tube shocks part #
wdp
Anyone have the part number for tube shocks for the rear of a MGB?.....I know I know, it isn't stock but the car came that way and I need new shocks and don't even know whats on it now.
Oh yeah, the shocks are yellow if that helps.
Yellow usually equals Monroe...pull one, clean it up & take to a Monrow dealer...he can take their numbers (engraved on the side) off it & trnspose to parts numbers.
Spax are partly yellow too. I just looked at them on Moss's site, but didn't see a link for just the shocks.
The problem is there are no numbers on these shocks. It looks like at one time there was a tag on them, but it is long gone.
Thanks anyway.
You could probably take it to a Monroe dealer, as Tony suggested, anyway for him to match it to a replacement, without the number! I don't think I'd use a gas charged one though! Might make a "B", which has no weight in the back anyway, ride a little stiff in the rear. JMHO. PJ
I did some checking on getting a shock that fits while I was working at a parts store, and found that the Monroe Sensa-Track part number is 5877ST.
One problem with this part number is that the upper hole may not be the same size as the shock you have.
Hopefully this helps.
It would be a lot easier and perhaps cheaper in the long run to simply bolt an original style set of lever shocks on the car. Experimenting with tube shocks not designed specifically for your B may prove frustrating. You may get lucky, or you may end up with a rough ride and poor handling like most tube shock kits provide.
Sorry I can't help with part numbers but there is no way to know what you have there. Good luck!
The other advantage of replacing with Armstrongs is that he'll never be in this position again - the lever shocks will never wear out as long as he ownes the car if he keeps them topped up (and if they did, at least he'd know what they were for replacement purposes).
Buy them from Peter C. and they will never need to be topped up. His rebuilds come with a lifetime guarantee. Try finding that in a tube shock! :smile:
:lol:
How right you are, Steve!
...'cept for some Koni's. And THEY ain't cheaper.
Koni, and KYB both offer lifetime warranty. At least they did. It's been so long that I've had to install shocks I don't know where to look for the paperwork.
My long term plan was to get shocks from Peter C. but in the short term was looking for a quick tube shock replacement. The tube shock hardware is all ready installed.
With 3 MGs and a Metro to maintain, plus keeping SWMBO happy I was trying to take the easy way out.
Thanks for all the suggestions and help!
DrEntropy said:
:lol:
Indeed.
I switched to Konis about 5 years ago and I'll never go back to levers, no matter what the warranty. They're cute/novel for the purist set, but IMO nothing beats an adjustable Koni. Except perhaps a Ron Hopkinson coilover, which I was too cheap/lazy to fit :smile:
Except a remotely adjustable Armstrong lever shock. Adjust them right from the cockpit with no modification to the car necessary. Plus, you get a shock designed for the car that fits at the correct angle. Nothing beats that!
Not on MGB what? Adjustable levers? Sure you can! They were a competition option in the 60's, and you can get repros from Worldwide.
Morris An argument against tube shocks... Spridgets 2
B Tube Shocks Conversion Austin Healey 19
KVH Replacing Rear Lever Shocks with Tube Shocks Triumph 24
Morris Tube shocks on all four corners! Spridgets 13
AUSMHLY After market rear tube shocks Austin Healey 28
davester MGB MGB rear tube shocks...which ones? MG 18
mgbmedic MGB rear tube shocks for MGB MG 20
C Shocks: Rebuild Lever Arms or Tube Conversion??? Triumph 23
R TR6 TR6 rear ride height with tube shocks Triumph 5
T tr4-rear tube shocks Racing 2
bobmga62 MGA Tube Shocks form MGB to MGA MG 4
R Tube Shocks Triumph 14
C Tube Shocks on Midget? MG 1
aeronca65t Spridget Tube Shocks Austin Healey 8
tinman58 TR2/3/3A Vent tube Triumph 3
J MGB Jet Tube to Float Chamber Fuel Leak MG 7
K TR2/3/3A The Amco chrome tube type grille ....... Triumph 9
D Capillary Oil Tube Fastener Austin Healey 5
P MGB Tube axle wear MG 3
M Capillary Tube repair Spridgets 4
AUSMHLY BJ8 Overdrive Accumulator Spring Tube Austin Healey 1
G Stator Tube Nut and Olive Austin Healey 9
Cutrog1 BJ8 Fuel Tube Installation Austin Healey 10
P Classic Tube Pre-Bent Brake Lines Austin Healey 5
71TR6 TR2/3/3A TR3A Breather Tube Attachment Triumph 6
C TR2/3/3A stator tube Triumph 6
B TR2/3/3A Control Head/Stator tube orientation Triumph 8
M TR2/3/3A Removing Wires From Stator Tube Triumph 7
K TR2/3/3A Making your own steering wheel stator tube? Triumph 16
aero3113 For Sale Big Healey Tube Shock Conversion Austin Healey Classifieds 2
T TR2/3/3A Can someone confirm size and thread count on fuel line tube nuts [brass fittings]? Triumph 16
Jim_Gruber Pages from Porter Spridget Restoration Manual on Seat Recovering, You Tube Videos Spridgets 4
D TR2/3/3A stator tube will not go down Triumph 0
AUSMHLY Tube vs Tubeless discussion :] Austin Healey 28
F TR2/3/3A Tie member[front apron support tube] Triumph 11
S Wanted stator tube Austin Healey Classifieds 0
S stator tube nut Austin Healey 7
D Best little tube bender Restoration & Tools 8
D TR2/3/3A tr3 temp guage capillary tube thread size Triumph 3
K TR2/3/3A The rear axle "tube" seal replacement. Triumph 6
D You Tube made me do it. I bought a Milwaukee dry cut saw. Restoration & Tools 6
K For Sale Curved tube intake manifold...2" Triumph Classifieds 2
M Questions about stator tube and trafficator fixation Austin Healey 31
X BE jacking tube access holes and top bows. Spridgets 1
Sarastro General TR How is the axle tube attached to the diff housing? Triumph 16
D BT7 stator tube Austin Healey 39
J TR6 TR6 Cross Tube Differences? Triumph 6
R Capillary tube temp gauge Austin Healey 7
