Triumph Overdrive Shift Knob and Lever
Bruce_B
The Spitfire has a working overdrive switch on the dash that I'd like to move to a Shift Lever Knob with the OD switch built in.
Is the lever and the knob available aftermarket., or do I have to shop around on ebay.
Is it just a question of routing the wires up the lever to the knob?
Thanks...
Bruce
RobT
The stock units with the O/D switch in the knob were hollow with the wires running up inside the lever itself.
This setup was used on the later model Triumph sedans with O/D - I had a Spitfire and fitted a Triumph Dolomite O/D box with this setup. EBay or UK parts dealers are probably your best bet.
Dennis
You can get the knobs, canley's ( www.canleyclassics.com ) has them, found under their product updates. I'm not sure about getting the shift arm though. Ebay has them every now and then. I don't believe I have one in my spare parts but I'll look.
Dennis
SpitBang
billspit
They can be pretty expensive off ebay as they are no longer available through local sellers. As above, they are available through Canleys.
If you don't like it on the dash, you can put it on the steering column. I believe all the proper items for that are available.
DougF
If used is okay, try Scott Harper at Team Triumph in Warren, OH. (330)392-7176
Trevor Triumph
My wife's Spitfire has the O.D. switch on the sterring column which is correct for a MkII. She has a later transmission but the cap on top of the shifter is quite expensiove we were told. Roadster Factory has the column switch.
tdskip
Bruce - if I know the car in question then shifter is original and has room for the wiring. The shift knob appears to have been broken at some point hence the relocation of the O/D switch to the dash. You should be OK with just a new knob with the built in switch.
Bruce_B
Bruce_B
tdskip,
if you're correct and it is the car in question then that's good news. Someone I know had told me to wait until I get the car before ordering stuff. That's good advice.
Thanks to all for information.
tdskip
Bruce_B said:
tdskip,
Ha!
Order away my friend, order away...
S TR2/3/3A Triumph tr3 overdrive wiring Triumph 9
John_Mc MGB overdrive for triumph? Triumph 13
2wrench Is a Triumph overdrive tranny all that? Triumph 154
D Triumph Overdrive Manual ebay Triumph 0
T TR4/4A Triumph TR4A 1965 price Triumph 8
M For Sale 1971 Triumph Tr6 Triumph Classifieds 0
J For Sale Triumph TR2 TR3 rocker panels, right and left Triumph Classifieds 0
J SOLD!! Triumph TR2 TR3 Channel - Drip - Rear Edge Triumph Classifieds 1
Charlypm For Sale 69 Triumph TR6 Racecar Triumph Classifieds 1
J TR4/4A Vintage Triumph Register Build Codes Triumph 6
J SOLD!! Triumph TR 2 TR 3 windshield stanchion mounting plates Triumph Classifieds 3
oldbagpipe For Sale 1961-1962 Triumph TR4 Short Bubble Bonnet (hood) Triumph Classifieds 0
oldbagpipe For Sale '2' Triumph TR4 engines Triumph Classifieds 9
motzart007 Wanted In search of used seats for 1969 Triumph Spitfire MKIII Triumph Classifieds 1
C For Sale 1963 Triumph TR3b-TCF Triumph Classifieds 5
tr6nitjulius General TR 1/1/2024 in TRIUMPH Triumph 0
pbraun For Sale Triumph TR 250 Project Triumph Classifieds 0
R For Sale FS: Revolution 5 Spoke Wheels (Triumph) Other British Classifieds 4
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
tr6nitjulius General Tech TRfest 9/7-10th 2023 (150+ TRIUMPH Only) Triumph 6
R TR6 Triumph vin tag information Triumph 7
L For Sale British car collection for sale Morris Minors, Triumph Other British Classifieds 0
L For Sale 1961 Triumph Herald Saloon Triumph Classifieds 0
L My 1951 Triumph long ago British Motorbikes 0
tr6nitjulius TR6 TRIUMPH invades Redmond, Or for ATDI 2023 Triumph 4
Hamish Racing General TR At last a New Triumph Triumph 2
Got_All_4 General TR New Triumph Concept Car TR25 Triumph 14
tr6nitjulius General TR TRIUMPH TR6 the possibilities! Triumph 12
XJtom General TR Triumph items of interest Triumph 2
B TR6 Triumph tr6 coolant leak Triumph 4
Gatheringtree TR2/3/3A Billet Pedal Cover Set w/ Triumph logo Triumph 0
D For Sale 1974 triumph spitty davidschab60@gmail.com Triumph Classifieds 0
Gliderman8 General TR Triumph emblem? Triumph 13
D TR2/3/3A Drive your Triumph day photo Triumph 6
AngliaGT General TR You Might Need Snow Tires for This - Drive Your Triumph Day 2023 Triumph 5
F For Sale Four Steel Wheels Triumph TR3 or TR4 Triumph Classifieds 5
J For Sale Triumph TR2 or TR3 elbow trim Triumph Classifieds 0
J For Sale Triumph TR3 door, left, for sale Triumph Classifieds 0
S TR2/3/3A Triumph TR3 Tail Light Issue when Headlights and Brakes are On Triumph 15
D For Sale Triumph GT6 for sale (possibly one of the worlds finest examples) Triumph Classifieds 2
S For Sale Triumph TR 2-3 Front Left Fender Triumph Classifieds 2
KVH General Tech Making the Triumph Engine Dolly Triumph 4
P Post-War Other Triumph Herald Engine ID Triumph 2
P Spitfire 1979 Triumph Spitfire starts then runs rough Triumph 2
J TR4/4A 1964 Triumph TR4 - Not Starting/Running Triumph 3
