TR2/3/3A Frustration has started but car wont.
Stratty
Last week she started up just fine. This week after fixing brake issue she cranks and cranks. I have spark. I have fuel to carbs. One of the carbs leaks a bit from the float bowl. It wants to start when I add fuel into the carb. Hmm any ideas?
1956 tr3
TR4nut
Possibly gummed up needle valves that are glued shut right now. Shoot some carb cleaner in the bowl inlets. I like to keep it simple too - some spray starting fluid in the carbs should get the engine to fire, that would help eliminate other issues.
Geo Hahn
Possibly gummed up needle valves that are glued shut right now...
I agree that is a likely cause. You can open the top of the fuel bowls (one nut, ÂĽ" Whitworth IIRC but you can use a crescent wrench or maybe a 12mm open wrench) and peek inside. Should be nearly full of fuel but if they are dry that is your answer.
sp53
Is this the car that was making all the noise? But anyways my experience has been tractor motors fowl out spark plugs easily. I pull the plugs and look to see if they are carboned up or too wet with fuel to start then go from there.
steve
R TR2/3/3A New engine = frustration Triumph 19
F Frustration trying to adjust handbrake on Austin Healey BT7 Austin Healey 9
vette Ignition Parts Frustration Austin Healey 18
Bob Claffie MGB Brake frustration MG 33
apbos H1 SU vacuum advance frustration. Spridgets 9
D Wheel painting frustration Spridgets 25
Tinkerman Frustration time ARRRRGH Triumph 19
angelfj1 Vent Pull Frustration Triumph 9
DNK Frustration! Triumph 18
M Datsun Trans Frustration and More Spridgets 3
mikecyc72usa Ugh! Frustration!! Triumph 16
J Frustration & Responsibility...LONG POST MG 9
W Frustration!! Spridgets 3
dklawson Spitfire Spitfire - Single-Rail Gearbox Frustration !!! Triumph 20
R TR2/3/3A 58 tr3 ignition + frustration but smashin' bugs Triumph 17
philman Wedge TR7V8 frustration Triumph 3
RickB Fuse block frustration Spridgets 20
C Gauge Rebuilding Frustration Austin Healey 4
Jim_Gruber Errrrrrrr!!!!!!! Frustration!!!!!!!! Nasty Words!! Spridgets 15
B paint frustration Racing 10
kyreb1862 Frustration !!! MG 10
Newkie Help! Fender hardware frustration and... MG 17
W TR2/3/3A Selling Frustration - TR3 Triumph 31
jjbunn MGB-GT Frustration Extendus Horribilis - GT Windscreen MG 49
White79MGB Flasher Frustration Triumph 9
Morris Extreme Frustration Spridgets 15
wkilleffer Carb balance/adjustment frustration [long] MG 22
D Frustration 401 Engine/Tranny Triumph 1
B Nuts and Bolts Frustration Spridgets 6
KLUTZ Frustration is quickly mounting !!!!!!! Triumph 19
K TR2/3/3A How to tell if the timing chain has slipped...... Triumph 12
drooartz The great Gordon Murray has a Bugeye! Spridgets 0
R TR6 I just brought this to its new home. It has been stored for 15 years, has only 21000 miles , and only 1000 sincw Triumph 12
B tachometer cable has a hole in it Restoration & Tools 7
K TR2/3/3A Red ignition light stays on...car has alternator not generator. Triumph 17
W Wanted Servo for BN4 has to be original 1957 or before any condition considered. Austin Healey Classifieds 11
AUSMHLY BJ8 Transmission just rebuilt now has metal filings Austin Healey 10
K TR2/3/3A Clutch Slave Cylinder location when TR3 has a TR6 Gearbox? Triumph 16
T TR2/3/3A Has anyone designed a hand brake warning light for the TR3? Triumph 3
R Has this ever happened to you? Any odd Sprite story... Spridgets 8
P Hoping someone has this measurement easily available. Austin Healey 3
E General TR Hertitage certificate: factory record has not survived Triumph 11
R General Tech Preserve eng/trans that has been removed Triumph 11
S TR2/3/3A TR3 has me stumped, it runs then dies over and over and the exhaust system was pulled Triumph 9
T TR6 Car has always started without fail.....until now Triumph 10
C TR6 A lot has happened. Update on my project Triumph 7
Jim_Gruber In need of 2 Fulcrum Pin Bolts - MOSS Has them on Back Order Spridgets 3
K TR2/3/3A Friends TR3 has carb issues? Triumph 5
vette To Johnny who has posted an Article in the Articles Section about his German Exported Austin Healey 9
BOBBYR My Dad has to be laughing Austin Healey 4
