TR4/4A TR4-A Front grill ... How did you restore yours?
nissanite
My grille is straight with a little corrosion at the lower corners behind the turn lamps. It has many very minute stone dings. You must look very close but you can feel them. With the lamps removed, the panel is very shinny, almost polished. I know from experience after you polish it always needs touching up.
I would use 2000 grit paper & a dremel to polish it if this works.
CinneaghTR
That grille is extruded aluminum so you can be too harsh with it. I use Mother's Mag & Aluminum polish and a rag. You could use a dremel with a polishing head I guess. I started with an NOS grille and the dings just add character, but it is smooth and clean. :yesnod:
HerronScott
I'm with Jeremy on this. I just cleaned and polished mine with something similar to what he posted.
Scott
PeterK
The grille is anodized aluminum so you have to be careful about polishing or be prepared to cut through and remove the anodizing to polish the base aluminum. btdt it's a tedious job around the edges if you get down into the coating.
TDHoward
The anodizing can be removed with old fashioned oven cleaner. "easy off" works very well. Spray on, let sit for a couple of hours, then it'll polish off.
You'll have bare aluminum then and it can be polished to a chrome like shine with patience.
The problem with this method is it needs to be recoated with something clear or it'll begin to oxidize. Clear coat lacquer works fine or you can keep it waxed.
Your grill probably isn't bad enough to go this route though.
I second the Mothers mag polish. With a felt dremel bit, it'll do wonders.
H TR4/4A TR4 front plate seal Triumph 6
Gerald_Gordon TR4/4A Preferred front springs and suspension bushings for mild driving in a TR4 Triumph 3
S TR4/4A TR4 front and rear suspension Triumph 8
M TR4/4A TR4 front coil springs Triumph 0
M TR4/4A Front Bumper for TR4 Wanted. Triumph 3
doughairfield TR4/4A TR4 Front sway bar install question Triumph 9
TR4v8 TR4/4A tr4 front suspension question Triumph 2
Burrell22 TR4/4A Tr4 front end help. Triumph 10
9 Spitfire Spitfire front clip on a TR4 Triumph 17
KVH TR4/4A TR4 Front Sealing Block Triumph 2
S TR4/4A TR4 front suspension shimmy and shake Triumph 8
Tabcon TR4/4A Help with front input shaft seal on TR4 tranny. Triumph 3
K TR4/4A Paging TR4 nut....re front suspension Triumph 2
M TR4/4A Wanted - TR4 Front Fenders Triumph 9
M TR4/4A TR4 Front Suspension Rebuild Triumph 6
SCguy TR6 TR6 front sway bar on a TR4 Triumph 1
T TR4/4A Moss TR4/5/6 front fender patch question Triumph 2
pa297pass TR4/4A TR4 Upper and Lower Front Valance Panel Triumph 6
SCguy TR4/4A TR4 front end alignment Triumph 2
SCguy TR4/4A Early TR4 Front Bumper Brackets? Triumph 1
T TR4/4A TR4 Front Wheel Bearing Triumph 8
T TR4/4A Early TR4 Front Bumper Overriders Triumph 4
Kirk_Fisher TR4/4A TR4 front fenders/engine bay Triumph 13
J TR4/4A TR4 Front Spoiler Triumph 6
T TR4/4A Early TR4 - Front Suspension Trunnions Triumph 7
T TR4/4A Early TR4 - Front Brake Calipers Triumph 2
T TR4/4A Early TR4 - Front Brakes Triumph 3
T TR4/4A what is the ideal front roll center-tr4 Triumph 0
T what is ideal front roll center- tr4 Racing 6
SCguy TR4/4A TR4 front suspension question Triumph 8
TR4nut TR4/4A TR4 front end rebuild - trunnion bushing question Triumph 3
TR4nut TR4/4A TR4 front suspension rebuild advice Triumph 13
TRMark TR4/4A Lowering front of TR4 Triumph 5
mondialo64 TR4/4A TR4 vs 4A front springs Triumph 4
R TR4/4A 1963 TR4 soft hood cover with attached plastic stiffeners Triumph 2
T TR4/4A TR4 seat buffer problem Triumph 5
KVH TR4/4A TR4 Movie Showcase Triumph 3
oldbagpipe For Sale 1961-1962 Triumph TR4 Short Bubble Bonnet (hood) Triumph Classifieds 0
oldbagpipe For Sale '2' Triumph TR4 engines Triumph Classifieds 9
scottkilpatrick TR4/4A Send Unit Issues - 62 TR4 Triumph 4
EvansClassicCars For Sale 1966 TR4 Triumph Classifieds 0
S TR4/4A TR4-Stromberg throttle shaft play Triumph 3
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 - Part 2 Triumph 8
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 Triumph 10
mctriumph TR4/4A earliest Tr4 ?? Triumph 0
D TR4/4A TR4 inner ball joints Triumph 8
