BJ7 Rear Quarter Panels
chicken
Hi, im just trying to fit my rear quarter panels on my BJ7, i bought these from AH Spares.
Should they need trimming at all ? i can get the seat bolt anchor to align through the panel but when i try and get the front edge to align to the door pillar lip it puts alot of bend on the wooden panel and bows it, im assuming it should just fit in flat.
Do the rear backrest panel brackets bolt on first to the inner wing and then the quarter panel screws to this at the rear ?
How does it fix to the lip on the door pillar, just self tapping screws.
It feels like i'm getting somewhere with the jigsaw !
I did not have too much trouble with mine, the rear of the panel screws to the wide face of the bracket that is welded onto the wing and that holds the the rubber clip for the coach mans bracket that is screwed onto the rear of the back rest, the front is then fitted to the door reveal then you alter the position of the safety belt fixing to suit. If all that makes sense. My safety belt fixing was an adaption by a PO and consisted of a single bolt fixing through the wing and through the quarter panel. I had to cut a new hole in the quarter panels to line every thing up. The screws are generally chromed or stainless self tappers. Your door weather seal fits over onto the section of the panel near the door - say about 2 - 3 inches in and is finished with a clip. Mine is in pieces at the moment so I can not send photigs of the final finish.
Cheers
Cheers
Hi Bob, thanks for this. My seat belt fitting is also a single hole fitting with an eye bolt. I think my panel is snagging where the metal section is at the bottom of the footwell, i will try trimming this back and see if that helps as currently if i secure front edge and back edge it bulges the ply. Rob
How did this project end? I'm having a similar issue with a panel I purchased in the 90s. I'm just now getting around to updating the rear seat back to it's original configuration with new brackets in place. It appears that the panels make the overall width from side to side too small for what I have seen the rear seat back should be. Can anyone send a picture of what the proper connection looks like between the panels and the rear bracket? Seems it should be a little shorter than the same panel in a BJ8.
Hi, i think i have the opposite, the side panels seem to fit ok but then the back panel is too short ? i bought a new wooden back panel and had it trimmed so maybe i was sent the wrong piece or the trimmer did something odd.
So in answer to your question i'm still figuring out what to do.
I am not 100% sure but I do not think that the back of the seat was designed to fold flat. It stopped at the seat belt nuts. The BJ8 of course does.
Cheers
B BJ7 & BJ8 Interior Rear Quarter Panels Austin Healey 12
B BJ7 Rear quarter panels Austin Healey 0
R BJ7 Rear Axle Maintenance Austin Healey 5
B BJ7 Rear View Mirror Mounting Hardware Austin Healey 7
chicken BJ7 Rear Number Plate Mounting Austin Healey 3
D BJ7 Rear rail trim Austin Healey 0
B Rear shroud connection to the floor pan on a BJ7 Austin Healey 21
P Rear Seat Pan Bolt Hole Locations on a BJ7 Austin Healey 1
Griz Rear reflectors BJ7 Austin Healey 32
T BJ7 Slipping Clutch? rear main seal? Austin Healey 11
G Early BJ7 rear window fittings Austin Healey 2
B Spacer between rear air filter and carb - BJ7 Austin Healey 11
B Tow Hooks for the Rear of a BJ7 Austin Healey 10
rjc157 BJ7 Rear seat Back Austin Healey 5
healeydan BJ7 Top Rear Curtain Questions Austin Healey 7
maxwedge5281 1963 bj7 rear interior trim Austin Healey 45
B Installation of New Rear Seat Surround Panel for a BJ7 Austin Healey 8
maxwedge5281 rear seat pans for bj7 Austin Healey 2
C Rear seat panel BJ7 & ignition coil help Austin Healey 14
B BJ7 rear reflector Austin Healey 1
M BJ7 Rear Disc Brake Setup Austin Healey 7
B Rear soft top bow on a BJ7 Austin Healey 15
B BJ7 & BJ8 soft top rear seal Austin Healey 2
M BJ7 rear window ["backllight"] Austin Healey 0
D rear seats BJ7 Austin Healey 1
chicken BJ7 rear seat pans Austin Healey 0
chicken mounting of rear seat pans for BJ7 Austin Healey 14
R BJ7 rear drain channel- Seal or not? Austin Healey 6
B BJ7 Rear Seats Austin Healey 3
R Holes in rear shroud-BJ7? Austin Healey 1
5 WTB: BJ7 Squab Austin Healey 13
5 BJ7 Boot Rust-Through Austin Healey 13
B For Sale Too many Healeys - BN2, BN4, BT6, BJ7 For Sale Austin Healey Classifieds 0
Walter74 BJ7 Throttle Linkage "Support Panel" Austin Healey 5
T BJ7 Trim Recession (Convertible Top) Austin Healey 2
ModifiedBJ7 BJ7 Windshield Surround Rubber Seal Austin Healey 2
R New Hood for BJ7 Austin Healey 3
chicken BJ7 Chrome Trim Austin Healey 15
JMACENGINESHOP BJ7 Engine Rebuilding Austin Healey 23
B Wanted Grill Top Cowl and Surround - BJ7 Austin Healey Classifieds 1
R Changing BJ7 Differential Ratio Austin Healey 10
X Trouble shooting trafficator - 1963 BJ7 Jaguar 9
T BJ7 Hard to find First Gear when G/Box is hot Austin Healey 3
chicken BJ7 Door Fit Austin Healey 27
T Wanted BJ7 parts needed Austin Healey Classifieds 0
T Weight of BJ7 Transmission/Overdrive Austin Healey 10
D BJ7 Clutch Austin Healey 6
R BJ7 Back Seat-Rest Austin Healey 1
HealeyRick BJ7/8 Convertible Top Issues Austin Healey 5
