TR4/4A TR4 door checkstrap replacement.
joejoecat
Has anyone ever tried to replace the door checkstrap on a TR4? I can't seem to get it out .It has a spring clip that appears to be held on by some type of rivet that I can't remove? Any help would be appreciated . thanks
Gliderman8
I replaced my checkstrap on my TR6 which I believe is similar (or the same) for the TR4.
Rivets have to be drilled out. I am sure you can probably
re-rivet them, but I chose to use machine screws lockwashers and nuts.... it was a lot easier.
MDCanaday
They are not like a 6 at all.but you make the job easy in the same way as a tr6. First cut the old strap in half so the door can be removed/swung out farther. Then you can destroy the rivet.Be aware the new parts often come with METRIC threads if you try to re-use your old hardware you will come to grief!!!! The new parts look so nice for a year or two then go quickly to hades and must be refreshed every so often......
MD(mad dog)
Trilashfour
I just replaced my TR4 door checkstraps and used a machine bolt with nylon threaded bolts to secure them to the door. The checkstraps make a loud pop as I open or close the door. Do I need to replace the spring clip to stop this noise? If so how do it do that? Thank you.
charleyf
There are two very different check straps used on the TR4. Early and late.
Which do you have? A picture would help.
Charley
Trilashfour
Thanks for your response. The Moss part number is 803-030. They seemed to fit okay.
charleyf
You have the late style. I have the early style which was changed mid production. Due to what I would call a poor design. So I am no help to you here.
Charley
mctriumph
I have changed lots of early style straps.The replacements are only so so at best.And offer the advantages
of metric threads so you can accidently ruin them with the old bolts.
Mad dog
Popeye
Bronze
Yours look like they should “pop” when opening and closing. The spring snaps over a step to keep the door open.
charleyf
Mad dog
Mad dog
Attached is a pic of the "early style door check strap". I suspect you are referring to the late style. If not then where are you getting your replacements?
Charley
mctriumph
My Tr4 was CT143XX built April 62. Yes I had to change the early straps more often than
one would have wished.
Mad dog
Lotuswins TR4/4A Is this normal? TR4 gap between door and cowl Triumph 10
Zitch For Sale TR4 - old door cards Triumph Classifieds 0
M TR4/4A TR4 door glass spacer wires. Triumph 1
Gerald_Gordon TR4/4A Failure of new door-check strap on an early 1961 TR4 Triumph 6
M TR4/4A Where to buy replacement TR4 exterior door handles? Triumph 1
Tim Tucker TR4/4A TR4 Door Hardware Color Triumph 2
M TR4/4A Tr4 Tr4a door handles Triumph 2
H TR4/4A Tie Rod In Door - TR4 Triumph 5
TR4A_IRS TR4/4A TR4/6 Door Fitting Triumph 3
TR4nut TR4/4A Anyone have any spare TR4/4A door glass? Triumph 12
TRMark TR4/4A TR4 Door Restraint Triumph 3
M TR6 tr4-tr6 door switches Triumph 3
71tr TR6 TR4 door handles on a TR6 Triumph 4
F TR4/4A TR4 Question: Door check strap pin Triumph 5
S TR4/4A TR4 Door Check Straps Triumph 4
A TR4/4A TR4 A wood glove box door question Triumph 0
SCguy TR4/4A TRIUMPH TR2 TR4 DOOR RESTRAINT ASSEMBLY Triumph 1
toysrrus TR4/4A My TR4 got "CRUNCHED" Today!!!!! Need Door!!!!! Triumph 46
M TR4/4A TR4 Door compatability Triumph 3
M TR4/4A TR4 Door Seal channels Triumph 4
TR4 TR4/4A TR4 Door Fit ? Triumph 2
R TR4/4A 1963 TR4 soft hood cover with attached plastic stiffeners Triumph 2
T TR4/4A TR4 seat buffer problem Triumph 5
KVH TR4/4A TR4 Movie Showcase Triumph 3
oldbagpipe For Sale 1961-1962 Triumph TR4 Short Bubble Bonnet (hood) Triumph Classifieds 0
oldbagpipe For Sale '2' Triumph TR4 engines Triumph Classifieds 9
scottkilpatrick TR4/4A Send Unit Issues - 62 TR4 Triumph 4
E TR4/4A What Flare to put on a TR4 Brake Line Triumph 2
EvansClassicCars For Sale 1966 TR4 Triumph Classifieds 0
S TR4/4A TR4-Stromberg throttle shaft play Triumph 3
scottkilpatrick TR4/4A Difficulty Level Opinion - Differential Gasket Replacement 62 TR4 Triumph 10
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 - Part 2 Triumph 8
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 Triumph 10
mctriumph TR4/4A earliest Tr4 ?? Triumph 0
Got_All_4 For Sale TR6 TR250 TR4 parts for sale Triumph Classifieds 2
D TR4/4A TR4 inner ball joints Triumph 8
jfarris For Sale TR4 Fuel Gauge with 2 Transmitters Triumph Classifieds 0
mctriumph For Sale hood for early Tr4 Triumph Classifieds 0
KVH General Tech Jacking Up The Rear of TR4 Triumph 5
Rod-H TR4/4A TR4 Body Number Plate Supplier Triumph 6
F For Sale Four Steel Wheels Triumph TR3 or TR4 Triumph Classifieds 5
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
KVH General Tech Issues with Distributor--TR4 Triumph 13
Tim Tucker TR4/4A Konig 16x7 wheels and leaf spring clearance for TR4 Triumph 5
MTr4 TR4/4A In search of a 1962 TR4 Triumph 2
A For Sale 1963 TR4 for sale Triumph Classifieds 0
Cokerair TR4/4A Searching for "How To" instructions for TR4 Tonneau Triumph 5
J TR4/4A 1964 Triumph TR4 - Not Starting/Running Triumph 3
tj_tr3_tr6 Wanted Wanted / Need / TR4 Engine Block for 62 Tim from So California Triumph Classifieds 3
