I recent bought a TR3/TR4 pump w/ priming lever from one of the big three and couldn't get the outlet to stop leaking. Tightened it, Tightened it, and tightened it some more, but I couldn't do anything to stop the leak. I took it off and looked at the threads in the pump and came to the conclusion I made a $55 mistake. The inlet side looked fine.
So I ordered another one but before I did anything I looked at the threads in the outlet. It looked horrible, and it was plainly clear that mating surfaces were not only all botched up, but not even centered. Again, the inlet side looked perfectly fine. It was not someone elses mistake, as I could tell it had never been installed. Clearly, the manufacturing process of the pumps was screwed up, and what I dismissed as my fault on the first pump was most likely a manufacturing quality control snafu. I sent it back and got a full refund.
