Unknown Switch ???
George Zeck
Hi everyone ....
In process of rewiring some vital items on the car // switching from positive earth to negative ground and we found what clearly appears to be a small black switch underneath the dash / immediately below & underneath the speedo. Since the car is in pieces now -- can't turn anything on.
Any idea's ??
(it's so hidden I want to say it's a "kill switch". Remember, clearly stock not aftermarket item).
Tx
George Zeck
Biff
The "unknown" switch is your panel (instrument) light switch. It (the panel lights) are either on or off. This is the same for bugeyes and both the Mk-II and Mk-IIA cars.
Tullamore
Speaking of unknown switches, my Sprite has a switch in the middle of the console directly above the steering column. I think it is called the brake switch, when you push it the red light comes on. What does it do?
Tom Rynne
To be a litlle more exact on the brake failure light, it is activated when one of the hydraulic circuits experience a loss of pressure due to leakage such as a rear cylinder seal failure or a damaged brake line. The brakes have 2 circuits for safety. If one fails you still have 2 wheels to brake.
The light is activated by a switch which in turn is closed by movement of a small piston inside the brass brake line junction on the inner fender. The pressure drop to one circuit under a leaking condition causes the piston to move to the side of lower pressure which causes the switch to be activated and the dash light to come on constantly thus warning you of the failure. This is not to be ignored!
Pressing the test button on the warning light is, as was stated above, only testing that the bulb in the light still works.
Bleeding the brakes can sometimes cause the piston to move and it must then be recentered.
I had the entire master cylinder on my 72 B siphon dry when the O rings on the piston failed. The cure for this is to remove the brass junction and clean it and the piston and refit new O rings. The junction seems to be a place where any crud which is present in the brake system tends to collect!
spritenut
The Brake failure switch.
It comes on when you step on the brake pedal and it goes to the floor.
Then you say Oh $h!* No brakes, but now there is a light on the dash to let you know this.
Geo Hahn Unknown Switch Other British Cars 1
Agrandshort TR2/3/3A Unknown part panel Triumph 5
CARSINC Unknown Part Spridgets 5
P Unknown British sports car Spotted 7
TheRealDestrux MGB Unknown connector on alternator MG 6
Walter74 Unknown Hole Purpose Austin Healey 2
H T-Series Unknown British[?] Engine MG 3
D TR2/3/3A master cylinder res plumbing and unknown spacer Triumph 6
K For Sale TR3 Ammeter...condition unknown Triumph Classifieds 0
R BJ8 MKIII unknown parts Austin Healey 2
G TR2/3/3A Unknown holes Triumph 6
Geo Hahn Unknown Car - Possibly British? Other British Cars 17
Tinkerman TR2/3/3A Unknown Part TR3? Heater Bracket? Triumph 5
J Unknown Bracket Austin Healey 4
L Unknown Brisith Car Rover / Land Rover 2
Twosheds Unknown Mystery Car Other British Cars 7
T Another unknown part Triumph 4
ronzet MGA Unknown Part for my 1957 MGA MG 14
B Testing an unknown engine Austin Healey 9
D Unknown car, Help? Other British Cars 14
K unknown car question! + berkeley ! Other British Cars 7
P unknown tool Restoration & Tools 3
Patrick67BJ8 Custom BJ8 Dash Switch Panel Austin Healey 7
R Bugeye ignition switch Spridgets 2
K TR2/3/3A Old school battery shut off switch....... Triumph 3
T TR2/3/3A Replacement Turn Signal Switch Triumph 4
F Wanted Dipping switch cap Triumph Classifieds 1
L What does this column switch do? Spridgets 4
G Brake Light Switch Failure Austin Healey 24
R Wanted Bugeye ignition switch Spridgets Classified 2
B Headlight Dip Switch Austin Healey 4
M Which wires fit which terminals on my Rover V8 ignition switch? Rover / Land Rover 6
R Electrical Experts - Vixen 2500 - Ignition Switch Observation? TVR 10
S Overdrive Throttle Switch Austin Healey 4
SherpaPilot TR6 Ignition Switch Question Triumph 13
Popeye General TR Connecting to Lucas switch grub screws? Triumph 5
C MGB-GT Reproduction light switch MG 13
timsgolf Center Dash Switch Plate Painting Austin Healey 5
adcronin For Sale MGB Turn Signal (lights, horn, indicator) Switch, New for 62-67, also Sprite MK 3 & 4, MIDGET MK 2-3 thru 67 MG Classifieds 0
R Bugeye Starter Switch Spridgets 7
B General MG Remote Starter Switch MG 6
P TR2/3/3A ignition switch smoking Triumph 12
O XKE series 2 thermo fan switch bung stud repair. Jaguar 9
6 E-Type brake light pressure switch location Jaguar 5
C TR6 Ignition Switch for 1972 TR6 Triumph 1
Bocaray TR2/3/3A Headlight Dimmer conversion to dash switch Triumph 6
K TR2/3/3A The two wires that go to the brake light stop switch junction......... Triumph 1
algot1901 1950 Prefect Ign Switch Other British Cars 1
S TR2/3/3A What temperature of electric fan switch do you use in your radiator? Triumph 3
