TR2/3/3A TR3 clutch release bearing
mikebernard
Im in the process of installing a new clutch in my 57 TR3. I got a clutch kit from BP, most of my other parts from Moss. My concern is that the new release bearing is a "slip-fit" onto the new brass bearing carrier. I assumed I'd have to press the parts together, plus i thought there shouldn't be any possibility of movement between the two parts. I can pull the bearing on and off the carrier easily by hand.Any suggestions? Thanks
I agree this should be a press fit. In fact some care is needed when pressing... I believe the technique is to rotate the bearing whilst pressing.
I replaced the bearing as a matter of routine when I replaced the clutch. About 5,000 miles later I had the gearbox off to replace it with an OD box and I found a LOT of slop in the replacement bearing. I had to believe it was not long for this world. It came from Moss and they acknowledged that it (brand 'Green') was from an unsatisfactory supplier and they no longer used them. Anyway, I just put the original 'Made in England' bearing back in there. It lasted 40+ years, so maybe I'll get 40 more from it.
One other thought... I think TRF sells their bearing already pressed onto a new carrier. Removes the issue of proper pressing & fit.
Mike, If you still have the old carrier and or bearing, try testing out the new parts. ie old bearing slips on new carrier equals bad carrier etc., then contact the supplier. But if you're like me and have had these things on the shelf forever, then you need to go to an alternate fix. If it is as you feel a slip fit (maybe just a couple ten thousandths too small)(no wobble) then I wouldn't hesitate to simply use a bit of good quality epoxy. Just degrease the mating surfaces. If you decide to reuse the carrier at a later date, it will still come apart in a press.
S TR2/3/3A TR3 clutch release bearing... from Home Depot? Triumph 12
mountainman TR2/3/3A TR3 Clutch Release bearing Triumph 2
K TR2/3/3A Clutch Slave Cylinder location when TR3 has a TR6 Gearbox? Triumph 16
E TR2/3/3A Tr3 a clutch hydraulics problem, again. Triumph 16
K TR2/3/3A TR6 Gearbox in a TR3.....Use a TR6 clutch disc and pressure plate or Triumph 7
BarryO TR2/3/3A setting up a TR3 clutch slave Triumph 5
mctriumph master cylinder brake/clutch Tr3 Triumph Classifieds 9
A TR2/3/3A TR3 Brake / Clutch Resevior & Lines needed Triumph 2
Lukens TR2/3/3A TR3 clutch issues Triumph 14
K TR2/3/3A TR6 gearbox on TR3: re clutch slave adjustment. Triumph 13
K TR2/3/3A Torque value for TR3 clutch cover to flywheel bolts....... Triumph 2
AHS TR2/3/3A TR3 transmission clutch fork & shifter removal? Triumph 5
T TR4/4A I'm back to the well of knowledge - TR3/TR4/TR4A clutch-transmission confusuion Triumph 10
K TR4/4A TR4/TR3 clutch operating shaft availability? Triumph 2
M TR2/3/3A TR3 clutch hydraulic line routing Triumph 2
mgedit TR2/3/3A Routing of Clutch and Brake Pipes from MC 56 TR3 Triumph 7
Moseso TR2/3/3A Clutch Swallows Air -- TR3 Triumph 32
K TR4/4A Can I fit a TR3 clutch plate&disc in a 4A? Triumph 4
TRclassic3 TR2/3/3A TR3 new clutch? Triumph 6
Kleykamp TR2/3/3A sticking clutch ??? TR3 Triumph 5
T TR2/3/3A tr3 brake/clutch reservior question Triumph 1
K TR2/3/3A TR3 Clutch master and slave bleed issues? Triumph 5
C TR2/3/3A New member and newbie question on TR3 clutch Triumph 26
K TR6 TR6 Trans in a TR3...What about clutch? Triumph 1
mgedit TR2/3/3A 56 TR3 Clutch/Brake Pedals Triumph 4
S TR2/3/3A TR3 clutch pressure problem - not a broken spring! Triumph 3
T TR2/3/3A TR3 clutch slave and clevis Triumph 4
J TR2/3/3A TR3 Lockheed brake/clutch MC bracket... Triumph 11
bigjones TR2/3/3A TR3/4 clutch adjustment and shifting into 2nd Triumph 5
Moseso TR2/3/3A TR3 Clutch Slip Triumph 6
T TR2/3/3A TR3 clutch slave cylinder Triumph 14
mrv8q TR2/3/3A TR3 Clutch Master Cylinder Triumph 20
H TR2/3/3A TR3 Clutch Advice Triumph 11
RedTR3 TR2/3/3A TR3 Clutch Slave Cyl Return Spring Size? Triumph 7
R TR2/3/3A TR3 clutch Triumph 2
M TR2/3/3A TR3 Clutch / Pressure Plate Triumph 2
Moseso TR2/3/3A TR3 Clutch/Brake Reservoir Triumph 4
martx-5 TR2/3/3A TR3 Clutch Pipe Triumph 9
CCURTISS TR4/4A TR3/TR4 Clutch Fork Install Question Triumph 8
Aldwyn TR2/3/3A TR3... Double Clutch or Syncromesh? Triumph 5
RedTR3 TR2/3/3A TR3 Clutch Slave Cylinder Adjustment Triumph 3
RedTR3 TR2/3/3A TR3 Clutch slave bleed screw size Triumph 4
S TR2/3/3A part numbers for tr3 clutch Triumph 8
S TR2/3/3A clutch set up for a tr3 Triumph 3
S TR2/3/3A tr3 freeway clutch Triumph 8
MGTF1250Dave TR2/3/3A TR3 CLUTCH FRICTION DISC REPLACEMENT Triumph 9
T TR2/3/3A TR3 Clutch Problem HELP Triumph 7
G No directional signals or brake lights on 60 Tr3. Triumph 0
T TR2/3/3A Rear Wheel Bearing instillation on TR3 Triumph 7
