Hi Guest! If you enjoy and benefit from your participation at British Car Forum, please consider supporting our efforts with a subscription. There are some perks with a member upgrade!
It is until you get to the carb inlet. A rubber hose probably an inch or two long is used to connect to the inlet. If you try and use rubber hose for the entire length the hose may melt and cause your car to melt.
Harry
CT
Geo Hahn is right. After todays ride I looked at the fuel line and it is indeed 1/4 inch from the pump outlet to the carb. Now its the eyes I wonder what's next? Sorry for dragging this to the top again I didn't want any confusion.
