AlamedaMGB
First, i don't see nearly enough tech discussion on here re: carbs so I'm not sure if people don't touch them, or don't have isssue with them.
Anyway, I was tuning up my ZS so I can get me '77 MGB smogged. I went to adjust teh fine idle air mixture screw and ran into a few difficulties.
First: How do people loosen the course adjusting nut( the lock nut ) I couldn't get a wrench down in there very well, and when I put a wobble socket on there, I couldn't hold the fine idle screw. Definitely a challenge.
Second:
The fine idle adjust screw has a slot at the top, to adjust it up or down in the course adjust nut( lock nut ) but one of the tabs broke off. I hack sawed a new groove, but I would like to replace this part. Does anyone know of a source for the fine idle adjust screw? I looked in Moss, but the exploded carb view didn't show it. Only the Idle Speed adjust screw. Can I use any Set screw? Maybe one with an allen head would be better? does the profile of the trip of the screw matter?
Lastly,
I followed the Haynes process to the letter. Worked great, though a little obscure. Made more sense after I finished. And having a GasAnalyzer is vital if you are like me and can't differentiate between 'fastest smooth idle' and fastest unsmooth idle.
I still have to take it for a road test, but even if it's lean, I just need to get it to the test station.
I'm still bitter that I will be saddled with the ZS forever, as my B will never roll into smog exemption here in California. <sigh>
Second:
Lastly,
