TR2/3/3A TR3A Fuel Gauge
CaptRoy
Well I now have the fuel gauge working on the TR3. I received the sending unit from Moss hooked it up and it still didn't read right. I sent the gauge and sending unit to Calif had the gauge rebuilt and calibrated with the sending unit. They arrived today I changed them out this evening. I changed the gauge first and then replaced the sending unit after I hooked it up and made sure it worked. I had to pull the glove box to get to the fuel gauge. The entire job only took 2 hours including putting the tools up.
I have never had panel lights and now I know why. There are no light wires hooked to the gauge. The PO put in a new wiring harness but neglected to wire the lights on the gauges. I think it is the blue/white and I just need to run it in series from the panel light switch...Does that sound right..
The panal lights on a TR3 are mounted to the dash panal. THey shine through "windows" in the body of the gauges. There are only 2 of them for the 4 gauges on the center dash, and are situated on either side of the switches, mid way between the top and bottom gauges on each side.
The Tac and speedo each have two bulbs on the same type fiberboard socket that the panal lights use.
It should be a red wire with a white tracer. The bulbs in the Tac and speedo ground through the gauges, and there should be a ground wire captured under one of the thumb screws on each. the center dash bulbs ground through the panal as they mount in the rings that are part of the panal, and that panal should have a ground wire on a bullet connector attached twards the center of the back side.
Blue and white wires are the headlight circuit. Don't tap that wire.
T Wanted Working Fuel Gauge for TR3A Triumph Classifieds 5
T TR2/3/3A TR3A Fuel Gauge problem Triumph 10
K TR2/3/3A Can a TR4A Fuel Gauge be swapped into a TR3A? Triumph 8
D Wanted TR3A Fuel gauge Triumph Classifieds 4
B TR2/3/3A Fuel gauge issue 60 TR3A Triumph 13
T TR2/3/3A TR3A fuel gauge question Triumph 36
tmc TR2/3/3A TR3A fuel gauge Triumph 5
TR3TR6 TR2/3/3A TR3A FUEL GAUGE Triumph 8
NutmegCT TR2/3/3A fuel gauge / sender TR3A Triumph 25
NutmegCT TR2/3/3A Fuel gauge fixed! TR3A Triumph 7
NutmegCT TR2/3/3A Fuel gauge needle replacement TR3A Triumph 0
C For Sale 1961 TR3A fuel tank Triumph Classifieds 0
kodanja TR2/3/3A 1960 TR3A w/TR4 engine, fuel pump replacement Triumph 25
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
Donald1107 59 TR3A Fuel Pump Triumph 48
F Wanted 1960 Triumph TR3A fuel tank Triumph Classifieds 5
T TR2/3/3A Late Fuel Tank in Pre-TS60000 TR3A Triumph 3
G TR2/3/3A TR3A Electrical Quirks, Flasher, Wipers and Fuel Guage Triumph 4
T TR2/3/3A Is there a special way to get fuel pump off and on a 1961 TR3A? Triumph 4
PatGalvin TR2/3/3A New Fuel Lines TR3A Triumph 2
Anthony_S TR2/3/3A Fuel pump and who knows what else TR3a Triumph 23
R TR2/3/3A TR3A fuel line Triumph 2
R TR2/3/3A TR3A Fuel sending unit Triumph 3
JohnnyMead TR2/3/3A TR3A Routing Fuel Line: Fuel Pump to Carbs Triumph 15
Bremer TR2/3/3A TR3A fuel pump questions Triumph 15
angelfj1 TR2/3/3A TR3A - Fuel Tank Banjo Bolt Triumph 6
bigjones TR2/3/3A TR3A fuel line Triumph 13
JohnnyMead TR2/3/3A TR3A Fuel Tank-Fuel Line Question Triumph 8
ekamm TR2/3/3A Boot closeout for fuel tank tr3a Triumph 13
angelfj1 TR2/3/3A TR3A - Fuel Tank/Boot Fiberboad Panel Triumph 8
M TR2/3/3A TR3A Fuel Pump Refurbish Triumph 20
angelfj1 TR2/3/3A AC Fuel Pump for TR3A Triumph 6
Earl TR2/3/3A Fuel Lines 61TR3A Triumph 2
Geo Hahn TR2/3/3A TR3A Fuel Sending Unit Triumph 1
71TR6 For Sale TR3A Nose Panel Triumph Classifieds 0
Hamish Racing TR2/3/3A TR3a racing up historic Shelsley Walsh Hill climb UK Triumph 2
Hamish Racing TR2/3/3A TR3a in a spin Triumph 9
71TR6 TR2/3/3A TR3A Front Hood Rain Flap fitting Triumph 7
71TR6 TR2/3/3A TR3A Seat Tracks Binding Triumph 5
71TR6 TR2/3/3A TR3A rear shelf carpet Triumph 6
71TR6 TR2/3/3A Unknown holes in TR3A passenger footwell Triumph 11
mctriumph SOLD!! Restored 59 Tr3a Triumph Classifieds 5
D TR2/3/3A TR3A front suspension rebuild Triumph 47
RichB4493 Wanted TR3a overdrive dashboard switch Triumph Classifieds 4
C TR2/3/3A TR3A Electrical problem Triumph 20
trglory TR2/3/3A TR3a spark plugs Triumph 1
P For Sale 61 TR3A Triumph Classifieds 1
D TR2/3/3A 59 TR3A Gearbox lever will not move. Triumph 11
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
mctriumph SOLD!! Project car 61 Tr3a Triumph Classifieds 0
