Tachometer not working following ignition upgrade
msgt
I have just upgraded my 1964 BJ8 Phase 2 with a CSI unit - this was a bit fiddly but went well and the engine is a lot easier to start and runs very nicely.
However - the tachometer does not work - I have tried reconnecting the tachometer wire but without success.
The car is positive ground and, for some reason, the tachometer is labelled -ive ground - and was wired up aftermarket - before I start troubleshooting and replacing the -ive ground tach with a +ive ground one - has anybody seen this before?
Thanks
Mark
Some have said the electronic ignition does cause change in the tach. Go to Healey6.com and look under technical and electrical. There are articles about changing the the tach. I think one said take one loop out of the sensor wire on the back of the tach for electronic ignition.
Jerry
On the AHEXP forum, someone posted an old doc for wiring a Smiths tach with a Pertronix; it showed one loop around the pickup on the tach (try wiring it in both directions). I have a Pertronix on my BJ8, and the tach works OK up to about 4,500RPM, where it bounces like crazy (but I rarely rev that high). Both points and electronic ignitions send pulses and I've always wondered why the issue with electonics; maybe because the electronics output more of a square wave, possibly with a higher voltage.
Tachometer now working - thanks Bob and Jerry
I did not have original wiring.
The eventual solution was to revert back to the original wiring and take out a loop so that the white wire passes through the pickup only once - I had also upgraded the coil to a Lucas DLB 105 and it seems that the pulse was too powerful when the loop at the back of the tachometer was in place.
I followed links from Healey6.com and AHEXP and found the solution under Pertronix support - I also found the Gentleman's Guide useful and an interesting read.
Pertronix Support
Gentleman's Guide to Smiths Tachometers
Thanks
Mark
Mark
Good to see you have your tachometer working. I had confirmed that the Smith's RVI tachometer will work with the Pertronix (or equivalent) unit so I knew you would find the problem. Fortunately, your tachometer was not damaged. I wrote a couple of articles for the HEALEY MARQUE magazine last year on how this tachometer works. Perhaps this is a little bit more information than you need, however, it is interesting to know how these tachometers were designed back in the day of transistors.
  • HM 01.2020.p46-47.pdf
  • HM 02.2020.p38-39.pdf
  • HM 03.2020.p38-39.pdf
Bill,
thanks for writing the articles and sharing. I have an early BJ8 with I have converted to negative ground. The later models you just switch the green wire and the long brown thing (don't know the electronic name). The early unit does not have a green wire. Have you any hints for that unit?
Jerry, the earlier tachs were mechanical so no green wire, no looped white wire.
1 MGB Speedometer and tachometer on '66 MGB are not working MG 8
P I need a non-working electric tachometer for parts Spridgets 0
T BJ8 Tachometer and Fuel gauge stopped working. Austin Healey 27
B tachometer cable has a hole in it Restoration & Tools 7
F TR6 Tachometer lighting Triumph 8
S Engine or Tachometer Odd Problem Austin Healey 7
Magyar Rebuild Speedometer & Tachometer - mechanical or electronic? Spridgets 17
S For Sale Early Sprite & Midget Speedometer/Tachometer/Generator etc. Spridgets Classified 2
E Oil leaking from the Tachometer cable Austin Healey 5
E MGB Tachometer 65 mgb MG 5
vette Just a note to Bill Young about his work with the electronic tachometer. Austin Healey 2
RAC68 Calibrate Smiths Tachometer Austin Healey 12
B For Sale MGA JAeger Fuel Gauge, Dual Safety Gauge, Speedometer and Tachometer MG Classifieds 0
B For Sale Austin Healey 100 Smiths Fuel Gauge, Dual Safety Gauge, Speedometer and Tachometer Austin Healey Classifieds 0
B For Sale Triumph Tr3 Fuel gauge Temp gauge Oil pressure gauge, speedometer tachometer Triumph Classifieds 0
T TR2/3/3A Noisy tachometer Triumph 9
S Intermittent operation of tachometer Austin Healey 9
Lin Tachometer/Dwell Meter Austin Healey 10
N Tachometer?? Spridgets 6
W Tachometer reads high when engine compartment heats up Austin Healey 3
D TR2/3/3A curious tachometer take-off Triumph 5
NutmegCT T-Series Tachometer repair MG 15
Boink Tachometer seize? Spridgets 11
Michael Oritt Electric tachometer connections--No Healey content Austin Healey 7
M TR2/3/3A Tachometer Malfunction Triumph 7
drooartz Geeking out over a tachometer Spridgets 15
C tachometer for XJ6 Jaguar 0
S TR4/4A Tachometer Triumph 5
GTP1960 TR2/3/3A Tachometer vs rpm analyzer? Triumph 5
Roger Lotus Elan S3 - Rev Counter [Tachometer] needed Lotus 4
5 Lazy Tachometer Spridgets 14
DanLewis Electronic tachometer for Bugeye Spridgets 18
J Mechanical tachometer to electric Austin Healey 11
J WTB: Bugeye Tachometer Blanking Plate Spridgets 11
B Smiths RVI Positive Ground Tachometer Bench Test ? Austin Healey 24
Marvin Gruber Tachometer reading too high Jaguar 4
A Need Help with a Tachometer -- the drive portion. Austin Healey 1
M Quick tachometer wiring question on a '65 Spridgets 10
D Tachometer Triumph 9
L BJ8 Tachometer problem Austin Healey 6
P Tachometer versus lights Austin Healey 5
apbos Tachometer ID Smith's Rn1412/00 Spridgets 5
pkmh BJ8 Tachometer, "sparking" Austin Healey 35
G T-Series Tachometer and ignition switch MG 16
I Reproduction tachometer drive quality? Spridgets 4
K TR2/3/3A TR3 Dist Pedastal Tachometer Attachment? Triumph 3
K tachometer question Spridgets 9
B MGB MGB tachometer erratic, engine cutting out.... MG 11
F Ignition System/Electric Tachometer Triumph 9
F Spitfire Spitfire Electric Tachometer Problems Triumph 5
