Whitworth on 59 Sprite.
Deanr
Just getting started on this car and was curious how much Whitworth I would find.
I have none on hand and would be a major hold up to wait on some.
DavidApp
I am new to the MG Midget but I think you will find that you will have UNF bolts and maybe some UNC, but no Whitworth threads.
Whitworth came in 2 flavors. BSF and BSW for fine and coarse. Most cars in the UK used UNF and UNC.
David
Deanr
I wasn’t sure as I only been driving it not working on it. I thought Whitworth would only be found on the SUs but it is British.
DavidApp
Does look like the cabs use some BSF spanner/wrenches.
BSF and BSW head sizes were brought into line some years ago so there are two sizes marked on them. For instance 7/16 BSF 1/2 BSW At one time you had to have 2 separate sets of spanners one BSF and one BSW.
David
drooartz
Yup, car is all "standard" mostly fine thread other than at least one nut on the carbs. Only a handful of sizes as well so it's an easy car to work on.
BobHaskell
Another thread (with different wrench sizes) that you'll run across is British Association (BA). Used by Lucas, Smiths and SU. Examples of BA cheese head screws include SU carb dashpots, Lucas distributor points, Smiths fuel sending units, SU electric pumps (I'm not familiar with the mechanical SU pump). The threaded studs on the back of Smiths gauges are BA.
So be cautious when chasing threads. BA and Whitworth thread gauges are available on Amazon. Descriptions of British threads can be found on British Tools and Fasteners web site.
Jim_Gruber
There is also a Bolt IIRC on the E-Brake cable that is Whitworth. For the most part all SAE Fine thread other than mentioned above.
SNClocks
Years ago I bought a Myford lathe from back in the 40s. It's pretty much Whitworth so in one of my trips to the UK I bought a couple of sets of Whitworth wrenches and sockets at boot sales. They were very inexpensive, even though good quality names. In the work I've done so far on our bug eye I've had to use Whitworth wrenches a couple of times but probably could have gotten away with an adjustable spanner. You can see that I have a set of Whitworth, SAE and Metric wrenches on the wall behind the lathe...
The contraption to the right side of this shot is a Zeiss operating room microscope I adapted for doing fine work on the lathe.
K TR2/3/3A Does this fitting need a Whitworth wrench? Triumph 10
TR3MT TR2/3/3A Whitworth Threads (as on the bolt) Triumph 6
JPSmit Whitworth Question Restoration & Tools 23
jfarris TR2/3/3A Whitworth fill plug for lever shocks Triumph 2
MikeAH100M Whitworth Source Austin Healey 8
Basil SOLD!! Set of Whitworth Sockets for sale Other British Classifieds 1
JimLaney Whitworth Threads or Just Nuts! Spridgets 5
Jim_Gruber 1/4 Elliptic Spring Clamps - Are those Whitworth Threads on those 1/4 Screws Spridgets 7
Jim_Gruber Did I find another need for a Whitworth Wrench Set/ Did I screw up intake manifold Spridgets 5
LarryK Whitworth tools Restoration & Tools 5
bowiderberg Spitfire Whitworth on a Spitfire 1500? Triumph 8
timbn2 Whitworth / BSW tap and die question??? Austin Healey 25
M Addendum to searchin for Whitworth screws Jaguar 2
M Source needed for Whitworth-BSF screws,etc. Restoration & Tools 2
C Need info on Whitworth hardware Restoration & Tools 3
timbn2 whitworth / king dick tools... where to get.? Austin Healey 4
G I need a quick tutorial on Whitworth wrenches MG 6
B Quality of various Whitworth spanners Restoration & Tools 9
EinsteinsDad Grade markings on British Whitworth Fasteners Restoration & Tools 4
KVH TR4/4A TR4/4A Gas Line Whitworth Questions Triumph 0
Britishtools More in depth Whitworth Thread Information Restoration & Tools 3
Britishtools Mr Joseph Whitworth: Inventor and Engineer Restoration & Tools 7
B Whitworth - where?!? Austin Healey 7
drooartz Spring service of the 4-door Sprite (Morris Minor) Spridgets 8
D For Sale 1958 A-H Bugeye Sprite Austin Healey Classifieds 3
CARSINC Progress On My 1965 Sprite (update) Spridgets 3
Bayless Onslo the Sprite runs Spridgets 4
F Sprite Gearbox Spridgets 5
CARSINC Sprite bonnet emblems Spridgets 4
George Zeck SOLD!! 1964 AH Sprite MKII Spridgets Classified 0
apbos New long term project. Sprite powered rear engined race car. Spridgets 9
drooartz A disassembled sprite takes up a lot of space! Spridgets 30
CARSINC For Sale Sprite Shift Lever Spridgets Classified 0
CARSINC For Sale Sprite Front Wire Wheel Hubs Spridgets Classified 0
CARSINC For Sale Sprite Differential Spridgets Classified 0
CARSINC For Sale AH Sprite Axles and Hubs Spridgets Classified 0
Bayless What size battery for my '67 Sprite? Spridgets 5
CARSINC 1965 Sprite Bugeye Spridgets 5
CARSINC Sprite Electrical System Information Spridgets 2
Boink 3D Sprite Model Spridgets 3
A Sprite Tacho Spridgets 2
BJ8Healeys Location of VIN tag, 1964 Sprite HAN8L43421 (I know it's stamped on the frame. Looking for the tag.) Spridgets 8
S Calling All Spridget Owners & Race Fans - Sprite Turns 65 Spridgets 3
Bayless How does '67 Sprite top attach to body? Spridgets 3
adcronin For Sale MGB Turn Signal (lights, horn, indicator) Switch, New for 62-67, also Sprite MK 3 & 4, MIDGET MK 2-3 thru 67 MG Classifieds 0
N For Sale Austin Healey Frogeye Sprite Spridgets Classified 0
D Sprite Model Identification Austin Healey 2
S Sprite Fuel Pump Upgrade Austin Healey 1
C For Sale Center wiring harness for a 1959 Sprite Spridgets Classified 0
