WAY off subject but...
GaryBeu
Banned
I know this is the BCF but the real auto experts live here. :smile: One of my front disc brakes on my 1995 Ford F-250 4wd is apparently binding all of a sudden. Truck pulls to the left when driving and the wheel is very hot. Brakes were redone 15,000 miles ago. What would be the appropriate method of checking the problem? Thanks
Gary
Were the calipers rebuilt with new seals and pistons when the brakes were redone? If not, then oftentimes later down the road the pistons will seize up in the caliper. Some of those used composite pistons instead of metal and they tend to expand and bind and not return properly. If they're metal pistons, then rust, etc. causes the same problem.
That seems to be the most common problem with them. Do both if that's it because the other is probably not far behind
Not familiar with Ford big trucks but, if it has a single piston system (pistons pushing from only one side) it's possible that the caliper is hanging up in the caliper frame. The frame would pull in the pad opposite the piston and not release. Bob
At 15K, a caliper hanging in the slide will show more wear on the piston side pad.
Look.
Also, was not aware Ford had gone to composite pistons. Must be weight/cost, as the disaster of the Chrysler composite pistons on the 70's and 80's that swelled up and locked should have taught everybody in the industry a lesson. You could buy replacement stainless or plated pistons to fix it.
Unfortunately I know this first hand since my '95 van, my '97 motorhome, and my son's 93 Escort and earlier his '87 Escort all had this problem at one time or another. All had composite pistons. Buying a rebuilt caliper with steel pistons was the best fix in all cases. To paraphrase the Beatles, "All you really need is $"
Thanks guys. I don't know if the pistons are composite or what. We replaced them with "new" calipers when the work was done. I'll be looking at it later today.
Floating caliper or fixed? If floating, check the guide pins and ensure they are not bent and the caliper floats freely. Some mfgs suggest lube, some dry but polished. Thats the first thing I'd check.
I polish mine in the drill press and use a *tiny* smear of wheel bearing grease.
OK, let me throw in a ringer, as your truck is old enough! Check your front flex lines, actually I would replace them anyway. I had this happen twice. The flex line on one had a steel clamp that held it from moving, the clamp rusted between it and the hose so much, it actually restricted the fluid from returning back after brakes were applied. The other one went bad when the rubber inside broke loose due to age and caused a valving effect, allowing the fluid to move only one way. Regardless of what ever is wrong, I would replace these two lines. JMHO and experience. PJ
Yes. Like Paul, I've had those flex lines act like a one-way check valve, preventing fluid from coming back out of caliper.
In my case, the flex line had come apart internally. It's a good idea to change them if they're older.
On the parts counter we see this all the time, mostly after the customer has already replaced the caliper/wheel cylinder. When you ask them if the checked the hoses, it amazes us that the test for this, is the same as for battery cables. You just grab it,wiggle it back and forth, and............its good!
Thanks for all of the suggestions. It's been raining so hard here (I have to work outdoors) that I haven't gotten anywhere yet. Hopefully, tomorrow.
Well, I took the caliper off and the lower piston is frozen. The rubber seal around it is gone so I guess water and road salt did it in. I'mm gonna replace the flex hoses on both sides "just because I'm there". Thanks again to everyone.
AUSMHLY Off subject - Gel coat Austin Healey 5
TulsaFred Fixing distributor that is "one tooth off" Spridgets 3
K TR2/3/3A Old school battery shut off switch....... Triumph 3
petnatcar Knock-Off Wrench - The New and Improved Version Austin Healey 12
B TR4/4A Headlights Blink Off Triumph 15
S TR2/3/3A getting the circlip off 3rd gear Triumph 9
Editor_Reid TR2/3/3A Original Knock-Off Hammer Triumph 14
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
scottkilpatrick TR4/4A Knock off wire wheels procedure..basic questions Triumph 9
Editor_Reid Knock-Off Hammer Austin Healey 8
kodpkd Signing Off Austin Healey 8
KVH General Tech Loud Metallic Click Pop Every Time After Engine Off Triumph 11
T Knock-Off Spinners Austin Healey 43
jfarris TR2/3/3A Plug/cap sizes to block off heater Triumph 5
G Engine Will Not Turn Off Austin Healey 10
DrEntropy A couple Cumberland SCCA Runoff shots, 1976 Racing 0
L BUG EYE WHAT CAUSES A VOLTAGE REGULATOR TO STICK ON WHEN U TURN KEY OFF Spridgets 3
F For Sale: Minilite Style Knockoff Wheels, 15" x 5.5" Austin Healey Classifieds 2
Tr3aguy TR2/3/3A Gasket part way off Triumph 10
T TR4/4A Fenders off the car for paint? Triumph 8
MikeAH100M Austin Healey Book by Geoff and Signatures Austin Healey 3
TRopic6 For Sale TR2/3 Brass Fuel Shutoff Tap [for parts] Triumph Classifieds 0
G Inertia Cut-Off Switch - E-Fuel Pump to Ignition [Key] Switch Austin Healey 3
R Turn Signal Knob goes off center Austin Healey 9
J BJ8 flywheel take some pounds off Austin Healey 17
Lin Rightway Heritage Trimming - Geoff Chrysler Austin Healey 5
A Setting Camber Really Off Austin Healey 13
W For Sale 1961 TR3a - Full Off Frame Restoration Triumph Classifieds 0
JPSmit So I guess I don't need to lay off the churros after all Spridgets 4
CJD TR2/3/3A Fuel Shutoff Valve Triumph 63
S TR2/3/3A Frame off vs. body on restoration Triumph 21
Basil Easy[er] way to get frozen brake rotors off Restoration & Tools 13
steveg Fuel pump inertia cutoff switch Austin Healey 33
B TR4/4A Can't get rear extension off. Help! Triumph 24
S TR2/3/3A fixed one of those brass fuel shut off deals? Triumph 13
JPSmit Off to bed for the winter Spridgets 10
TomMull Knock Off Tool Restoration & Tools 6
S MGB When your breaks off. who ya gonna call......? MG 2
L Tight spot on steering box is way off Austin Healey 18
R TR4/4A Speedometer off 10mph Triumph 6
Boink MGB MGB-GT off-roading? MG 4
T Even but low compression on 3.8 - timing slightly off? Jaguar 7
J Gas pump auto shut off question Austin Healey 2
jfarris Wanted Mag style knockoff wheels for TR3 Triumph Classifieds 1
Got_All_4 TR6 How does this steering lock come off Triumph 9
Jim_Gruber Braided Line for Spin Off Oil Filter Adapter Spridgets 13
Got_All_4 TR6 Rear Panel Reflector off a parts car? Triumph 8
D TR2/3/3A off topic , but can you help with a quotation Triumph 5
T TR4/4A Heater control valve - cant completely turn off Triumph 3
JPSmit Off to British Car Day Spridgets 8
