A fan of 2500M's!!!
ralph_s
A bit of irony regarding my cooling saga. Started last year w/ all new hoses and a re-cored radiator & a threaded temp switch. This spring it was time to figure out the auxilary fan. The Smiths fan was disconnected at the Lucas relay, so after a bit of wire investigation I reconnected the fan to the relay and wired in an override switch for the fan. This helped to improve my confidence level by knowing I could turn the fan on at will!! Everything worked as designed, which is no small feat!! Went to several shows w/ the car and enjoyed my new found success until the Lucas relay gave up. Not being a purist, I replaced w/ a solid state relay from NAPA for $10.00 and replaced the theromstat w/ a 165 deg hiflow unit. Again all was well until the Smiths fan died....should have guessed all this stuff was diconnected for a reason. Replaced the fan with a 7.5" from the Fan Man (very reasonable price). Made some custom brackets to mount the fan and was back in business. Did a tune up and adjusted the timing which was severely advanced, set the ZS carbs which were very lean and viola the car runs considerably cooler, smoother and purrs at 850 rpm.
So, I'm off this weekend to the British Invade Gettysburg w/ my new found success and enjoying my TVR more w/ each passing week.
mrtvr
Ralph,
Glad you are enjoying your 2500M more and more with each passing week. Enjoy the Gettysburg show and be sure to "fly the TVR colors" and help more people learn what a TVR is as it is still a relatively unknown British marque. If everyone with a TVR would get their cars out there among the masses on a regular basis, the TVR name would become more recognizable.
Marshall
TRclassic3
Ralph
I just picked up a 77 2500M a couple of weeks ago. I plan on driving to Gettysburg Sunday. Hope to see you there.
R
ralph_s
Ed,
Excellent, I plan to be there by 9AM. See you then.....we'll look like bookends!!!!!!
mctriumph TR2/3/3A Ultimate fan conversion Triumph 10
F Revotec Fan Austin Healey 2
S Installing a Radiator Fan Austin Healey 9
K TR2/3/3A " do not remove the fan as it is essential for establishing crankshaft balance" Triumph 9
jfarris For Sale TR3 Stock Fan used (1956) Triumph Classifieds 0
jfarris For Sale TR6 Yellow Fan - new Triumph Classifieds 0
tr6nitjulius General TR Fan Belt Replacement '72 TR6 Triumph 1
RJS TR4/4A Radiator Fan Shround Triumph 3
KVH General Tech Fan Not Backward — Balancers Triumph 5
A Spitfire Install fan Triumph 1
J TR6 TR6 Hayden Pusher Fan Wiring Triumph 2
O XKE series 2 thermo fan switch bung stud repair. Jaguar 9
R For Sale TR6 COOLING FAN / ADAPTERS Triumph Classifieds 0
R Cooling Fan Color Austin Healey 6
S TR2/3/3A What temperature of electric fan switch do you use in your radiator? Triumph 3
R Spitfire Electric Fan Triumph 2
R six bladed fan - bugeye Spridgets 2
Dnickels Spitfire Generator fan rubbing/scraping Triumph 3
G TR4/4A Radiator Fan and plates spanning bolts Triumph 6
Lin Fan belt for 1275 with alternator Spridgets 4
Tr3aguy TR2/3/3A Tropical Fan Triumph 19
G Thermo Fan Sensor Austin Healey 5
R TR6 fan shroud replacement Triumph 5
J BJ8 Radiator Fan Austin Healey 12
6TTR3A Wanted GT6 MK one engine fan Triumph Classifieds 0
longbridgehealey Electric Fan vs. Texas Cooler Austin Healey 21
C Wanted WANTED Heater fan motor and housing for 1964 MK3 Sprite Spridgets Classified 2
D Spitfire Electric fan Triumph 3
Zitch For Sale 8 Blade yellow Fan for triumph Triumph Classifieds 2
HealeyPassion Aftermarket heater/defroster with 3 speed fan Austin Healey 15
M TR6 Rimmer Bros. Electric Fan Conversion Triumph 0
M TR6 Dowel Pins, Pulley Adaptor, Revotec Electric Fan Kit Triumph 1
thibault 6 Blade cooling fan for 64 BJ8, advice? Austin Healey 25
T BJ8 Fan Belt Change Austin Healey 7
B Wanted FOUND. TR10 Fan mount Bushings Triumph Classifieds 3
S Heater and fan control replacement - any advice? Austin Healey 9
B Fan Blade Failure Austin Healey 6
D Fan Blade Austin Healey 11
B Revotec fan kit Austin Healey 4
B TR6 TR6 Fan Belt Triumph 4
K TR2/3/3A Volvo 122 radiator fan on a TR3? Triumph 3
S Fan blade bolts - torque setting and thread-locker? Austin Healey 4
FlyingCat Spitfire Electric Radiator Fan Triumph 10
N Bumper bracket and fan shroud color Austin Healey 5
FlyingCat Spitfire Radiator and fan Triumph 5
Alfred E. Neuman TR4/4A TR4 fan extension and crank bolt length Triumph 9
TomMull TR2/3/3A Tropical fan, I wonder what I bought?? Triumph 2
J TR4/4A Water temperature and electric fan in a TR4 Triumph 5
I Correct orientation of the fan blades. Austin Healey 13
TomMull Wanted Tropical fan for TR3 Triumph Classifieds 8
