TR2/3/3A Anyone running NGK spark plugs?
karls59tr
Bronze
I installed a set of BPR6HS plugs (used to be BPR"5"HS that was recommended?) and now the car seems to idle and run a bit rougher than when I had the older BPR5HS plugs in. I had the old plugs gapped at .032 and it seemed to run smooth there. I'm going to put the older plugs back in to see if that makes a difference. If the gap is the issue the "6" NGK's have a recommended gap of .025.
What else should I check in regard to ignition? When I had the old plugs in they ran well with the newly installed points and condensor.
The 6 is a harder plug than the 5, that is it runs a bit colder and is marginally less tolerant of contamination, like oil.
Why did you change to 6?
I changed to 6 because that is what the NGK online site has listed. I wonder if the 6's are are the new uprated 5's??? I reinstalled the old (not really that old and a nice tan color) BPR5HS plugs and the motor ran smoother. Maybe i will try the 6's at .032 and see what happens?
No, the 6s are the 6s and the 5s are the 5s. They have slightly different specifications. All manufacturers have plugs with different heat ranges, you moved from one range to another.
If your engine runs rougher, it may be you have an occasional misfire. Might be plug gaps, you could try the 6s with a larger gap, but it might also be the heat range. How old is your engine, how many miles since a rebuild? Is it oily, blue smoke exhaust? Lots of questions, but if it were me I'd go back to the 5s.
The "5"s are hotter, which have a tendency to burn off deposits easier than colder plugs. If you are running rich, that may be why the engine is running smoother with the "5"s. I'd also put the gaps at 0.025", as that is the factory spec. It was initially 0.032", but it was changed early on due to mis-firing.
I went with the 6's because when because Jeff at Advance did my distributor I bought the Cap(side exit),wires,rotor ,points and plugs from him and Its what he recommended.
No problems .I change them every 5k or so and I usually keep the old ones for spares because the look like new.
Tom
I also have an Advance distributor and NGK have the "6"s listed as the plug to use for the TR3 on their website so I am wondering if the engine is running rich? Maybe I should lean out the carb mixture a bit?
I used the 6s in a 2ltr GT6 with no problems, don't know about the TR. The Jag shop I worked for used NGK for everything. My favorite is Champion, never had but one failure in 53 yrs. Had one separate the porclein from the metal on a V-12 Jag. Thought I dropped a valve, new plug andball was well.
I've been using Bosch Platinum plugs in the TR6 with no problems and burning the right color showing a correct mixture.
I did the same with my Spits and GT6. You will find that NGK plug cleanable after fouling and running bad fuel. Just about the only plug that is cleanable. I run Champion in everything else. Been with Champion since 1964 and ran NGKs for some 20 yrs in the Spits and GT6.
Oddly enough, the Porsche 912 takes the same size plug as the TR4. There is something of a consensus on Porsche boards that the NGKs are among the best plugs, but not agreement as to whether the 6s or 5s are better, if that makes you feel better about it. I think you just have to go with what works for you.
Karl What make & year is your car? NGK is the best plug and the iridium is the BEST of the best!
Len Fanelli
Abingdon Performance Ltd.
First have you double checked the float level &/16". What needles are in the carbs & what is your altitude above sea level?
The jets should be set .040" below the bridge, making sure that the choke returns to OFF with the jets firmly up to the adjusting nut. (Rock Auto ( Chicago) has the best NGK prices.
Remove the dashpots & piston ( chamber assembly) and with a dial vernier caliper measure the distance from the "Bridge" or venturi to the top of the jet, making sure that every time you release the choke that the jets return 100% off , jet firmly up against the adjusting nut EVERY time! With not even a .002" feeler gauge between the jet & nut.
Thanks for the info.(y)(y)
TR3sharon TR2/3/3A Anyone running tubeless radials on TR3 steel radials? Triumph 2
Got_All_4 General TR Anyone running superpro bushings? Triumph 3
K TR2/3/3A Anyone running a cold air duct to the carbs? Triumph 15
K TR2/3/3A Anyone running an Oil Temp sensor on their TR3/4? Triumph 11
RickB Anyone running with 14's or 15's on a Spridget? Spridgets 21
G Q for anyone running an aluminium flywheel Triumph 10
G TR6 Anyone running a megasquirt on their TR6? Triumph 2
G TR6 Anyone running triple ZS on a TR6? Triumph 6
martx-5 TR2/3/3A Anyone running 6" wires on TR3?? Triumph 15
6 Piper Cams: anyone running one? MG 18
G Anyone running new ANSA System? Triumph 2
Basil Anyone remember Dave Russell? Austin Healey 10
AngliaGT 1997 Miata - Anyone Have a Picture on How to Mount the Front License Plate Bracket? Other Cars 12
AngliaGT Anyone Plan on Attending the SCCA Runoffs at VIR Next Week? Racing 6
R TR2/3/3A Does anyone know the paint Code for british Racing Green for a 1954 TR-2? Triumph 12
Celtic 77 Anyone recall Hobo Hill in New York State? Racing 0
T Rut's 4 speed shifter modification - anyone have knowledge? Spridgets 3
JPSmit Gear reduction starters anyone? Restoration & Tools 5
L Can anyone tell me what car this is from please? Other Cars 0
DrEntropy Show this to anyone under 40... Restoration & Tools 9
K TR2/3/3A Can anyone confirm that if you replace the ammeter with a voltmeter ( generator removed and alternator added) that you...... Triumph 5
D Can anyone identify this vintage car? Other British Cars 17
T Can anyone identify this bumper Spridgets 5
AngliaGT Morgans - Anyone Heard From John Sheally lately? Other British Cars 13
johntennyson Anyone Know These Guys? Or Remember Sprite-Midget Owners' Group? Spridgets 29
K TR2/3/3A Anyone remember the "rattling gear shift" fix? Triumph 8
roscoe Comments, anyone? Austin Healey 3
BillyB62 TR2/3/3A Anyone seen a valve cover like this Triumph 0
T TR2/3/3A Has anyone designed a hand brake warning light for the TR3? Triumph 3
Pythias Sprite Winged Bonnet Badge.... ANYONE? Spridgets 16
B Anyone have a Europa Twin Cam for sale? Lotus 6
B Anyone have spark advance data for Piper camshafts? Spridgets 1
Got_All_4 TR5/TR250 New Hazard Relays Does Anyone know How to Hook Up Triumph 7
steveg TR6 Metal Dash - does anyone make one? Triumph 13
T Powertrain locked up three times whilst driving today - anyone have thoughts? Spridgets 15
S TR2/3/3A Anyone care to share their bondo applying techniques Triumph 35
DrEntropy MGB Clevis pins, anyone? MG 3
69MGC Wanted Anyone know this guy? MG Classifieds 2
B Does anyone still make or sell a quality condenser? Austin Healey 14
W TR6 Anyone add Exhaust tips to standard exhaust Triumph 4
K TR2/3/3A Anyone have a picture of the crankshaft pulley.... Triumph 1
K Anyone racing a TR3? Racing 5
S General TR Can Anyone identify this TR Triumph 3
C Anyone know where to get one of these? Austin Healey 6
Grantura_MKI T-Series MG TD anyone? MG 5
HealeyRick Why Would Anyone Butcher a Healey with a V8? Austin Healey 26
K TR2/3/3A Anyone heard of an oil additive called 'Molyslip E" ? Triumph 5
Basil SS100 anyone? Jaguar 5
