Turn Signals , Brake Lights, Off Switch - Yikes
stretchit2
Fellas,
This is a long story (electrical yikes!), but to be brief since I bought my car (61 MKII BT7) I have had it changed to a negative ground (and everything that goes along with that),& an electronic ignition, it now has an alternator, and I just had a new off switch installed. This work was done sequentially and not at the same time.
Since having the alternator installed I have been having an intermittent problem with charging the battery, sometimes it did and sometimes it did not (the idiot light is always on). During this time I noticed that the off switch didn't work like I think it used to. With the switch in the off position everything still worked, except the car would not start. I think when I first got the car when the off switch was off, nothing worked.
Anyway, I had the switch replaced today, and dummy me I didn't check how it worked at the mechanics. I was so caught up in the moment I simply drove the 15 miles back to my house (it was a great day today in So Cal, somewhere in the mid 70's -sorry, I digress). Driving home I noticed that my turn signal indicator was not working, so once at home I checked and neither the turn signals nor the brake lights worked. I then checked the newly installed off switch and discovered it did not turn off any of the things I thought it should turn off, pumps, lights, etc.
So I have two questions:
1) Does it sound like the off switch is still not operating properly? and,
2) When installing the off switch could the mechanic have done something to effect the turn signals and the brake lights, and if so what might that have been?
Technically that is three questions.
Your novice friend,
Stretch
Hi Stretch,
First, if the Cutoff switch is off, it should interrupt the ground connection at the battery. Without a grounded battery, no battery current should be flowing through the car and, therefore, no electrical device should be able to operate.
Second, I assume your alternator contains an integrated regulator. If the idiot light is on, the alternator is not activated and the regulator is completing the ground for the light to illuminate. When the alternator is charging, a current is supplied to this line and, without a ground connection the idiot light does not light.
Since your alternator charge problem seems to be intermittent, I would first check the fan belt for tightness (remember, a belt may seem tight but will slip when resistance is applied as a result of an electrical load requiring the alternator to work). If the fan belt is fine, I would run tests on the regulator to make sure the alternator is functioning properly. I assume that you have a battery ground or the car would not start.
Lastly, is your brake and signal lights only failing at the rear with your front signals working or is the problem causing both the front and rear signal lights to fail? If only at the rear on the side of the Cutoff switch, I would first check your right light connections. If the failure is at both sides in the rear, I would check the connections at the left and also at the engine firewall where the rear harness is plugged in.
Based upon all your problems, I would look closely at the Cutoff switch that has been recently installed and, in specific, use a multi-meter to make sure the switch is providing a secure ground when in the on position.
Good luck,
Ray (64BJ8P1)
jfarris TR2/3/3A Modified turn signals/brake lights on a 56 Triumph 6
Martinld123 Brake Lights But No Turn Signals Austin Healey 9
J TR2/3/3A Add brake light to Rear turn signals Triumph 12
RJS TR4/4A Electrical Question - brake lights, fuel/gas gauges, turn signals failed Triumph 9
J MGB Electrical issue- turn signals dim and cause the brake warning light to flash MG 8
B oh curmbs! turn signals and brake lights were... MG 14
TimK Brake lights/turn signals/DB10 Relay issues Austin Healey 5
C Wedge TR 8 Turn signals and brake lights. Triumph 12
Carlbanan56 MGB Mgb turn signals MG 17
K 68 midget. No horn, headlights, turn signals Spridgets 9
J MGB help, turn signals do not work MG 3
bighealeysource Turn Signals Austin Healey 21
doakley Spitfire Turn Signals Triumph 3
BierRunner TR6 Turn Signals/Hazards don't work Triumph 16
Got_All_4 TR5/TR250 Lost Turn Signals Triumph 2
BoyRacer LED Turn Signals Austin Healey 5
E MGB Turn signals 65 mgb MG 4
W MGB Turn signals on 78 MGB MG 3
T TR2/3/3A Turn Signals Blinking too fast Triumph 2
D MGA MGA turn signals MG 3
T TR2/3/3A What causes fast flashing turn signals when all bulbs & indicator light are flashing? Triumph 15
R BT7 turn signals Austin Healey 5
KVH TR4/4A Rear Turn Signals are Blinking In Reverse Triumph 2
Joe Schlosser LED Turn signals Austin Healey 9
Jim_Gruber BE Quiz for Today - Beehive front Turn Signals take a ? possibly 6/32 screw Spridgets 1
Jim_Gruber BE Quiz for Today - Beehive front Turn Signals take a ? possibly 6/32 screw Spridgets 2
Joe Schlosser BugEye turn signals Spridgets 5
vickxxx T-Series turn signals for MGTD MG 5
jfarris TR2/3/3A Front Turn Signals / Marker lights Triumph 3
Jim_Gruber Turn Signals and Flasher Lamp on Dash Spridgets 8
G BJ8 Phase II conversion to LED turn signals Austin Healey 11
A When were turn signals original equipment on Mk1 Bugeye Sprites? Spridgets 4
L TR6 No power/not enough power to turn signals, wipers Triumph 8
Crankshaft TR2/3/3A Loss of power to wipers ad turn signals? Triumph 11
5 TR2/3/3A LED bulbs w/turn signals problem Triumph 4
bobh Faster Turn Signals Triumph 2
Morris A lesson in turn signals... Spridgets 4
I No turn signals Triumph 17
B Turn Signals Austin Healey 2
HealeyRick Turn Signals Not Working Austin Healey 6
Jim_Gruber Turn Signals have stopped working Spridgets 25
Anthony_S Turn signals and indicator light Triumph 11
coj Electrical system - turn signals - green light Austin Healey 1
apbos Speedwell Bonnet turn signals Spridgets 13
N Please help! turn signals. Spridgets 20
N Turn signals on the "blink" Triumph 4
King_of_England Clubman turn signals British Motor Corp 1
Brooklands TR2/3/3A Front Turn Signals on TR3B grill Triumph 7
spnx amber SP250 turn signals Other British Cars 5
