79 Midget 1500 overheating
George P
My 79 Midget 1500 is overheating to the point where the temp went above 100c
I had a 85c stat fitted so I removed it and ran the car without a stat fitted. Temp dropped to around 60c
I then fitted a 76c stat and went for a run today. After about 1/2 mile the temperature rocketed to above 100c but the engine did not seem to be boiling. After a further mile the temp then dropped to about 80-90c At that point I got home and garaged the car.
Before all of this I bled the whole system, I'm sure there must be air locks in there somewhere but I'm dammed if I can clear them.
I disconnected the header tank and raised the pipe higher than the engine fill point then I added water. The heater is disconnected and bypassed, whether that has something to do with the problem I'm not sure.
There doesn't seem to be any leaks around the head!!
If I remove the expansion tank cap several hours after the engine has gone cold I can feel that the system is still under pressure.
All hoses have been changed for new ones and a new stat is fitted 76c and a new expansion tank cap.
Some time back I fitted a pressure tester to the expansion tank and raised the pressure to 15psi. It held steady.
This issue has plagued me for a long time now. I'm worried I may have done some damage so how can I check the block ?
Clearly I'm missing something.
Help me, where do I start.
Thanks
George, these little critters can be very annoying - especially around heating/cooling. I have never used the expansion tank for the operations you are describing - instead I use the big brass nut with the slot on the top of the rad. This is higher than the tank and this is where I burp it. Full disclosue I had my rad rebuilt and my engine block boiled when I was restoring the car but have not had heating issues. The different times I have had the rad out and refilled it, I have filled the rad through the brass nut hole and then burped the system by squeezing the hoses with the engine running. As a sidebar more than once with my car I have come out of a building or store (ie to a car with a hot engine) to find that it had burped rad fluid on the ground - I'm still not completely sure where that came from.
good luck and sounds like we are getting there!
Thanks JP, well this morning I bit the bullet. Rad out, water pump off and a new one ordered. I noticed again water on the garage floor at the front of the car. I'm pretty sure now the pump has been leaking for some time. I have tried 2 thermostats, filled the system countless times and still get heating issues, The frequency of adding water should have told me it was leaking from somewhere so I decided to replace the pump. I'll let you know how it goes.
L Little1's 75 Midget 1500 Thread Spridgets 14
L Midget 1500 Zenith Air Filter Element: Is it a Unicorn? Spridgets 7
dwpirkeyjr Red? Bue? Purple? Yellow? Poly Bushings Complete Set For 1979 MG midget 1500 Spridgets 7
M 1500 Midget water pump weep hole Spridgets 2
M 1977 MG Midget 1500 Problem Spridgets 8
M Midget 1500 1977 Smog pump/Air Injection Pipe Spridgets 0
T MG Midget 1500 crank shaft pulley Spridgets 0
M Wanted Midget 1500 exhaust manifold MG Classifieds 0
G General MG Leaking Fuel on twin HS4's 1500 MG Midget MG 5
B COMPLETE DROP-IN Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans NEVER INSTALLED Spridgets Classified 2
A 76 Midget 1500 Oil filter Spridgets 6
M Wanted Twin carb manifold for 1500 Midget or spitfire Spridgets Classified 3
Steve P. 1500 radiator in an earlier 1275 cross flow Midget? Spridgets 2
aseriesspares Spitfire What Gearbox are you using. Spitfire / Midget 1500 Triumph 2
aseriesspares What Gearbox are you using. Midget 1500 Spridgets 5
T Putting a Spitfire 1500 into a 1972 Midget Spridgets 6
DanLewis 1500 cc MG Midget Radiator in a Bugeye??? Spridgets 5
J 1500 mg midget fuel issue Spridgets 2
J 1500 midget master cylinder Spridgets 10
T ZS Question for 76 1500 midget Spridgets 33
T 76 midget 1500 oil pressure lines? Spridgets 15
frankenstang57 Educate me on the Midget 1500 MG 4
R Overdrive/5 speed options for 1500 Midget? Spridgets 21
P how to replace rear main seal in 1500 midget Spridgets 2
R pcv valve for 1500 midget? Spridgets 18
R spark plug for a 9:1 ratio 1500 midget? Spridgets 5
T 76 midget 1500 engine crud Spridgets 4
R looking for1500 midget therm housing[MOSS 63-370]? Spridgets 1
RickB Seat recovering, 1500 Midget Spridgets 18
R 1500 midget clutch inspection? Spridgets 3
R oil feed kit for 1500 midget? negatives in this? Spridgets 5
Rhodyspit75 Spitfire Midget carbs and manifold on 1500 Spit Triumph 6
D Vacuum unit for 1500 Midget Spridgets 7
P holes in 76 midget 1500 front bumper Spridgets 6
R compression test procedure on 1500 midget Spridgets 5
G 79 midget 1500 clutch? Spridgets 5
A MIDGET 76 1500 CLUTCH SLAVE CYLINDER Spridgets 1
bcbug Midget 1500 Hose Connections Spridgets 9
RickB Midget 1500 dual circuit Master Cylinder troubles Spridgets 7
7 79 midget 1500 Emission Removal Spridgets 3
G 79 mg midget 1500 wiring Spridgets 7
bcbug 1500 midget carb replacement Spridgets 38
A 1300 cam bearings in Midget 1500 Spridgets 3
M 78 1500 Midget Tire Sizes Spridgets 1
J Midget 1500 electronic ignition? Spridgets 10
S 1500 Midget air intake Spridgets 1
S 77 Midget 1500 gearbox Spridgets 4
boxfullofyertoys Midget 1500 idle problem MG 0
boxfullofyertoys Midget 1500 idle problem Spridgets 10
tony barnhill Patriot 1500 Midget Headers Spridgets 3
