Morris
I have the top plate off of my 1500 tran, and everything looks pretty good. The reverse gear is showing some wear, but everything else looks pretty tight to my untrained eye. Are there any tell-tale signs of wear I should be looking for?
My gears typically grind when going from 1st to 2nd under hard accelleration. I thought it might be the synchro rings, but they appeart to be fine. Is there something else that could be causing this problem? How can I tell if the rings are worn?
Finally, my throw out bearing is solid, but all the grease has turned hard and brittle. Would it be stupid to attempt to clean the bearing and repack it?
Thanks guys.
Thanks guys.
