V8 or Polyurethane bushings
X
xsteamer
I couldn't find the previous thread so I am asking what should I buy, V8 or polyurethane bushings? Do I need to use an antiseize agent when I install them?
And a good policy is: Anti-seize all threads. You may be the next guy to have to disassemble it. /ubbthreads/images/graemlins/wink.gif
Should antiseize be used on all nuts & bolts?
I use it on most things threaded. Not many of the engine fasteners: thermostat housing studs are treated with it, crank damper too, but most body/chassis stuff.
ummm... "most".
We used antiseize on truck lugs for years. If torqued down to proper specs there should be no trouble.
I bought those poly bushing for my MGA....haven't installed them yet though, again hopefully I'll get to it this summer....They came with a tube of antiseize
Torque settings are more acurate when the threads are coated with some type of lube. When torquing, you are actually, microscopically, streching the bolt. It might be a bit confusing as we normally think of torque as twist. In bolts, it's actually streach verses friction. The torque can change on the same size bolt depending on its grade and length. Grade 5, grade 8 etc. The friction not being in the threads but from the head of the bolt to it's mating surface. The easer the threads can turn, the more accurate the torque readings. Antisize is a good thread lube because it protects the threads for extended periods of time. Makes it easier to remove the bolt later and it comes in differant heat ranges. Never put antisize on the bolt head or its mating surface. You can use it on lug nut threads as long as you don't get it on the wheel and nut mating surfaces. That's where the friction comes in. /ubbthreads/images/graemlins/hammer.gif PJ
B TR2/3/3A What do you do lubing polyurethane bushings? Triumph 7
R TR2/3/3A Front Suspension Polyurethane Bushings Triumph 2
K Polyurethane bushings Spridgets 9
M MGC Polyurethane bushings on MGC GT - Good or Bad idea MG 2
M Polyurethane bushings on BJ8 - Good or Bad idea Austin Healey 6
doughairfield Rubber vs Polyurethane bushings. Triumph 14
mrsprite polyurethane bushings? Spridgets 6
fmichaels polyurethane bushings Spridgets 2
I Rubber verses polyurethane bushings Triumph 15
Popeye Polyurethane cure time - wheel refinishing Restoration & Tools 2
B Polyurethane Bushing Austin Healey 9
jerrybny Prothane Polyurethane Bushing Sets Triumph 9
glemon Polyurethane Bush Lube Triumph 8
F Polyurethane Rotoflex Coupling... Triumph 3
J New paint -- results [polyurethane or enamel]? Triumph 22
K TR2/3/3A Exhaust bracket rubber "top hat" bushings? Triumph 3
dwpirkeyjr Red? Bue? Purple? Yellow? Poly Bushings Complete Set For 1979 MG midget 1500 Spridgets 7
K TR2/3/3A Rear leaf spring brass and Delrin bushings ? Triumph 4
Racer-X- Metalastik Lower wishbone bushings and upper fulcrum pin bushings Other British Cars 6
KVH General Tech HS6 Carburetor Bushings Triumph 10
S TR2/3/3A steel bushings for the lower Arms Triumph 10
Hangtown Healey King Pin Bushings Grease Groove Austin Healey 8
A TR2/3/3A Early TR3 starter (bomb style) bushings sizes Triumph 7
R TR6 Lower A-arm trunnion bushings Triumph 18
Got_All_4 TR5/TR250 Need guidance for replacing steering column bushings Triumph 11
Upland SuperPro trunnion bushings Spridgets 0
R TR2/3/3A Upper Wishbone Bushings Triumph 12
steveg TR6 Installing stock trailing arm bushings on the car - is it possible? Triumph 2
tahoe healey Sway Bar Bushings Austin Healey 3
Gliderman8 TR6 Corona boredom relief - Steering Wheel Bushings Triumph 6
B Wanted FOUND. TR10 Fan mount Bushings Triumph Classifieds 3
S TR2/3/3A Clutch cross shaft bushings? Triumph 5
S TR2/3/3A lube for upper A bushings Triumph 2
R TR2/3/3A Replace Rubber bushings in front suspension Triumph 11
Got_All_4 General TR Has anyone used these poly bushings Triumph 6
D TR2/3/3A steering column bushings Triumph 8
B MGB Installing new upper fulcrum bushings MG 5
B MGB Installing upper fulcrum bushings MG 0
Gerald_Gordon TR4/4A Preferred front springs and suspension bushings for mild driving in a TR4 Triumph 3
mt10flyer TR2/3/3A poly bushings - upper wishbone Triumph 2
55modified Replacing rear spring eye bushings on a BN1. How difficult? Austin Healey 8
KVH General TR Pressing in the lower/inner control arm bushings Triumph 3
S TR6 steering column bushings Triumph 5
N Top link offset bushings?? Spridgets 6
S Question regarding NOS vs New rear leaf spring bushings Austin Healey 3
B TR2/3/3A Inner wishbone bushings Triumph 5
GBRandy TR6 1973 TR6 Rear Frame / Body Bushings Triumph 3
Got_All_4 TR2/3/3A Super pro bushings Triumph 2
Got_All_4 TR2/3/3A Reaming trunnion bushings Triumph 4
Got_All_4 General TR Anyone running superpro bushings? Triumph 3
