TR2/3/3A Anyone care to share their bondo applying techniques
glemon
Will second the long strand stuff over a weld or repair, also make sure it is the kind that won't absorb moisture, I used that followed by the fine top coat stuff over for a smooth, feathered finish.
I also still use old fashioned Nitro Stan red putty for pinholes or fine sanding scratches, but not for any larger surface imperfections, it is quick and easy to use.
mctriumph
Glemon , The old putty is NOT a good thing, it will absorb thinner and will indeed never actually
dry completely.It shrinks slowly over the years revealing the flaws. I have not used such a product
since the mid 90's...
Mad dog
Platinum
Anybody use U-pol's "Dolphin Glaze" for spot putty? I love the stuff. We called it porpoise poop.
mezy
Used this a lot in the body shops, great stuff, you could finish shaping with 80 grit, then a thin coat of dolphin
to fill the scratches, sand well will 240 grit. the prep boys loved it when they got a repair finished in 240, it was straight on with the primer.
mctriumph
My trick is using a little fiberglass resin to thin the filler , to the point it is a glaze.
Not to say we had no glaze, just that its pricey and fussy when it sets too long.
Mad dog
HealeyRick
Don't do this. This is an image from a car that came from a highly respected MGB shop in the UK. Filler is meant to be a skim coat, not a medium to display your sculpting skills. Shiny paint hides a lot of stuff like this until it starts cracking. Like the "Secret Agent" song by Johnny Rivers said, "Beware of pretty faces that you find. A pretty face can hide an evil mind."
bobhustead
Dolphin Glaze is the nectar of the gods for thin skims, spots and pinholes. Dunno what part of technique you ask about, but early in the bondo cure process, I use a hacksaw blade with one edge sanded off, so it looks a bit like a knife edge with teeth on one side, to conform the shape to the surrounding metal.
Bob
Jerry
Slightly off topic but I started working on my 64 BJ 8 project. The frame and substructure was dipped to remove all paint. Great job but the phosphate residue left from the anti rust dip is a little rough. What do you guys do prior to primer?
mctriumph
Jerry, the real question how do you treat the inner boxes of the unibody???
I dont know what sticks to this residue. I would think pumping an acid wash primer
into the spaces as if it was wax all might work. IMHO it is a serious concern that I dont
know the best answer for.
Mad dog
Jerry
I sanded the whole frame and substructure during the last two days. It was a very thin coat of something but it is now smooth. It did not come off with water or paint thinner. I will spray my 2k primer and see what happens
mctriumph
I once had a BJ8 hood that had been acid dipped. The spot welds were broken/cracked
so I removed the front and rear braces to complete repairs. What was inside there was a horror.
Acid residue/gunk/rust. It required a lot of work to make them"right" to reinstall.
What I am saying is how the devil do you clean out the frame boxes at this point??
There is no access to these critical bits.
Mad dog
Jerry
I am now wondering if this frame was dipped. I found some paint residue in some tight spots and maybe someone used an industrial stripper part by part. I will probably use something like waxoyl inside the frame once I get done painting.
mctriumph
Jerry spray the boxes with a rust neutralizer ,later spray with waxoyl or the equivalent.
Then pray . The chassis on Big healey was only just good enough when new.
After the motor is running, drive it around the block before final wing alignment ......
Mad dog
Jerry
My 67 Bj8 has a Jule frame. This frame on the 64 is excellent, no dent, no bends. And the frame measurements are correct. Inside preventative is a good idea
VeeCee
When I apply putty, I find that I only get about one pass with the spreader before I run into problems with build up. If I try a second pass with the same spreader, the film and build up left on the spreader from the first pass bunches up the putty and makes the first spread worse.
What I do is use a second or third or fourth spreader if I make a more passes to smooth down the putty more. Do people wipe the spreader with a rag each time or something? I thought maybe a rag with a little bit of lacquer thinner might be ok to get the film off in-between wipes because that evaporates so quickly. Anyways always up for new ideas.
steve
Add Fiberglass resin to the Bondo. Measure out 10% of whatever size can your using. No more that 20% ( 20% is good for horizontal surfaces, self leveling) 10% for vertical maybe a touch more. Then add hardener before applying. (Don’t just dump the resin in). The filler will spread so
Much more smoothly and almost no air bubbles.
G Anyone care to take a bet? Spridgets 5
Basil Anyone remember Dave Russell? Austin Healey 10
AngliaGT 1997 Miata - Anyone Have a Picture on How to Mount the Front License Plate Bracket? Other Cars 12
AngliaGT Anyone Plan on Attending the SCCA Runoffs at VIR Next Week? Racing 6
R TR2/3/3A Does anyone know the paint Code for british Racing Green for a 1954 TR-2? Triumph 12
Celtic 77 Anyone recall Hobo Hill in New York State? Racing 0
T Rut's 4 speed shifter modification - anyone have knowledge? Spridgets 3
JPSmit Gear reduction starters anyone? Restoration & Tools 5
L Can anyone tell me what car this is from please? Other Cars 0
DrEntropy Show this to anyone under 40... Restoration & Tools 9
K TR2/3/3A Can anyone confirm that if you replace the ammeter with a voltmeter ( generator removed and alternator added) that you...... Triumph 5
D Can anyone identify this vintage car? Other British Cars 17
T Can anyone identify this bumper Spridgets 5
AngliaGT Morgans - Anyone Heard From John Sheally lately? Other British Cars 13
johntennyson Anyone Know These Guys? Or Remember Sprite-Midget Owners' Group? Spridgets 29
K TR2/3/3A Anyone remember the "rattling gear shift" fix? Triumph 8
roscoe Comments, anyone? Austin Healey 3
BillyB62 TR2/3/3A Anyone seen a valve cover like this Triumph 0
T TR2/3/3A Has anyone designed a hand brake warning light for the TR3? Triumph 3
Pythias Sprite Winged Bonnet Badge.... ANYONE? Spridgets 16
B Anyone have a Europa Twin Cam for sale? Lotus 6
B Anyone have spark advance data for Piper camshafts? Spridgets 1
Got_All_4 TR5/TR250 New Hazard Relays Does Anyone know How to Hook Up Triumph 7
steveg TR6 Metal Dash - does anyone make one? Triumph 13
T Powertrain locked up three times whilst driving today - anyone have thoughts? Spridgets 15
DrEntropy MGB Clevis pins, anyone? MG 3
69MGC Wanted Anyone know this guy? MG Classifieds 2
B Does anyone still make or sell a quality condenser? Austin Healey 14
W TR6 Anyone add Exhaust tips to standard exhaust Triumph 4
K TR2/3/3A Anyone have a picture of the crankshaft pulley.... Triumph 1
K Anyone racing a TR3? Racing 5
S General TR Can Anyone identify this TR Triumph 3
C Anyone know where to get one of these? Austin Healey 6
Grantura_MKI T-Series MG TD anyone? MG 5
HealeyRick Why Would Anyone Butcher a Healey with a V8? Austin Healey 26
K TR2/3/3A Anyone running NGK spark plugs? Triumph 26
K TR2/3/3A Anyone heard of an oil additive called 'Molyslip E" ? Triumph 5
Basil SS100 anyone? Jaguar 5
Jim_Gruber Recovering Dashboard - Anyone tried this approach? Spridgets 4
T TR2/3/3A Anyone running tubeless radials on TR3 steel radials? Triumph 2
R General TR Anyone going to TRA in North Georgia? Triumph 0
R Wanted Anyone have one of these? Triumph Classifieds 6
mt10flyer TR2/3/3A Anyone race prepped a TR3? Triumph 3
Rut TR4/4A Sorry Top anyone? Triumph 0
Got_All_4 General TR Anyone know where to get one of these? Triumph 5
AngliaGT Anyone in Charlotte,NC That Could Check Out a Truck for Me? Other Cars 0
Gliderman8 TR2/3/3A A nice ORIGINAL TR3A resto project if anyone is looking Triumph 3
Got_All_4 TR2/3/3A Has anyone installed one of these slack limiting plates Triumph 4
