ARP instructions. Trust that, and don't worry.
DavidApp
Got it all together and mounted on a stand. Makes moving it around easier. I hope to set it up so I can start and run the engine before I install it in the car.
David
Did you have the big ends resized with the ARP bolts in place?
DavidApp
I must admit that I did not get the big ends resized after I installed the ARP bolts. I did see a You tube video that showed a very slight change in big end diameter when the ARP bolts were torqued down.
I used the stretch method of torqueing and had to go up 5 ft/lb to get the required stretch.
David
Platinum
When you set up a rig to run it, take torque into account!
I'll not go into the details, but an incident involving a 4.2L Jag engine once gave us a surprise... o_O
DavidApp
Thank you for the advice on that.
I would imagine there is a bit more torque from the 4.2L Jag engine. Did it involve a bit of revving it up?
David
K TR2/3/3A Memory refresh: non ARP cylinder head studs..... Triumph 2
KVH General Tech ARP Head Studs/Liner Protrusion Triumph 10
DrEntropy MGB And now, NO ARP head studs to be found! MG 13
RJS TR4/4A ARP Head Stud Question Triumph 2
G TR4/4A ARP Bolt Torque Specs Triumph 10
T TR4/4A Should I use ARP Assembly Lubricant for Engine Assembly and Fastener Installation? Triumph 2
T TR4/4A Are the ARP head studs worth it? [ducks for cover] Triumph 19
T TR2/3/3A ARP connecting rod bolts Triumph 2
RedTR3 TR2/3/3A Moss [ARP] Flywheel Bolts Triumph 16
F Using 12 point ARP style rod and main bolts Spridgets 9
R ARP head and connection rod studs? Spridgets 15
hondo402000 TR6 TR6, 71 model flywheel bolts, ARP Triumph 2
hondo402000 TR6 TR6 ARP head bolts Triumph 4
S I just bought ARP main stud kit 206-5405 Austin Healey 4
L ARP fastners. Spridgets 4
M ARP head studs Triumph 5
Basil ARP studs too short Triumph 18
DNK ARP Studs Triumph 74
Glen_B Torque for ARP mains Spridgets 1
hondo402000 TR6 ARP Head stud kit 71 TR6[ Where to buy] Triumph 10
G ARP Assembly Lubricant....how to use the stuff Triumph 9
martx-5 ARP Head Studs Triumph 21
Morris ARP studs torque and blown headgasket Spridgets 17
7 ARP bolt kits Triumph 2
Morris ARP Head studs torque... Spridgets 2
A ARP flywheel bolts--install Latest [no Loctite] Triumph 11
healeyboz ARP bolts Spridgets 6
healeyboz ARP bolts Spridgets 5
ChrisS ARP Rod Bolts Spridgets 7
ChrisS ARP Head Studs Racing 2
P TVR Big Valve 4.3 TVR 0
R Big Healey 100 Head Austin Healey 4
dougie Did Big Healey Drivers Go Soft? Austin Healey 8
B How big is the floor pan drain hole? Spridgets 0
AUSMHLY For Sale - 1990 Big Healey, 3000 MK3, HMC Mk4 Austin Healey 2
Lin Big Birthday, today! Austin Healey 12
R Wanted WTB Big Healey Austin Healey Classifieds 3
R Connecting Rod Big End Specification Austin Healey 4
S For Sale Big Barn Cleaning Triumph Classifieds 0
dougie Big Healey Six - Used the Right Way Austin Healey 5
aero3113 For Sale Big Healey Tube Shock Conversion Austin Healey Classifieds 2
dougie 1963 Sebring Big Healey 57 FAC Austin Healey 4
S TR2/3/3A The big brass drain plug on the OD does not thread in easily Triumph 9
B For Sale 1956 Austin Healey 100-4 SCCA big bore race car plus parts lot engine trans etc Austin Healey Classifieds 0
dougie Big Healey 6 Racer For Sale Austin Healey 2
K For Sale TR3 Cockpit Trim ...N/A at The Big 3 Triumph Classifieds 0
AngliaGT Big Healey Spotted 0
coldplugs Big Healey near Portland OR Spotted 3
D Two big Healeys Spotted 1
jfarris For Sale New TR3 Rod Bearings Big End Std Size Triumph Classifieds 0
