Tire size 6'' wire wheels\ Unipart oilfilter
kch
I have just bought new 70 spokes 6''x15 wire wheels for my healey 3000 Mk1. Does anybody know what kind of tires that will look good with these wheels.
And I have bought oilfilter adaptor to fit the filter straight on to the engine block. It comes with filter from Unipart GFE 264. Does anyone know what kind of oilfilter this equals from Fram, or any other filter companies /ubbthreads/images/graemlins/cheers.gif
Karl, Oslo, Norway
John, your Healey looks great. The tires fill out the wheelarches nice.
What brand of tires do you have ?
Is that 5,5" wheels or 6" wheels ?
Hi Karl,
I have no opinion on the tires.
The following filters are listed as fitting a TVR V6. Not your car but same Unipart filter.
Unipart GFE264
Fram PH2854
Crossland 547
Coopers Z501
Motorcraft EFL38
Maybe this will give you a start. Good luck,
[ QUOTE ]
Karl, Oslo, Norway
[/ QUOTE ]
Karl--
i purchased the spin-on adapter from MOSS and use a K & N #2009 filter.
The tires are Riken, the rim width is 6". You can (I hope) see some additional views at Healey Photos . These will give you some other angles. Ignore the door seal photos, they're not for your model.
John, thanks for the link to the pictures. This is just the information I needed. I see from the pictures that this is the tiresize I want. Hopefully I will find som Avon ZZ at this dimmension. I am on my way to the tireshop.
And thanks for the filterinformation, Fram filters are much more availible here than Unipart filter, which I have to order from UK. /ubbthreads/images/graemlins/cheers.gif
[ QUOTE ]
[/ QUOTE ]
Before you purchase the Avon ZZ (I think it is properly the CR6ZZ be sure to check for actual tire section and diameter dimensions. I believe this tire is wider and smaller by several .1" than the 175/70 zX (no longer available)or correct 5.90/15. I have found one tire close to original correct diameter is the Vredestein Sprint Classic in 185/50 or even better the Michelin XAS (very expensive) available from Coker.
Whatever you buy please let us know how it looks and performs.
T TR4/4A TR4A wire wheel tire size & powder coating? Triumph 18
G Tire size for wire wheels Triumph 20
H 15 x 6.70 Size Tire Ok for 100-6 Wire Wheel? Austin Healey 3
H BJ8 wire wheel and tire size Austin Healey 7
R 2500M Inner Fenders - are they the same as a Vixen 2500? (Also Tire Size) TVR 3
P TR6 What make and size tire was on the TR6 when it left the factory? Triumph 7
M TR5/TR250 Compatible Modern Tire Size Triumph 5
F TR2/3/3A Spare Tire Size Triumph 11
vette Tire Size and Improving Rear Brake Drums Austin Healey 17
D Series II E-Type tire size Jaguar 9
H BJ8 tire size Austin Healey 14
T TR5/TR250 TR-250 Tire Size Triumph 6
NutmegCT Tire size substitution Restoration & Tools 4
B experience with tire size changes? Other British Cars 2
B TR2/3/3A Tire Size Triumph 14
britlover proper tire size to replace 5.90-15? Austin Healey 16
S General TR Tire Size Triumph 18
Jim_Gruber Tire Size and Stock BE Wheels Spridgets 40
B T-Series MG TD metric tire size MG 5
B New VTO wheels ?? Tire Size for TR3 Racing 7
B VTO Wheels/Tire Size Triumph 13
O TR2/3/3A TR3 Wheel Swap and Tire Size Triumph 10
T TR2/3/3A TR3A Spare Tire Well & Tire Size Triumph 13
davidk What size modern tire will fit in spare tire well? Triumph 7
R TR2/3/3A TR3 Tire brands and size Triumph 5
K TR3 Tire Size for Shelby 500 Alloy Racing Wheels? Racing 0
K TR2/3/3A Tire size for 5.5x15 alloy racing wheels? TR3 Triumph 8
60TR3A What Size Tire is Ideal for a 15" X 5.5" Wheel? Triumph 29
tmc Tire size for the spare Triumph 10
V Tire size consensus Triumph 4
ekamm TR2/3/3A 3a steel wheel tire size? Triumph 14
J Tire size Spridgets 8
L What size tire will fit... Austin Healey 17
toysrrus RE: Tire Size Suggestions Wanted: Triumph 5
A bugeye tire size Spridgets 5
longbridgehealey Bugeye tire size Spridgets 2
MTribe TR6 TR6 tire size photos? Triumph 30
tomshobby tire size? Spridgets 11
D Tire size for 73 midget Spridgets 2
T Largest tire size I can put on my 89 xj40 Jaguar 1
6 Tire size conversion Triumph 0
htchevyii MGB need tire size recommendations for 77 MGB MG 6
E BE Tire Size Spridgets 20
L Street Tire size for 60 spoke wheels Austin Healey 15
Steve P. 5" aftermarket rims, what tire size needed??? Spridgets 3
N TR6 Opinions on 205-70R15 tire size for TR6 Triumph 11
I Bugeye tire size Spridgets 3
longbridgehealey Tire size Spridgets 12
YYCDave TR6 TR6 Rear Shock Conversion & Tire Size Triumph 2
Morris Stock tire size Spridgets 11
