TR4/4A Fuel Tank, Fuel line question, TR4
Hi Larry,
Mine TR4's fuel tank is no longer anywhere close to original, so I can't be totally certain. But if I recall correctly those are very standard plumbing parts available at just about any good local hardware store.
I have the same question.
I just replaced my tank and entire fuel line. I looked everywhere locally for that fitting, and called Moss, too.
I just couldn't find it, and I tried specialty shops.
I can't recall exactly how, but I did find a "backup" of sorts. It was a line nut meant for a flare fitting that I coupled with another part. In the end I just used my original part.
I think the TR4 part was either whitworth or pipe thread of some sort. Everyone locally shrugged when I showed it to them. If anyone knows a good source, it would be useful.
By the way, isn't the fitting at the fuel pump the same thing?
Outside chance, but you might get help from Classic Tube
I don't see the fuel line for a TR4 listed in their catalog, but they have TR3/TR5/6 lines and also a bunch of miscellaneous fittings available.
Randy
It's not available because I believe you can get it at any NAPA outlet store. For my 3 I purchased 2-10 foot 5/16ths inch steel fuel lines and bent to fit (NAPA Part Number 813-1235). They were standard pipe size with fittings and flared at both ends. I attached the two ten foot lengths with a double end flared connector fitting in the middle. I see the 4 uses 3/8ths rubber hose and clamps for connecting the pipes. rubber scares me. If you have original fitting bring it to NAPA and find someone knowledgeable to help you. I believe the fitting is called a 5/16 male npt to accept a standard single flared end which shoves up into the tank and the fitting screws up pressing the flare to the end of the fitting protruding from the tank. If the flare won't seat you can also use a compression type fitting here but I prefer the flared end because there is less chance for leaking. It's been seven years (Ok, four years I found the reciept) since I did this so my terms maybe a bit confused but that is definitely where I bought my fuel lines.
If I'm wrong about the size I sincerely apoligize in advance. Like I said it fits my 3 and I think the early 4 fitting is the same. Worth a shot I think.
Harry
CT
I ordered fuel lines for my TR6 from Classic Tube about 5 weeks ago. Three weeks ago I called to see if their was a problem and they said there was a 3 week backlog. I hope its due to the fine product they produce. But if your in a hurry.....
Hi again,
I suspect that even originally Triumph Spares didn't sell those pipe fittings separately, but as a small sub-assembly that included a short piece of piping with the fitting already flared on.
You might check www.rimmerbros.co.uk/ and https://www.moss-europe.co.uk/MossUK/ for small parts like these. The small stuff isn't too expensive to ship from England (the big stuff gets pricey). Larger items like the longer runs of fuel pipe can be bought locally and shaped to fit, I'm sure.
I suspect my TR4 has the original "bung" in the fuel tank, but really don't know if it's British pipe thread or US. FYI, even if it's BSP, that's so close to USP it's a common practice to use one in the other. In fact, some do this deliberately since it makes for a connection that's unlikely to ever shake apart. A little Locktite thread sealant can be used to insure no leaks, but the two threads are close enough it's usually not necessary.
I took a different approach with my TR4. It's certainly not "original", but I've now got a USP-thread-to-AN6 fitting on the bottom of the tank, an AN6 hose running from that to a Fram FP-1 filter, then to an elec. fuel pump, and next all the way to the engine compartment where there is a Holley fuel pressure regulator, then on to the carbs. Using stainless steel braided AN6 "aircraft" hose throughout makes add some security against any rock damage leaks, etc. (and it looks pretty cool!). A downside to using stainless steel braided hoses is that they are pretty abbrasive anywhere they might rub. I fitted larger dia. rubber hose over the section where it passes through the frame rail and used a lot of rubber-cushioned clamps elsewhere to prevent any rubbing.
Some (all?) TR4 have a second bung in the bottom of the tank, on the opposite side, intended as a drain. I've noticed TR6 tanks without the second outlet, but am not sure about other models or exactly when the change occured. I mention this because it would be possible to use as an outlet, if the original one were too messed up. Eventually I think I'll add a second AN6 pickup there on my car and use a tee to feed the system from the tank in two places, one on each side, which should prevent any surge issues when goin' round corners faster than I should (a TR4 tank already has surge baffles inside, too, which certain later cars don't).
If it is really impossible to find any sort of fitting for the tank, that will thread into the bung properly, it wouldn't be all that hard to remove the bung and replace it with one that has more widely available threads. The tank metal is pretty thin stuff, and pretty difficult to weld. I think originally it and it's fittings were all soldered together. But brazing will also work. A radiator shop might be helpful, if you don't have the tools and skills to do the soldering or brazing yourself.
Of course, be extra careful welding, brazing or soldering around any fuel tank. If it's had fuel in it lately, it should be repeatedly rinsed out with soapy water to insure there is absolutely no remaining fuel or fumes. Even then, carefully test before getting close to it to do any work with a torch.
And, be very careful trying to loosen any of the fittings, top or bottom. They often rust/weld themselves in place and it's way too easy to torque the soldered bung right out of the sheet metal. (Don't ask how I know!) Use lot's of penetrating oil on the fitting, possibly over the course of a week, before trying to remove it. And, try to avoid applying heat - to help loosen the threaded fitting - just a little too much will melt the solder.
Before investing too much time in an old tank, you might want to closely inspect it inside to see if it's really usable. Rust can cause all sorts of problems in the fuel system. Any seriously scaling rust might mean tank replacement, as it will make for weak points, potential leaks and flkes of rust can cause havoc in the fuel system. Surface rust can be neutralized and then coated with special compounds just for the purpose (www.eastwoodco.com sells fuel tank restoration kits). But I've heard this process is only good for about 5 years additional tank life before the coatings start to fail, too, and then they might themselves cause blockage or restrictions in the system.
Replacement tanks are available, if somewhat pricey. Some appear to be pretty close to the original. If changing it out, to me it makes sense to go to aluminum or stainless steel (altho the latter would be too heavy, IMHO). I've toyed with the idea of making up a tank/fuel cell from aluminum, but am not very knowledgeable at shaping and welding the stuff yet (so might take a welding/auto body class at a community college and make it my class project). We'll see.
Back on track, hopefully you can find the fittings at one of the British suppliers (or elsewhere). You might also call or email John Swauger at TRF's second level sales line, see if he can suggest some alternatives.
SherpaPilot TR6 Preping a New Fuel Tank Triumph 7
Frameman 1949 New Moss Motors Fuel Tank Austin Healey 10
Editor_Reid Fuel Tank Interchangeability Austin Healey 2
BoyRacer Fuel Tank Sending Unit Austin Healey 3
B TR6 Fuel tank replacement Triumph 0
JPSmit Fuel tank sender - how does it work? Spridgets 4
S Large capacity fuel tank Spridgets 1
MGTF1250Dave T-Series MG TF fuel line from tank to pump MG 3
JPSmit Fuel line - gas tank question Restoration & Tools 5
M TR2/3/3A Fuel Line Fitting at the Tank. Triumph 5
Ljohns New Midget/Sprite Fuel Tank Austin Healey Classifieds 1
Michael Oritt Fuel tank safety Austin Healey 18
BoyRacer Fuel tank sealing rubber is too thick Austin Healey 3
R Jensen-Healey Fuel Tank Questions Other British Cars 17
Martinld123 Fuel Tank Cap 100 BN2 Austin Healey 7
F Wanted 1960 Triumph TR3A fuel tank Triumph Classifieds 5
wkilleffer MGB Classic Gold fuel tank drain plug MG 12
SD Bugeye Half capacity of the fuel tank Spridgets 10
B TR2/3/3A Fuel Tank Venting Triumph 8
Zimmycobra For Sale Original 1966 TR4A Fuel Tank Triumph Classifieds 0
L T-Series TD Fuel Tank MG 2
NutmegCT Fuel tank cleaning/restoration Restoration & Tools 47
H Bugeye fuel tank sending unit - repair or replace Spridgets 5
sim fuel tank sender reading full all the time Spridgets 9
Basil E-Type fuel tank mounting bolts [$&^##$%*!!] Jaguar 16
J Bugye Fuel Tank Leak Austin Healey 4
Basil About to re-install my fuel tank Series I E-Type Jaguar 6
Popeye TR4/4A Found this odd long bolt in my fuel tank... Does anyone know what it is? Triumph 17
T Wanted Jaguar MK2 fuel tank and Radiator Jaguar Classifieds 8
T TR4/4A Fuel tank venting Triumph 1
L 100/6 BN4 Fuel Tank feed Austin Healey 5
Popeye Engine starving for fuel before tank is empty - 2001 Audi TT Other Cars 5
T TR2/3/3A Late Fuel Tank in Pre-TS60000 TR3A Triumph 3
R Fuel tank straps Austin Healey 15
Got_All_4 TR2/3/3A Has anyone tried to rewind/fix a fuel tank sending unit? Triumph 11
L Fuel Tank sender 100/6 Austin Healey 8
Got_All_4 TR2/3/3A Fitting the trunk floor pad & fuel tank cover Triumph 2
K TR4/4A Fuel tank options Triumph 4
O TR2/3/3A Fuel tank vent Triumph 1
Csarneson BN4 Longbridge Fuel Tank Austin Healey 15
E TR4/4A TR$ Fuel line from tank Triumph 13
rjc157 Fuel tank sender Austin Healey 13
S Hot tip: seal for fuel tank sender Austin Healey 9
B Fuel tank woes Austin Healey 4
catfood BN1 Fuel tank straps Austin Healey 5
TulsaFred Fuel Tank fitting and nipple Spridgets 6
catfood Fuel tank question Austin Healey 1
C Full tank but no fuel!!!!! Austin Healey 15
W Fuel tank compatibility Spridgets 4
