TR4/4A Anyone know a source for TR4-6 outer sills that actually fit?
britlover
I purchased a pair of outer sill sheet metal from the Roadster Factory that are horrendously bad reproductions. They bear some resemblance to the actual sills, but don't fit AT ALL. Anyone know a place that sells/ manufactures good replacements? I know good ones won't come cheap if they are indeed out there, but in the long run I'm not sure I can make these fit... Any help would be appreciated!
DNK
Not heard that they were a problem.
Must be a new thing
DNK
If they were both Heritage then they probably came from the same source
justin_mercier
I had a pair from rimmer bros that were excellent. There are no British motor heritage sills from what I understand. rimmer had 2 different sills available, their more expensive better fit ones (which I had bought) and the lesser expensive much poorer fit ones.
britlover
britlover
The ones I have are definitely not Heritage, nor do they have the stickers. They appear to be made on one-sided stamping tools. Thank you guys for the responses, I'll look into Rimmer Bros in the UK, and maybe Victoria British. TRF did warn that Heritage sills were not available, and that they weren't the best quality...
DNK
I guess the ones that went with my car were worth some money then.
They were Heritage
HerronScott
So these are the cheaper REP850281 T46 OUTER SILL, LH Outer Sill, less expensive replacement ($79.95 list) versus the 850281 T46 LH SILL,OUTER,STEEL Outer Sill Panel, L.H. ($154.95 list)?
Did they say if they were expecting more of the Heritage parts in the future?
Scott
britlover
britlover
Scott
Not sure, but their website only lists the $154.95 ones PN 850281. I bought them a couple of years ago, and I'm just getting around to fitting one of them. I'd much rather start with some that fit.
HerronScott
I found the other part number in their parts database and although it's an older catalog, this shows both versions with the descriptions.
https://trf.zeni.net/summerlong/70.php
I'd really guess that you have the REP850281 part but I'd give them a call and see if you have any options to exchange them. They should be able to pull up your order and see which you purchased.
Scott
TR4eh
When I did this replacement work I first ordered the replacement sills from Rimmer, and the fit was quite poor. Not wanting to reform the curves I bought the "original" parts and they fit much better. Judging only from the pictures on Rimmer's website, I don't think the two panels have changed much. In my opinion the better fit was worth the extra cost.
justin_mercier
from what I understand, and was told by a restoration guy at one of the british car shows nearby, there will be no more Heritage sills for 4-6 because the dies became too worn out to stamp accurate parts, and that the best fitting ones now are not actually Heritage parts, but quality (and more expensive) repros. The best source I know is the more expensive (2x as much) ones from rimmer.
britlover
britlover
Been a while since I first posted this, getting back into the project again... I notified TRF, and was told that they have had no complaints. The part number (850281) coincides with the "original" spec sills from Rimmer brothers, but according to the pictures they look different. The fit issue is essentially a huge gap under the door (they won't go any higher, up hard against the A and B post feet) and the curvature at the fenders isn't quite right either, especially at the rear. The TRF sill endcaps don't fit either -- not even close. I suppose I'll order from Rimmer and send these back.
bighealeysource Anyone know of a source for correct size "M" for 100M models ? Austin Healey 0
E Can anyone suggest a source to id Hella relays? Jaguar 1
Basil Anyone remember Dave Russell? Austin Healey 10
AngliaGT 1997 Miata - Anyone Have a Picture on How to Mount the Front License Plate Bracket? Other Cars 12
AngliaGT Anyone Plan on Attending the SCCA Runoffs at VIR Next Week? Racing 6
R TR2/3/3A Does anyone know the paint Code for british Racing Green for a 1954 TR-2? Triumph 12
Celtic 77 Anyone recall Hobo Hill in New York State? Racing 0
T Rut's 4 speed shifter modification - anyone have knowledge? Spridgets 3
JPSmit Gear reduction starters anyone? Restoration & Tools 5
L Can anyone tell me what car this is from please? Other Cars 0
DrEntropy Show this to anyone under 40... Restoration & Tools 9
K TR2/3/3A Can anyone confirm that if you replace the ammeter with a voltmeter ( generator removed and alternator added) that you...... Triumph 5
D Can anyone identify this vintage car? Other British Cars 17
T Can anyone identify this bumper Spridgets 5
AngliaGT Morgans - Anyone Heard From John Sheally lately? Other British Cars 13
johntennyson Anyone Know These Guys? Or Remember Sprite-Midget Owners' Group? Spridgets 29
K TR2/3/3A Anyone remember the "rattling gear shift" fix? Triumph 8
roscoe Comments, anyone? Austin Healey 3
BillyB62 TR2/3/3A Anyone seen a valve cover like this Triumph 0
T TR2/3/3A Has anyone designed a hand brake warning light for the TR3? Triumph 3
Pythias Sprite Winged Bonnet Badge.... ANYONE? Spridgets 16
B Anyone have a Europa Twin Cam for sale? Lotus 6
B Anyone have spark advance data for Piper camshafts? Spridgets 1
Got_All_4 TR5/TR250 New Hazard Relays Does Anyone know How to Hook Up Triumph 7
steveg TR6 Metal Dash - does anyone make one? Triumph 13
T Powertrain locked up three times whilst driving today - anyone have thoughts? Spridgets 15
S TR2/3/3A Anyone care to share their bondo applying techniques Triumph 35
DrEntropy MGB Clevis pins, anyone? MG 3
69MGC Wanted Anyone know this guy? MG Classifieds 2
B Does anyone still make or sell a quality condenser? Austin Healey 14
W TR6 Anyone add Exhaust tips to standard exhaust Triumph 4
K TR2/3/3A Anyone have a picture of the crankshaft pulley.... Triumph 1
K Anyone racing a TR3? Racing 5
S General TR Can Anyone identify this TR Triumph 3
C Anyone know where to get one of these? Austin Healey 6
Grantura_MKI T-Series MG TD anyone? MG 5
HealeyRick Why Would Anyone Butcher a Healey with a V8? Austin Healey 26
K TR2/3/3A Anyone running NGK spark plugs? Triumph 26
K TR2/3/3A Anyone heard of an oil additive called 'Molyslip E" ? Triumph 5
Basil SS100 anyone? Jaguar 5
Jim_Gruber Recovering Dashboard - Anyone tried this approach? Spridgets 4
T TR2/3/3A Anyone running tubeless radials on TR3 steel radials? Triumph 2
R General TR Anyone going to TRA in North Georgia? Triumph 0
R Wanted Anyone have one of these? Triumph Classifieds 6
mt10flyer TR2/3/3A Anyone race prepped a TR3? Triumph 3
Rut TR4/4A Sorry Top anyone? Triumph 0
Got_All_4 General TR Anyone know where to get one of these? Triumph 5
AngliaGT Anyone in Charlotte,NC That Could Check Out a Truck for Me? Other Cars 0
