The Prince has found me
Colin_D
Member
Help.
So I take my TR6 out of storage a few months ago and the headlights don't work, I go to drive it today and the directionals don't work, (of course I figure this out when I get home). I did put Halogen headlights in last year and I was planning on buying the heavy duty headlight harness from Victoria British, but now that the blinkers aren't working I'm a little worried.
Has this happened to anyone else?
Cheers,
Colin
I would check all your connections (standard answer).. I would also check the appropriate grounds (also standard answer).
Cheers,
Colin
*SPUTTER*!! *GASP!!*
NEVER!!! :smirk:
All grounding points are suspect, all Lucar connectors should be taken apart and cleaned, dielectric grease used upon reassembly. From the symptoms described, the grounds are most likely the culprits.
Being that I answered Colin's question may I ask a question in the same genre?
My Wedge has no flashing blinkers only solid,but the hazard flashes. Does this sound like the blinker flasher. Can the grounds be dirty and the flashers still work?
Here's a kind of odd one, for a while I had a weird situation where the all of the lights on my Jag Etype were acting strangely.
When I had all of the lights off and I used the turn signals only the marker lights would flash. If I turned on just the marker lights both the turn signal and marker lights would come on steady, if I then used the turn signal the marker lights would go off and the turn signal would flash. With the headlights on the marker and turn signal lights didn’t come on, when I used the turn signal the headlights went out and only the rear brake lights flashed.
I ended up tracing thru and cleaning every connection trying to figure out why it was acting so strange. It finally turned out the ground on the rear lights was corroded. When I cleaned that up all of the lights worked perfectly after that.
The lesson that I learned is never underestimate how even one bad ground can make seemingly unrelated parts of the electrical system on these cars misbehave.
So as others have said the first thing I would try is to start to systematically go thru all your electrical connections and clean them up you probably just have a bad ground.
The stock turn flasher unit requires no ground itself; but is rather picky about how much current goes through it. If you've changed bulbs to ones that draw more or less current than original, the flasher may not flash at all. Or anything that causes a high resistance or low voltage in the common part of the circuit can also cause problems (including the hazard switch).
But since the two sides are grounded separately, normally a ground problem will only show up on one side.
Note that it's a different flasher (different part number too) for hazard and turn. The hazard flasher is normally a "load independant" type, so you can try substituting it for the turn flasher (but the original turn flasher won't work right as a hazard flasher).
I was talking about the bulb end. If the ground is bad at that end I take it the hazard won't flasher either?
The turn flasher is a 2 pronged deal as the 6. Isn't the hazard flasher a multi pronged affair?
Cycle the hazard switch a couple of times. All TS current passes thru the hazard sw, and sometimes they get a little grumpy. Usually cycling the switch will cheer up the contacts. Worth a try anyway.
No, the hazard flasher is a lot less picky about current; it will flash as long as it sees any current at all.
But since it's different bulbs between left turn and right turn; normally a grounding problem at a bulb shows up as different behavior between left/right.
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]The turn flasher is a 2 pronged deal as the 6. Isn't the hazard flasher a multi pronged affair? [/QUOTE]Could be, as I'm not all that familiar with the TR8 and all it's wiring variations. But the TR8 schematics I have show 2-terminal units for both turn and hazard (same as my Stag).
Randall you are probably right and you know as much with this car as I do. On my turn flasher I have the LG/W and LG/N going to it.Where is the hazard flasher anybody know?
Jim_Newman The 'Prince" has struck Austin Healey 16
G The Prince of Darness has struck MG 13
D Prince of Dimness Spridgets 4
B The Prince of Darkness on the dash board finally conquered Austin Healey 10
H Lucas Prince of darkness Austin Healey 4
B Prince of darkness conquered in the cockpit Austin Healey 17
HealeyRick Prince Charles Had A Healey? Austin Healey 7
D Thwart off the Prince of Darkness.... Spridgets 17
F Prince of Daarkness Spridgets 18
bthompson The Prince of Darkness strikes again. Spridgets 8
C The Prince of Darkness strikes. MG 4
lbc_newbie More fun with the Prince of Darkness Spridgets 9
davester The Prince of Darkness strikes! Dead starter MG 15
JPSmit The Prince of Darkness strikes again Spridgets 5
ooman About the Prince of Darkness... Austin Healey 1
19_again The Prince lives on MG 14
Webb Sledge The Prince of Darkness Finally Strikes Triumph 15
Nunyas The Prince of Darkness stikes once more... MG 9
jaybird The Prince of Darkness... MG 7
MGTF1250Dave Lucas, the Prince of Darkness MG 20
K TR2/3/3A How to tell if the timing chain has slipped...... Triumph 12
drooartz The great Gordon Murray has a Bugeye! Spridgets 0
R TR6 I just brought this to its new home. It has been stored for 15 years, has only 21000 miles , and only 1000 sincw Triumph 12
B tachometer cable has a hole in it Restoration & Tools 7
K TR2/3/3A Red ignition light stays on...car has alternator not generator. Triumph 17
W Wanted Servo for BN4 has to be original 1957 or before any condition considered. Austin Healey Classifieds 11
AUSMHLY BJ8 Transmission just rebuilt now has metal filings Austin Healey 10
K TR2/3/3A Clutch Slave Cylinder location when TR3 has a TR6 Gearbox? Triumph 16
T TR2/3/3A Has anyone designed a hand brake warning light for the TR3? Triumph 3
R Has this ever happened to you? Any odd Sprite story... Spridgets 8
P Hoping someone has this measurement easily available. Austin Healey 3
E General TR Hertitage certificate: factory record has not survived Triumph 11
R General Tech Preserve eng/trans that has been removed Triumph 11
S TR2/3/3A TR3 has me stumped, it runs then dies over and over and the exhaust system was pulled Triumph 9
T TR6 Car has always started without fail.....until now Triumph 10
C TR6 A lot has happened. Update on my project Triumph 7
Jim_Gruber In need of 2 Fulcrum Pin Bolts - MOSS Has them on Back Order Spridgets 3
K TR2/3/3A Friends TR3 has carb issues? Triumph 5
vette To Johnny who has posted an Article in the Articles Section about his German Exported Austin Healey 9
BOBBYR My Dad has to be laughing Austin Healey 4
doc50 Metro 1500 Has Slack Timing Chain? Other British Cars 20
steveg Steve Kingsbury has lost everything. Austin Healey 11
Got_All_4 TR2/3/3A Has anyone installed one of these slack limiting plates Triumph 4
Sarastro TR4/4A Camshaft oddity has me concerned Triumph 6
Got_All_4 General TR Has anyone used these poly bushings Triumph 6
5 For Everyone that has a BUGEYE OR FROGEYE Spridgets 3
M Overdrive has a mind of its own Austin Healey 21
Mickey Richaud Mod Note "Tinkerman" Has Passed Triumph 23
RAC68 Has anyone considered Power Rack and Pinion Stearing and/or an Air Bag suspension Austin Healey 32
K TR2/3/3A Moss Europe has restored the Jabbeke TR2 Triumph 0
