Stinky
I'm finally getting around to installing this carpet kit I got from TRF. I've put in a layer of "FatMat", which is same sort of thing as DynaMat. Anyway, I've laid the underlayment kit on top of the FatMat. Should I use a spray adhesive to hold the underlayment in place? Or will the carpet kit hold the underlayment in place? Furthermore, would a spray adhesive even be effective on the foil type stuff that the FatMat is made with? It does'nt seem likely that anything will stick well to that foil.
Thanks in Advance,
Thanks in Advance,
