TR4/4A Tackling the biggest problem with my TR4A.... Frame Damage :[
Djoslyn
IMHO...the chassis will flex were circled.
I would make the green lines in one continuous plate...65mm x8mm.
I've come across your frame modification post many times :smile:. I hadn't planned on going as thick as 8mm but definitely thicker than the existing metal that the frame came with. I've also considered adding some sort of gusseting external to where the trailing arms would mount and the rear frame rails since my car is not a IRS car.
Djoslyn
Managed to remove a lower control arm mount that had been poorly repaired. Replaced a piece of the frame underneath it that was dented and thinned out from the previous repair.
RGK
I had my 4A's frame bent accidently. Wish I had kept the right side headlamp, it was a true survivor.
Djoslyn
It's been a little over a week since all this was done but I managed to get a ton done.
The frame has been sand blasted! Thankfully no new surprises were found after the thorough cleaning....
I've also cut out all the reinforcement pieces I plan on adding onto the frame and started welding them in place.
Djoslyn
Some more progress with a vacation in Jamaica in between :D
I decided to finally tackle a long needed item on my list of things to fix. My crank pulley now has Timing marks! :smile: The woodruff key was pretty worn as well so I replaced it while was at it.
As far as the frame goes, I've treated it with eastwoods AfterBlast prep to protect it while i'm finishing up the modifications to it.
I've also welded all the lower control arm mount reinforcements into place and drilled the extra holes in them to accept the upgraded pivots.
Today I managed to box in the cross brace that the lever shocks mount to and finalize the shapes of the braces I'm adding to the front spring/shock towers.
The only bit of fabrication left to do is to add the upper bump stop mount at the top of the drive shaft tunnel. Since this frame is from a IRS car it didn't come with that bit...
Lots of welding to finish up too....
malbaby
Dane....you have done a very nice job in restoring and strengthening the chassis and still retain the original factory look.
Please pardon my following comments..;).....I notice that you have welded in seperate plates rather than one continuous strong inner strengthening plate through the cruciform area.
IMHO, the chassis will still flex and twist to some extent as the originals did. The fact that yours is not an IRS car puts additional stress on the cruciform area as the back of he chassis is loaded/unloaded via the rear leaf spring mounts.
Djoslyn
You are correct. They are separate plates. I know this wasn't the strongest way to go. My intent is to reinforce the frame just a bit more especially due to the extent of the repairs in that area. I've also added some fish plates at some of the areas of repairs.
I agree there is definitely more I could do to help this frame out with the flexing and twisting but I think I'm happy with where it is at currently for the scope of this project. And I will say, I really do appreciate all of your input that you've given to me throughout this. :smile:
tony barnhill Tackling My '85 XJ6 Again Jaguar 18
R6MGS MGB Biggest 15 inch tire for 80 MGB MG 9
mylillooker The Biggest Battery in the WORLD Spridgets 4
M biggest forum MG 6
T TR4/4A TR4 seat buffer problem Triumph 5
Carlbanan56 MGB High rpm problem MG 27
Sarastro TR4/4A Convertible top installation problem Triumph 12
J TR4/4A Strange Problem Fitting Inner Fender Triumph 18
B TR2/3/3A Possible differential problem Triumph 3
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
S Carb Problem Austin Healey 13
E Gearbox problem Other Cars 0
A Rivergate slave problem Spridgets 3
Govtslug TR6 Clutch Problem Triumph 21
Writer2022 GT6 GT6 MK3 Alternator Problem Triumph 4
M 1977 MG Midget 1500 Problem Spridgets 8
KVH General TR Transmission Problem Triumph 3
DrEntropy W123 Benz recurring problem Other Cars 16
J MGB Idle problem MG 4
tr6nitjulius TR6 TR6 No 1st/2nd problem/solution Triumph 4
Got_All_4 TR6 Throw Out Bearing Fork Problem Triumph 7
Got_All_4 TR6 2nd Gear Bush Problem TR6 Looking at Steel Triumph 12
E MGB MGB heater motor problem MG 3
K TR2/3/3A Another electrical problem: Park light & 5ignal light on Drivers side are brighter than....... Triumph 3
K TR2/3/3A Problem with the gear lever "anti rattle fix"..... Triumph 10
T TR2/3/3A Help - Cooling system problem Triumph 7
T TR2/3/3A TR3A Fuel Gauge problem Triumph 10
ROARRR Is there any problem swopping in a 3.0 in place of the 2.5 L engine in my Jag X Type? Jaguar 0
T General TR Cluthch problem / challenge Triumph 4
M Europa turn signal problem Lotus 7
T TR2/3/3A TR3A clutch problem Triumph 15
E TR2/3/3A Tr3 a clutch hydraulics problem, again. Triumph 16
S Engine or Tachometer Odd Problem Austin Healey 7
R TR2/3/3A TR3A Coil/condenser problem Triumph 22
G windscreen problem Spridgets 1
Hamish Racing TR2/3/3A Gearbox - can you spot the problem ? Triumph 17
T TR4/4A Why are distributor base plates different, is this a problem? Triumph 7
J TR6 72 TR6 starter problem Triumph 10
nichola TR6 New harness installed but have a purple problem Triumph 12
M TR2/3/3A Paltech SU Carb Rebuild--Problem Triumph 3
Simmo General Tech Electric Cooling Fans. Are they a problem? Triumph 19
C TR2/3/3A TR3 Gearbox Problem Triumph 10
Healey Nut Clutch problem Austin Healey 5
R TR2/3/3A Tr-2 Clutch Problem Triumph 46
C TR6 TR6 TURN SIGNAL PROBLEM Triumph 13
R TR2/3/3A Grounding problem Triumph 21
P TR6 Wiring problem Triumph 50
P TR6 Clutch problem not solved Triumph 6
