The 'Prince" has struck
Jim_Newman
Hi Gang:
This one is for the automotive electrically unimpaired in the group (of which I not a member).
The BN7 will not start. There is no spark at the plugs. Every electrical component (lights, horns, wipers, starter motor, etc.) works fine. In the process of trying to diagnose the problem, I removed the distributor cap(new) and disconnected the high tension wire to the coil(new). When I turn the ignition switch OFF, a lovely hot spark jumps from the centre post of the coil to the nearest ground. This happens each time I turn the switch on then off.
I have checked the continuity of wires wherever I can, have checked the connections under the dash, and scratched my head quite a bit.
Can somebody pleeeease tell me what is going on. I assume there must be a short somewhere, or something that should be grounded isn't but how do I find what and where it is and fix it. The car was converted to negative ground years ago and has a Pertronix ignitor set up.
As always, any help or guidance is greatly appreciated
Re: The 'Prince" has struck
Spark when energising then de-energising means coil works, power to coil is correct.
Now.
What did you change last?
Points or some other system?
If points, did you just change anything, and get the ground isolators wrong?
If not, we could have a bad condensor or points closed. Crank the engine with cap and rotor off, watch the points, do they open and close?
Questions, and something to check.
No points, no coil, Pertronix ignitor.
The usual reason for not having spark at the plugs when you have it at the coil is a bad rotor or cap. If you have spark at some plugs, but not all, it would be a bad spark plug wire or bad cap.
Some rotors have had high failure rates.
I have also heard that installing the Pertronix disk under the rotor pushes the rotor up so that the carbon brush in the center of the cap is crushed.
Thanks John
I had not considered the rotor itself. I'll check it out tomorrow. The carbon brush was duly ground down in order to fit properly over the rotor and it makes good contact with the rotor.
Cheers
There are only a few components between the disti cap and the plugs.
I would check the cap, rotor and if any doubt, simply replace. Next check the connections to the pertronix. If it still doesn't start, run a jumper from the battery to the +12V line (I'm looking at the pertronix trouble shooting guide from the one I recently installed), as the pertronix will not operate with a low voltage condition. If all that fails, I would bet on the pertronix unit went south.
There should have been no reason to grind the center brush down unless the magnet assembly is not fully seated.Remove it and try a different location to install it on the cam>-Fwiw--Keoke
If you've got a Pertronix and there's a spark on switch on or off, but t no other time, it is probably faulty. Try another.
Ash
The rotor seems OK. The concensus is a faulty Pertronix. Before buying a new one, is there some independent test I could run on the Ignitor unit itself to verify that it is indeed defective? This whole process started when the engine fired up and then quit after 20seconds and hasn't run since.
Happy Thanksgiving to all our US friends.
Cheers
I will do that t.h., but I'm getting this spark to ground from the coil when the rotor is out of the game. That is, the high tension wire to the distributor is disconnected. The only connection to the coil are the usual low tension wires plus the black and red wires from the Pertronix unit. Since the coil is producing this high energy spark, it appears to be receiving the required 12V. What I'm having the most trouble understanding is why the coil discharges this way (right to the ground terminal on the coil)when the ignition is turned OFF.
Cheers
Did your check/replace the cap and rotor? A quick google (not mine, but makes sense knowing how it operates) netted this to test your pertronix with a simple multi-meter.
Connect a wire from the ignitor base plate to the battery earth terminal; Connect the red wire from the ignitor to the battery live terminal; Connect the -ve wire from a multimeter/voltmeter to the ignitor black wire; Connect the +ve wire from the multimeter/voltmeter to the ignitor red wire; Turn or briefly crank the engine to rotate the magnetic sleeve - volts should fluctuate between battery voltage and 0v; Constant voltage indicates the ignitor is faulty.
yeah, I would replace your cap and rotor before fiddling with the pertronix. The Pertronix units are far more reliable than the rotors especially. I always carry spare rotors in my cars.
I had a Pertronix installed in my bj8. I got soon problem with ignition. When investigating I found out that the center plasic part over the cam lifts the rotor from its original position and distributor cap connector seat to rotor gets damaged. By grinding the lower face of the rotor this lift can be compensated. Measure the installation height of the rotor to a reference point of distributor house, with and without the center part of Pertronox to eliminate same problem.
For my TR6 the frist Pertronix failed and would discharge a spark each time the ignition switch was cycled on and off. The second Pertronix failed when the magnets seperated from the mounting on the point cam. I understand the later Petronix ignitions are improved but after being twice bitten...
After the second failure with the Petronix ignition I installed a Crane Fireball with the optical sensor trigger. That was about fourteen years ago and have not had ignition failure issues since.
You're absolutely correct Bustren. The alternative approach is to grind down the carbon element at the centre of the distributor cap above the rotor (which is what I did) to compensate for this mismatch.
Cheers
One spark from a Pertronix on shut-off is generally a sign of failure. That would be my initial guess on diagnosis, and I deal with these problems daily.
I find that RFI noise from the solid core spark plug wires in the AH 3000 will actually wreak havoc with the Pertronix ignitions. RFI can actually "blind" from the module reading its own magnetic signal if there is a lot of noise from the solid core ignition wires. later BJ8 distributors can run modern carbon-core wires which eliminate the problem. If you use carbon core wires in the 3000's DM6 distributor, The wires will fail relatively quickly from puncturing them with the hold-down screws.
G The Prince of Darness has struck MG 13
C The Prince has found me Triumph 10
D Prince of Dimness Spridgets 4
B The Prince of Darkness on the dash board finally conquered Austin Healey 10
H Lucas Prince of darkness Austin Healey 4
B Prince of darkness conquered in the cockpit Austin Healey 17
HealeyRick Prince Charles Had A Healey? Austin Healey 7
D Thwart off the Prince of Darkness.... Spridgets 17
F Prince of Daarkness Spridgets 18
bthompson The Prince of Darkness strikes again. Spridgets 8
C The Prince of Darkness strikes. MG 4
lbc_newbie More fun with the Prince of Darkness Spridgets 9
davester The Prince of Darkness strikes! Dead starter MG 15
JPSmit The Prince of Darkness strikes again Spridgets 5
ooman About the Prince of Darkness... Austin Healey 1
19_again The Prince lives on MG 14
Webb Sledge The Prince of Darkness Finally Strikes Triumph 15
Nunyas The Prince of Darkness stikes once more... MG 9
jaybird The Prince of Darkness... MG 7
MGTF1250Dave Lucas, the Prince of Darkness MG 20
K TR2/3/3A How to tell if the timing chain has slipped...... Triumph 12
drooartz The great Gordon Murray has a Bugeye! Spridgets 0
R TR6 I just brought this to its new home. It has been stored for 15 years, has only 21000 miles , and only 1000 sincw Triumph 12
B tachometer cable has a hole in it Restoration & Tools 7
K TR2/3/3A Red ignition light stays on...car has alternator not generator. Triumph 17
W Wanted Servo for BN4 has to be original 1957 or before any condition considered. Austin Healey Classifieds 11
AUSMHLY BJ8 Transmission just rebuilt now has metal filings Austin Healey 10
K TR2/3/3A Clutch Slave Cylinder location when TR3 has a TR6 Gearbox? Triumph 16
T TR2/3/3A Has anyone designed a hand brake warning light for the TR3? Triumph 3
R Has this ever happened to you? Any odd Sprite story... Spridgets 8
P Hoping someone has this measurement easily available. Austin Healey 3
E General TR Hertitage certificate: factory record has not survived Triumph 11
R General Tech Preserve eng/trans that has been removed Triumph 11
S TR2/3/3A TR3 has me stumped, it runs then dies over and over and the exhaust system was pulled Triumph 9
T TR6 Car has always started without fail.....until now Triumph 10
C TR6 A lot has happened. Update on my project Triumph 7
Jim_Gruber In need of 2 Fulcrum Pin Bolts - MOSS Has them on Back Order Spridgets 3
K TR2/3/3A Friends TR3 has carb issues? Triumph 5
vette To Johnny who has posted an Article in the Articles Section about his German Exported Austin Healey 9
BOBBYR My Dad has to be laughing Austin Healey 4
doc50 Metro 1500 Has Slack Timing Chain? Other British Cars 20
steveg Steve Kingsbury has lost everything. Austin Healey 11
Got_All_4 TR2/3/3A Has anyone installed one of these slack limiting plates Triumph 4
Sarastro TR4/4A Camshaft oddity has me concerned Triumph 6
Got_All_4 General TR Has anyone used these poly bushings Triumph 6
5 For Everyone that has a BUGEYE OR FROGEYE Spridgets 3
M Overdrive has a mind of its own Austin Healey 21
Mickey Richaud Mod Note "Tinkerman" Has Passed Triumph 23
RAC68 Has anyone considered Power Rack and Pinion Stearing and/or an Air Bag suspension Austin Healey 32
K TR2/3/3A Moss Europe has restored the Jabbeke TR2 Triumph 0
