TR2/3/3A Anyone heard of an oil additive called 'Molyslip E" ?
Sarastro
My suggestion: use good-quality oil and don't mess with additives. They're not likely to help, and some have been known to cause engine damage.
That said, MoS is a common component of greases and oils. If your oil needs it, it's probably there already.
TR3driver
Great Pumpkin - R.I.P
I've heard of it, never tried it. Thought they took it off the market after all the complaints about blocked oil filters and such.
Moly is a solid. In theory, the oil additives have particles of moly that are tiny enough to pass through oil filters. The problem is that, in the real world, filters will stop a small percentage of particles much smaller than they are rated for (kind of like TR3 air filters will get dirty with dust that would easily pass through the coarse wire mesh). In a recirculating system like an oil sump, each pass may only trap 0.01% of the smaller particles, but after a few thousand passes, most of it will be in the filter. Once the filter gets loaded up, the bypass valve opens, and most people don't know the difference. But some people notice things like that, and complained.
This is fairly typical of the stories I've heard. Of course, you can't believe everything you read on the Internet, but I've just never been interested in taking the chance.
https://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=285055
CJD
GM sells it as a camshaft lubricant for engine rebuilds. Not so much an oil additive, but rather gives the cam lobes a fighting chance until the engine is running fast enough to splash oil onto it.
TR3driver
CJD
It’s a molydisilfide pasty stuff. Other than that I know nothing about it.
SCguy Has anyone ever heard of Accel Oil? Triumph 0
AngliaGT Morgans - Anyone Heard From John Sheally lately? Other British Cars 13
John Turney Anyone heard of an Innocenti Sprite? Spridgets 17
K Anyone heard of an 83mm "steel headgasket or were Triumph 6
S Has anyone ever seen or heard of this? Austin Healey 9
Brosky Anyone heard from Bill about engine issues? Triumph 7
timbn2 anyone ever heard of "Limora.com" ? Austin Healey 2
1 Has anyone ever heard this tip? "Weeping" head MG 11
H anyone heard of this noise? Austin Healey 2
Webb Sledge Paeco Tuning? Anyone heard of them? Triumph 3
Basil Anyone remember Dave Russell? Austin Healey 10
AngliaGT 1997 Miata - Anyone Have a Picture on How to Mount the Front License Plate Bracket? Other Cars 12
AngliaGT Anyone Plan on Attending the SCCA Runoffs at VIR Next Week? Racing 6
R TR2/3/3A Does anyone know the paint Code for british Racing Green for a 1954 TR-2? Triumph 12
Celtic 77 Anyone recall Hobo Hill in New York State? Racing 0
T Rut's 4 speed shifter modification - anyone have knowledge? Spridgets 3
JPSmit Gear reduction starters anyone? Restoration & Tools 5
L Can anyone tell me what car this is from please? Other Cars 0
DrEntropy Show this to anyone under 40... Restoration & Tools 9
K TR2/3/3A Can anyone confirm that if you replace the ammeter with a voltmeter ( generator removed and alternator added) that you...... Triumph 5
D Can anyone identify this vintage car? Other British Cars 17
T Can anyone identify this bumper Spridgets 5
johntennyson Anyone Know These Guys? Or Remember Sprite-Midget Owners' Group? Spridgets 29
K TR2/3/3A Anyone remember the "rattling gear shift" fix? Triumph 8
roscoe Comments, anyone? Austin Healey 3
BillyB62 TR2/3/3A Anyone seen a valve cover like this Triumph 0
T TR2/3/3A Has anyone designed a hand brake warning light for the TR3? Triumph 3
Pythias Sprite Winged Bonnet Badge.... ANYONE? Spridgets 16
B Anyone have a Europa Twin Cam for sale? Lotus 6
B Anyone have spark advance data for Piper camshafts? Spridgets 1
Got_All_4 TR5/TR250 New Hazard Relays Does Anyone know How to Hook Up Triumph 7
steveg TR6 Metal Dash - does anyone make one? Triumph 13
T Powertrain locked up three times whilst driving today - anyone have thoughts? Spridgets 15
S TR2/3/3A Anyone care to share their bondo applying techniques Triumph 35
DrEntropy MGB Clevis pins, anyone? MG 3
69MGC Wanted Anyone know this guy? MG Classifieds 2
B Does anyone still make or sell a quality condenser? Austin Healey 14
W TR6 Anyone add Exhaust tips to standard exhaust Triumph 4
K TR2/3/3A Anyone have a picture of the crankshaft pulley.... Triumph 1
K Anyone racing a TR3? Racing 5
S General TR Can Anyone identify this TR Triumph 3
C Anyone know where to get one of these? Austin Healey 6
Grantura_MKI T-Series MG TD anyone? MG 5
HealeyRick Why Would Anyone Butcher a Healey with a V8? Austin Healey 26
K TR2/3/3A Anyone running NGK spark plugs? Triumph 26
Basil SS100 anyone? Jaguar 5
Jim_Gruber Recovering Dashboard - Anyone tried this approach? Spridgets 4
T TR2/3/3A Anyone running tubeless radials on TR3 steel radials? Triumph 2
