What to use for exhaust mid pipes?
tomshobby
Need some help. I am replacing the exhaust on my '76 TR6.
I am using a Jet-Coat header and ANSA dual pipes. What I need to know is what to use between them. Would stock mid-pipes work or maybe the connector pipes from the TRF header kit?
Thanks,
DNK
My mid pipes don't even come close to matching up with my sport headers,I'm still ticked about that 6 years after the fact. Still don't have them hooked up. Had them coated too!
G
Tom, I have the Falcon SS headers (split, duals) and the Falcon SS dual system. My problem was and is the Falcon mufflers are huge and hang really low. There is no adequate way to "hang" them so that there is room for them to move. So I used a unique way to mount the whole system. From the header back, I mounted some SS flex pipes (10" long each) from header to the rest of the system, then rigid-mounted the rest of the system on special cross bars that I rigged. If you get what I am talking about, the system doesn't vibrate or have room to expand, save for the middle sections of flexible pipes. The flex pipes are triple-walled SS pipes that were custom fabricated. The system works well for me. The mufflers are still huge, but are rigid-mounted all the way to the rear of the car.
DNK
Have the same system as Bill. I don't know if his fit,mine don't come close
tomshobby
tomshobby
After a number of phone calls I found the ANSA pipes should fit the original stock connector pipes. I also found the header from Jet-Coat is from Pacesetter and is supposed to be a fit to the same original connector pipes.
I verify this if it works or not.
Brosky
<div class="ubbcode-block"><div class="ubbcode-header">Quote:] I also found the header from Jet-Coat is from Pacesetter and is supposed to be a fit to the same original connector pipes.[/QUOTE]
Ah.....that's not quite true in all cases, or at least in mine. It wasn't even close! I had the TR6 towed to a custom exhaust shop and had the center pipes custom made.
G
[/QUOTE]
Ya big sissy! I just had to drive mine the neighborhood a couple of times with an open header. A noise like that you will never forget. Neither will the neighbors.
Brosky
I didn't mention that I did drive it about 6 miles and was stopped by a State Police Officer. He "suggested" that I arrange for a tow. While he waited.
No further arguments, sir.
tomshobby
tomshobby
Thanks for the insight and picture. I was hoping that mine might fit better than the combination that Bill and DNK had to work with but that hope faded into oblivion now that I see Paul's picture.
I am beginning to see a great opportunity here for companies that would make Triumph parts that actually fit.
Other parts of my project seem to be moving along fine when I can find some time to work on them. (My business keeps getting in the way, in a good way though)
swift6
That reminds me of the time that I replaced the stock muffler with a set of mid-pipes. Resulting in straight, twin pipes from manifold to rear bumper. The pipes were in the middle of the rear bumper like some BMW's. Barely more tolerable than open header (done that too). I kept the straight pipes on for about two weeks. 3,000 rpm seemed like it could almost break glass it would get so high pitched. I finally decided that long term hearling loss was not a good idea and put the muffler back on. /bcforum/images/%%GRAEMLIN_URL%%/wink.gif
FWIW, I had to have custom mid-pipes made for my header to Twin Sports System as well.
M TR2/3/3A Blown Exhaust Manifold Gaskets Triumph 9
J TR4/4A Exhaust a tad too loud... Triumph 6
F BJ8 Exhaust Hanger Pictures Wanted Austin Healey 9
K TR2/3/3A Exhaust bracket rubber "top hat" bushings? Triumph 3
K TR2/3/3A Thick flat washers for exhaust manifold studs? Triumph 0
CARSINC Please Identify this Exhaust Header Spridgets 2
Patrick67BJ8 Traced down that elusive exhaust leak! Austin Healey 5
Walter74 AH Spares Side Exhaust Austin Healey 2
TomMull GT6 "Sports" Exhaust Triumph 2
Tim Tucker TR4/4A Phoenix Stainless Steel Sports Full Exhaust System Inc Manifold experience Triumph 3
B Thread Type and Size of BN2 Intake/Exhaust Studs Austin Healey 0
AUSMHLY Cylinder Head Input/Exhaust Circlip/Split pin Austin Healey 3
K TR2/3/3A Exhaust pipe banging inside the cruciform? Triumph 8
B TR4/4A Exhaust Wrapping Triumph 8
M Wanted Midget 1500 exhaust manifold MG Classifieds 0
T Exhaust Pipe Hose Austin Healey 9
B Stainless Steel Exhaust System Wanted Austin Healey 5
newmexTR3 For Sale TR2-4 performance valve springs, collars, exhaust seats, cotters Triumph Classifieds 0
jfarris TR2/3/3A Exhaust Hanger Question Triumph 4
3 Exhaust Manifold/Headers BN2 Austin Healey 16
Zitch SOLD!! SOLD - Tri-Carb Exhaust manifold for a 3000 Austin Healey Classifieds 0
tahoe healey Exhaust Manifold Gaskets Austin Healey 5
K 100-6 Exhaust Front Mounting Bracket Austin Healey 2
nichola TR6 Stock exhaust sound... short video Triumph 4
S TR2/3/3A Exhaust system - It hangs too low no matter what I do Triumph 15
60TR3A TR2/3/3A Exhaust System Recommendations Sought Triumph 15
B Exhaust Pipe Size Austin Healey 26
6 Exhaust Pipe Spridgets Classified 2
K TR2/3/3A Can heat from exhaust downpipe ..... Triumph 2
AngliaGT MGB-GT TT Stainless Steel Exhaust Re-Installtion Suggestions MG 2
Ripper01 SOLD-TR6 Dual Port Exhaust Manifold Triumph Classifieds 6
K TR2/3/3A Time to replace the exhaust header wrap.... Triumph 2
D Wanted TR6 exhaust manifold w/air rail Triumph Classifieds 2
S TR2/3/3A Exhaust Systems Triumph 10
S TR2/3/3A TR3 has me stumped, it runs then dies over and over and the exhaust system was pulled Triumph 9
B TR4/4A General exhaust questions Triumph 17
J Spitfire 1979 Spitfire Running rough [sputtering, exhaust poping] at start up Triumph 2
Merlin63Tr4 TR4/4A Triple to dual exhaust valve spring conversion done wrong? Triumph 7
W TR6 Anyone add Exhaust tips to standard exhaust Triumph 4
F Exhaust Fumes in the Cockpit - BT7 Austin Healey 10
GeorgeC Intake / exhaust manifold gasket install goop? Spridgets 2
3 BN2 clutch pedal and exhaust downpipe Austin Healey 14
AUSMHLY Gasket, Inlet Manifold to Exhaust Manifold BJ8 Austin Healey 8
Zitch For Sale TR-4A exhaust manifold Triumph Classifieds 0
BJ8Healeys BJ7/BJ8 Exhaust Systems Austin Healey 24
AUSMHLY Exhaust Manifold Flange Stud Austin Healey 13
AUSMHLY Exhaust leaks Austin Healey 14
PAUL161 T-Series MGT Exhaust Stud Thread Size MG 2
BLong63AH Removal of Intake and Exhaust manifold. Austin Healey BJ7 Austin Healey 24
crispy How to Remove the Exhaust Manifold?? [late BJ8] Austin Healey 27
