Stewart
It was a pitb to install due to having to change the pedal box but it was worth it.
The kit that moss put together was awesome. Everything you needed was there down to the super glue to make up the manifold shims.
Once the pedal box was done the install was strait forward though I found getting the lower radiator hose in the right position to fit and not kink was a pain that took a bit to sort out.
Driving I must say the car has changed completely. In traffic it's fantastic just a light press on the pedal is all you need to keep up in LA's fast moving traffic. Need to make a quick pass just romp on it and your grin will reach the back of your head. Getting on the freeway is simple as the car no longer takes its own sweet time to build up speed. Just romp on the gas pedal and it leaps forward. I'm looking forward to getting up in the mountains but need just a little bit more time before I take it out of cell range.
Sound wise the car has also changed. The supercharge whine is addicting and the exhaust note has taken on a more ripping of the air tone when at full throttle. Sounds down right angry.
Dang car is going to get me a speeding ticket.
