Where to buy bolts that secure door latch
tdskip
Hi guys - I fixed a nasty rattle today by tightening two of the three bolts on the door latch mechanism (on the door itself). Yes, 2 of the 3 since the 3rd is missing. Gone. Vanished. See y'all later. It's out of there!
TRF lists them, but there are several types. My car is a 1974.
# 517148 - Screw, set, single-slotted head
#ZKC36 - Screw, set, cross-slotted head
I think the cross-slotted head is correct. (assuming cross-slotted refers to the "x" pattern on the bolt. Yes?
Thanks!
I got all the fasteners for my doors, fenders, etc from GROVE COMPONENTS in the UK.
They have kits already made up for classic cars including Triumphs.
I think you are looking for the posi-drive screws... they have them!
Tom- My '73 TR6 had the posidrive screws in the door latch and striker plates.
One more thing... if you go to Grove Components site and do a search on "Triumph" it will bring up all the kits for the Triumph.
Thanks for asking...
5-speed is sorted out, it shifts sooooo much better, and the new GP hubs are great. I think it is performing better than when it left Coventry!
Skip,
I got nice stainless steel ones that are hex headed from MMS.
https://www.mmsacc-stainless.com/
Cheers,
M. Pied Lourd
I just used SS phillips head that were the same shape
B MGA Where to Buy, What to Buy? Axle Nut MG 9
B Windshield glass, where to buy Restoration & Tools 4
M TR4/4A Where to buy a new crown wheel & pinion for TR4A Triumph 5
55modified TR2/3/3A warning indicator bulbs need replacing where and what to buy? Triumph 4
M TR4/4A Where to buy this aluminium extrusion? Triumph 7
vette Any Suggestions As to Where to Buy a New BJ7 Gasoline Tank? Austin Healey 24
AngliaGT Midget Parts - Where to buy? Spridgets 11
M TR4/4A Where to buy replacement TR4 exterior door handles? Triumph 1
F Spitfire Where to buy Stripe Kit Triumph 1
T TR2/3/3A Where to buy steel TR3A battery box? Triumph 8
MY66AH Where to buy a new crank Spridgets 40
B WHEELS- Where to Buy Triumph 4
B TR2/3/3A where to buy oversize thrust washers for TR3B? Triumph 16
Zitch Leaky SUs where to buy rebuild Triumph 22
D Where in N. Va. to buy/ mounts tires on wire wheel Austin Healey 3
Mychael Where to buy quality pedal rubbers. Spridgets 2
M Where would you buy your next fuel tank? Austin Healey 6
C TR2/3/3A Where to buy front calipers for an early[57] TR3? Triumph 7
60Bugeye Where to buy Bugeye Body Panels? Spridgets 13
T Where buy bullet connectors locally [ie pick up]? Triumph 15
W 90 GL$ Where to buy???? Triumph 12
richberman Where to buy Q-H bushings? Austin Healey 1
PatGalvin TR2/3/3A TR3 Fuel Line - where to buy? Triumph 7
B where to buy 175/80r15's? Austin Healey 11
P Where to buy a Parts Washer! Restoration & Tools 10
H WHERE TO BUY A CLUTCH M/C PUSHROD? Triumph 5
hondo402000 TR6 ARP Head stud kit 71 TR6[ Where to buy] Triumph 10
D T-Series Where to buy clutch parts MG 5
soren_ak where do u buy your healey parts guys ? Austin Healey 8
Gerdo Fuel Float? Where to buy? Triumph 8
Geo Hahn Redlines - Where to buy Triumph 3
L Where to Buy Replacement Rocker Panels-Frustrated! Austin Healey 5
B TR6 Where can I buy a trunk kit for a TR6? Triumph 6
M Where can I buy my spouse TR6 things - T-shirts? Other British Cars 4
YankeeTR TR2/3/3A Where can you buy TR2 door wood? Triumph 11
B Need Advice: Where to buy...? Spridgets 1
356roadster brake drums for early 100 bn1: where to buy? Austin Healey 16
J Where to buy aluminum door trim. Austin Healey 3
J Where to buy windshield and rubber parts. Austin Healey 5
T Where to buy Factory Grade Paint? Triumph 6
Z TR6 Where to buy TR6 Soft Top Triumph 7
tr6web Paint - where to buy it? Triumph 3
RobSelina where to buy springs Spridgets 7
K MGB where can i buy mirror for a MGB Roadster 1971 ?? MG 3
V Where to buy headers Triumph 0
Steve Where do you buy tools? Restoration & Tools 14
1955TR2 TR2/3/3A TR2/3 Oil Leak Where Oil Sending Pipe Connects to the Block Triumph 8
Scotsman TR4/4A Chimney nuts, where do they go Triumph 5
jehuie Where to post for parts that fit many cars? FORUM Navigation Questions 1
Pythias Where to post FOR SALE Spridgets 1
