Hey Guest! BCF is a resource offered at no cost to the Little British Car community. We do not require you to pay to play here. However, if you find BCF helpful, appreciate no pop up ads, and you want to ensure we stay online - Please support us with an "optional" low-cost (less than many car club dues) member upgrade. There are some benefits to upgrading!
[ QUOTE ]
DOES ANYONE HAVE A LIGHTENED FLYWHEEL AND DOES IT REALLY MAKE THAT BIG OF A DIFFERENCE ? WHAT IS THE DIFFERENCE ? REV UP QUICKER ?
[/ QUOTE ]
I have a dramatically lightened flywheel on my car. As the result of fitting an MGC xmsn, there was zero free play in the throwout brng, so the entire face was skimmed 0.125". The entire area outside the clutch cover was removed down to the height of the ringgear, and as much material as possible was removed from the backside, concentrating mainly on the outer perimeter.
Provision was also made for a higher performance clutch at the same time; the flywheel was drilled/tapped for a Ferrari 365 GTB/4 (Daytona) diaphragm pressure plate and a 1 x 23 friction disc. The clutch was sourced through Paeco, but the AP (manufacturer's) numbers cross over to the Ferrari application.
Throttle response is instantaeous, particularly when combined with the 45 DCOE Weber setup /ubbthreads/images/graemlins/cheers.gif
A friendly reminder - be careful what links you click on here. If a link is posted by someone you don't know, or the URL looks fishy, DON'T CLICK. Spammers sometimes post links that lead to sites that can infect your computer, so be mindful what you click.
(Click X in the upper-right to dismiss this notice)
