Throttle linkage sticking
xbimmer
Member
The throttle is sticking in my '59 Bugeye. The pedal will depress about 1" then stick....a little more pressure it will break free and jerk you backwards. I've oiled the wires but I think now it might be where it attaches to the carbs. Any help?
Replaced mine with - of all things - a new biycle cable from my local shop. greased the heck out of it beforehand and presto - works great.
Be careful of creating any angles. The bike shop should have various items to prevent this.
George Zeck
I used a bicycle cable as well. Brought the old cable in, and they were able to make one up to match for cheap.
Also check the linkage in the cockpit for a bit of sticking.
I think the last "official" throttle cable I put on any of my cars was back in the late '60's! I always use bicycle brake cables. <shrug>
Walter74 BJ7 Throttle Linkage "Support Panel" Austin Healey 5
Popeye TR4/4A Throttle Linkage Triumph 5
CARSINC Throttle linkage question Spridgets 1
rgfrey 1959 BN7 Throttle Control Linkage Austin Healey 2
D TR2/3/3A TR3 throttle linkage bell crank. Triumph 34
C Jammed Throttle Linkage Austin Healey 3
Michael Oritt 100 throttle linkage--help needed Austin Healey 3
F TR2/3/3A Throttle linkage cross rod Triumph 4
C TR6 Carburetor Throttle Linkage Triumph 10
ckeithjordan TR2/3/3A H6 Throttle Linkage Triumph 13
T Looking for advice for throttle linkage for Weber DCOE Spridgets 2
Rut TR4/4A SU throttle linkage and brackets Triumph 5
MY66AH Throttle Linkage Spridgets 9
B Longbridge 100-6 Throttle Linkage Pictures - Any Out There? Austin Healey 27
J TR2/3/3A Throttle cable instead of the linkage?? Triumph 1
newmexTR3 TR2/3/3A TR3 Throttle linkage pics needed Triumph 19
H TR4/4A 4A Throttle linkage for HS6 SU Triumph 2
A TR4/4A TR4A Throttle - Lower linkage length Triumph 1
vette Throttle Linkage Ball Joints Austin Healey 5
T Keeping the throttle linkage shiny Triumph 5
DrEntropy Alfa throttle linkage? Other Cars 3
MrBlueSky Wedge tr8 edelbrock throttle linkage Triumph 2
R GT6 Need to see GT6 Mk1 Throttle linkage Triumph 9
drooartz Throttle linkage question Spridgets 6
Zimmycobra Throttle linkage saga continues Triumph 5
Zimmycobra TR4/4A TR4A throttle linkage Triumph 6
Got_All_4 TR5/TR250 TR250 throttle linkage problem Triumph 6
T TR2/3/3A TR3 Throttle linkage return spring Triumph 3
D Ratco Throttle Linkage Triumph 8
J Healey 3000 - throttle linkage [cable] Austin Healey 11
T TR6 Picture/diagram of TR6 throttle linkage Triumph 7
bighly Improved throttle linkage MG 1
philman Wedge TR8 Throttle Cable linkage help Triumph 3
G Throttle switch and linkage Austin Healey 5
T Throttle linkage question Triumph 2
chicken Throttle linkage for BJ7 Austin Healey 6
B BJ7 Throttle Linkage Problem - Access? Austin Healey 6
D Ratco Throttle Linkage Triumph 31
vping Throttle linkage - I need a pic MG 13
chicken RHD Throttle Linkage Assembly For BJ7 Austin Healey 2
S HS2 SU dual carb throttle/choke linkage Spridgets 10
tosoutherncars DGV throttle linkage help needed Spridgets 4
DrEntropy YO! Brosky!!! [RE: Throttle linkage couplings] Triumph 15
Brosky Throttle linkage from Ratco Triumph 35
P Throttle linkage on 1967 LHD. BJ8 Austin Healey 5
ronzet Hot Throttle Linkage [I've got a weird one...] Austin Healey 15
G Triple Stromberg throttle linkage Triumph 12
S Adjusting Throttle Linkage Austin Healey 3
mbrooks BN2 throttle linkage Austin Healey 1
Lin Carb Linkage and Throttle Cable Austin Healey 3
