Hi All,
I will be removing my BT7 side shift transmission within the next few weeks to rebuild it, primary the replacement of synchronizers and bearings. It’s been close to 35 years since I last had this transmission apart, so my memory has essentially vanished. I will be sending the overdrive out for disassembly, inspection, and any overhauling that may be required.
Any advise, suggestions, hints, or other comments that may ease the process would be greatly appreciated. One thing I wish to confirm, is that the transmission/overdrive unit can be removed by lowering it from underneath the car.
Thanks,
Ron
Thanks,
Ron
